Old 05-30-2018, 01:01 PM   #3767
Vital
Drives: 2015 BRZ
Originally Posted by Teseo View Post
I will be shopping for new tires in the next week, my car is lowered on eibach pro kit (stock struts) and wheels are 17x8 +25. 235/45 will rub? Or im in safe side with 225/45? Link for fitment calc doesnt work, that's why asking before pull the trigger
235/45 will fit, but they are too tall. You are better off getting 225/45 or 245/40.
Vital is offline   Reply With Quote
Old 05-30-2018, 01:16 PM   #3768
Teseo
Drives: frs
Thanks mate, with those size on mind i let the prices determines wich to buy
Old 05-30-2018, 05:41 PM   #3769
Greenbean
Drives: 2017 series yellow BRZ
Originally Posted by Drakiv View Post
anyone run 18 x 9.5 +38 squared Wedssport SA10R wrapped in 275/35/18 Toyo R888? This is what I am looking at getting for a track set of wheels, but want to make sure I am able to, I am running feal coilovers.
pushing your luck with 275 especially if your tracking the car. if its just the rear maybe but definitely not in the front. honestly if you want to track the brz/frs/86 consistently a 17 inch tire is the way to go.
Greenbean is offline   Reply With Quote
Old 06-03-2018, 08:33 AM   #3770
GerrelleZeppeli
Drives: Toyota 86
I'm planning to get Work GT5 18x10.0 +38 all round. Currently lowered with Tein Flex Z.
For tyres, I'm going for 265/35/18, with the alignment set to -3 in the front, -2 in the rear.
Will this cause any issues/rubbing?
If so, will 245/35/18 for the front be ok? Or would it be better to go 18x9.0 +38 in the front?
GerrelleZeppeli is offline   Reply With Quote
Old 06-03-2018, 12:17 PM   #3771
15limited
15limited's Avatar
Too tall for what? I ran 245/45, it throws your speedo off but i ran into no fitment issues.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 06-03-2018, 12:24 PM   #3772
15limited
15limited's Avatar
Hmmm in comparison to my setup you'll be really close, the aggressive camber will help stay away from fender rub, but I bet you'll still rub in the front at full steering lock like I do slightly with 18×9.5 +40 265/35/18 falken rt615k+
Old 06-03-2018, 10:37 PM   #3773
GerrelleZeppeli
Drives: Toyota 86
So would 18x10.0 +38 be too much for the front?
Would 18x9.0 +38 be better in the front with say 245?
Old 06-04-2018, 12:29 AM   #3774
Vital
Drives: 2015 BRZ
I never said anything about them not fitting? I am aware they will fit I just don't understand why anyone would choose to run tires that are 2-3 inches taller than stock size its just not ideal to me. If it works for you thats great, but its not for me I prefer staying close to stock size...
Old 06-04-2018, 06:16 AM   #3775
Wyattkb
Drives: 2014 Whiteout FRS
Hey guys looking for some help on a new set of wheels and tires.
Looking to pickup a set of Rotiform LAS-R 17x9 and they come in 2 offsets +30 and +40.
I would like to run a wide tire since I'm boosted, I was thinking 255 or 245.
I have RCE yellows, koni yellows, rear LCA, SPL toe arms, camber plates and bolts up front.
My current alignment is running -3 camber front and -2.2 rear.
What can I run without any fear of rubbing/hitting spring perches?
Wyattkb is offline   Reply With Quote
Old 06-04-2018, 09:41 AM   #3776
15limited
15limited's Avatar
So they're "too tall" for you, not the car. And 235/45 aren't 2-3 inches taller than stock mpss
Old 06-04-2018, 09:48 AM   #3777
15limited
15limited's Avatar
I mean you can tuck a square setup, but you will probably lose steering angle or rub with rough road conditions. All depends on what you plan on using the car for and how low you want to be, I'm guessing by the camber and wheels specs you're going for fitment over function. Imho 18x9 eith 245/40 should easily clear at a streetable ride height, but I have never been a fan of running different f/r setups.
Old 06-06-2018, 02:59 PM   #3778
Fainten
Fainten's Avatar
Drives: white brz
I have a question, i already have 18 x 9.5 wheels with 245/35/18 all around. But now im looking to get a drop just to get rid of the wheel gap. im not trying to track it so was thinking eibach lowering springs. You'll think the front will fit and not hit the spring perch
Fainten is offline   Reply With Quote
Old 06-06-2018, 04:42 PM   #3779
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Without knowing your offset, there is no way to tell. But my guess, is that you will want coilovers.
Check out the meaty tire thread, especially page one, though the whole thread has tons of info on 18x9.5 wheels.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
Old 06-06-2018, 07:35 PM   #3780
Fainten
Fainten's Avatar
Drives: white brz
my offset is +35 all around
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
