Old 05-04-2020, 06:03 PM   #3809
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by Yoshoobaroo View Post
If your biggest complaint is turn in feel, rather than corner entry understeer, you'd probably be better off ditching the 9" steam rollers up front and get some sticky 215's instead.
Unless lap times are important to you, I don't see the need to over-tire the car for spirited drives and auto-x.
Not about lap times. I like the look of the 17x9 rpf1's, the car visually puts a huge smile on my face. I also don't know a ton about this stuff so I'm trying to learn. If I can improve the handling a bit while keeping the look I'd be happy.
For churchx, i'm running Dunlop ZIII's 245/40/17. At autox and the tail of the dragon I tend to lower the PSI down to 29-30ish.
Thanks again.
oldlostcory is offline   Reply With Quote
Old 05-04-2020, 06:40 PM   #3810
Pat
Pat's Avatar
Drives: 2023 BRZ
Sounds like you want more front roll stiffness (which was probably relatively high in the old Honda) and aside from maybe front toe change you'll get what you want out of a stiffer front swaybar. Camber and steering rack bushings won't help the car take a set any quicker imho. RCE Yellows are too soft for competitive autox tires.
Dampers would be next on my hit list to tackle a lazy front end after toe and swaybar (assuming you plan on sticking with the RCE Yellows). Although still do the camber, your tires will thank you.
While I expect you're spot-on with your suggestions given his original post, I'm going to add something to it. Reading between the lines (and hesitantly making some assumptions), I'm guessing his desire to improve "initial turn in feel" isn't everything he's going for. I bet he wants more front end grip more than anything. If that's the case, I suggest changing the alignment so the front has 1* more camber than the rear.
Note: I'm typing this mainly because he said, "The only other car I've ever driven aggressively was my old integra back in the day." I don't think he has nearly the driving or suspension adjustment experiences as you do, strat61caster.
Old 05-04-2020, 07:40 PM   #3811
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I hear you there. The more narrow RPF1s have a weird looking face convexity. The 9” wide versions look much better.
Old 05-04-2020, 08:20 PM   #3812
Pat
Pat's Avatar
Drives: 2023 BRZ
I totally agree. I can't think of another wheel that is so much this way. And stepping up to 18s is an even bigger difference.
Old 05-04-2020, 09:08 PM   #3813
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks again.
29-30 Cold?
Old 05-04-2020, 09:10 PM   #3814
Originally Posted by Scracho View Post
Hi guys!
I'm on my 4th 86 (Yes 4th) and have played with various suspension setups. I'm in the market for a $1500 street occasional track coilover and all roads have led me to a couple options.
IMO the largest improvement in ride/handling/lap times happen when you go from stock to DECENT coilover setup then from there unless you go to a full on pro setup the lap times aren't improving relative to cost from your decent "entry level" to medium tier coils. Thus the savings can be used for so many other items that will yield a faster, flatter and more enjoyable ride.
So that being said... CSG Tein Flex A OR RCE SS1????
I'd offer the counter viewpoint that a high end damper system that is set up well may not yield absolute lap times, but rather, yield relative lap times by giving the driver much more confidence in their vehicle.
With bias, my vote is CSG FLA + 17+ OEM rear sway bar
Old 05-06-2020, 04:58 PM   #3815
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Upgrading to FA500 coilovers from lowering springs this weekend. Given that the front coilovers have camber adjustment from the plates, can I just ditch the camber bolts that I've installed? Probably won't run more than -1.5 degrees.
Spacemane969 is offline   Reply With Quote
Old 05-07-2020, 12:41 AM   #3816
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Why throw them away? If they can get it close using the bolts only, keep the plate at "0" when you do the alignment. Thank me later.
Intent > Content
Old 05-07-2020, 01:04 AM   #3817
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Might I suggest using both - make identical adjustments using the camber plates, then zero the settings in using the bolts. That way you keep the SAI identical side to side. Also, if you ever decide you want more camber you can easily do it.
BlueWhelan is offline   Reply With Quote
Old 05-07-2020, 07:49 PM   #3818
Spacemane969
I just figured the more adjustable parts the more room for error.
Old 05-08-2020, 06:02 PM   #3819
solidONE
solidONE's Avatar
Camber bolts keep their position. People have been beating on it with adjusted camber from eccentric bolts since 2012. Not an issue.
There is more room for error, but It's not hard when you have an alignment rack to set the alignment.
Intent > Content
Old 05-09-2020, 06:26 AM   #3820
WolfWings
WolfWings's Avatar
Drives: 2018 Subaru BRZ Premium, Blue
Any general thoughts on the best options to pair with those Chuhatsu MultiRoad lift springs?
WolfWings is offline   Reply With Quote
Old 05-09-2020, 12:47 PM   #3821
Racecomp Engineering
I will use my stock 2016 struts at first with our RCE Rallyx springs, then Bilstein B6.
The TRD rally kit struts actually look pretty good if you can get them. The springs on that kit are just way too stiff and I'm not sure on cost/availability of the dampers alone. I'd still prefer the Bilsteins I think.
I plan on the Pedders camber/caster rubber top mounts.
I'm also thinking about the smaller/softer than stock Cusco swaybars. Definitely not necessary but could extra nice on dirt/gravel (and sacrifice a little bit on tarmac). I'm not sure that's a good idea with the Chuhatsu springs because those springs are a bit softer than our RCE RallyX springs especially up front.
Other than that....some bushings and the rear Cusco LCAs.
- Andrew
Old 05-09-2020, 01:40 PM   #3822
WolfWings
WolfWings's Avatar
Yeah I still plan to get ya'alls setup once it's finalized, but with... *gestures at the world* ...delaying everything and dog these seemed a good holdover as I'm finding myself spending a lot of time off asphalt and some of the stores in my area that are staying the best stocked I'm having to play the 'Ferrari encounters a speed bump' game to get in/out of their parking lot.
Thank you kindly for the info, found the NJP site that sells the TRD 86 Rally kit offers just the dampers as an option.
Last edited by WolfWings; 05-11-2020 at 10:04 AM. Reason: Dampers, not struts, USE THE RIGHT TERMS, derp!
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
