Old 05-04-2018, 02:27 PM   #3753
Sleepyyysam
sleepy
Sleepyyysam's Avatar
Drives: Brz
Welcome to the Forum!
235/35/18 is super rare, what tire are you thinking?
I'd go 225/40/18. Get camber bolts too.
Good luck!
Hey, thanks for the reply! Do you think the 225 will stretch too much for the wheel? I've personally never had to try and tuck a wheel and tire into such a small area haha. I'm considering not even getting the wheels if they won't fit neatly.
Sent from my Pixel XL using Tapatalk
Sleepyyysam is offline   Reply With Quote
Old 05-04-2018, 03:00 PM   #3754
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The car has a ton of room. You just need suspension parts to fit larger wheels. There are guys running 18x10 all around on stock body cars. Check it out.
http://www.ft86club.com/forums/showt...t=38557&page=2
After reading your response, I'd look through here and get some ideas on what you like, then go from there. It has almost every wheel that forum members have tried.
http://www.ft86club.com/forums/showthread.php?t=7535
I LIKE TIRES!
Old 05-05-2018, 06:57 PM   #3755
Sleepyyysam
sleepy
Drives: Brz
These threads were super helpful! Thank you man. Sorry for the noob questions, I'm fairly new to the forums. It is a big overwhelming at first.
Old 05-22-2018, 03:40 PM   #3756
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
anyone run 18 x 9.5 +38 squared Wedssport SA10R wrapped in 275/35/18 Toyo R888? This is what I am looking at getting for a track set of wheels, but want to make sure I am able to, I am running feal coilovers.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 05-22-2018, 06:42 PM   #3757
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IDK if I am the guy to answer this, because I don't track my car.
Tirerack says that the TOYO R888R is available in 275/35/18, has a tread width of 10.5, and weighs 27lbs. This is a huge tire. I would think that you would want it on a 18x10 or wider wheel. Anyway, there is tons of info about how to fit 265/35/18's (and larger) in this thread.
http://www.ft86club.com/forums/showthread.php?t=41083
You will rub in the rear on the bumper tab. (till it is gone or you shave it)
This thread has 275/35/18s on a 18x10. But the MPSS tire only has a tread width of 9.6"
http://www.ft86club.com/forums/showt...t=95645&page=2
You can see different size tires on 10.5" wheels in this thread.
http://www.ft86club.com/forums/showthread.php?t=82813
Keep reading and post your question(s) in a Track thread or the Meaty tire thread. Guys that have this style of setup will more likely read your post there.
Good luck!
I LIKE TIRES!
Old 05-23-2018, 07:18 PM   #3758
Drakiv
Project Shadow
Drakiv's Avatar
Good luck!
Appreciate the info, I have already been searching non stop this past week and couldnt find any info on that exact setup. I already run 265 tires in the back now, but im staggered. Fine for the street but I want a better setup for the track. Wanted to move up to 275, which I know a couple people are running but I dont think they have a +38 offset. I need more meat to keep traction with the power im running.
614whp/421tq on E85
Instagram: Drakiv
Old 05-24-2018, 11:33 AM   #3759
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
You most likely wouldn't notice a difference between 265s and 275s as far as traction goes. That's a small amount of difference. I'm running 265s squared and it's probably the widest you can go without needing to do a bit more modification.
If you absolutely need more, just know you may need to pull or roll fenders, shave down bumper tabs, etc. You'll also lose the ability to go full lock on steering without rubbing inside. This is the reason I stayed at 265 squared - none of the above issues and it works very well.
PR138
IG: @pr.138
2008 LBP Honda S2000
2013 UM Scion FR-S
PR138 is offline   Reply With Quote
Old 05-24-2018, 12:25 PM   #3760
Greenbean
Drives: 2017 series yellow BRZ
Widebody brother
Greenbean is offline   Reply With Quote
Old 05-27-2018, 07:25 PM   #3761
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
https://www.momo.com/en-us/product/heritage-6/
https://jalopnik.com/put-these-new-r...-ow-1826355175
Looks like they got wheel sizes that will fit the twins.
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 05-28-2018, 04:06 AM   #3762
15limited
15limited's Avatar
Compound compound compound. Traction issue solved
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 05-28-2018, 11:56 AM   #3763
Drakiv
Project Shadow
Drakiv's Avatar
So it sounds like I should be fine running R888's on 265's then. Thanks for the help guys.
614whp/421tq on E85
Instagram: Drakiv
Old 05-28-2018, 10:40 PM   #3764
SomeOneQC
SomeOneQC's Avatar
Drives: 2017 BRZ Sport-tech
Originally Posted by Jordanwolf View Post
Did you have a problem with them? Just in case, check the rear interior ones for any damage.
I had the original tire 215/45R17 on 17x8 wheels. The tires were stretch and yesterday this happen.
I guess it's caused by the stretching.
SomeOneQC
2017 BRZ
2016 STi
2009 HD Rocker C
SomeOneQC is offline   Reply With Quote
Old 05-28-2018, 11:12 PM   #3765
Jordanwolf
Rice King
Jordanwolf's Avatar
Tires are doing well, about 2k on them on the new wheels.
Stock tires are supposed to fit fine on 17x8. I would look at other causes than the stretch.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 05-30-2018, 12:51 PM   #3766
Teseo
Drives: frs
I will be shopping for new tires in the next week, my car is lowered on eibach pro kit (stock struts) and wheels are 17x8 +25. 235/45 will rub? Or im in safe side with 225/45? Link for fitment calc doesnt work, that's why asking before pull the trigger
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
