#3921 |
Drives: 2017 Toyota 86
menikmati
Senior Member I recently bought a 2017 Toyota 86 and added the Edelbrock S/C kit, along with a Jackson Water/Oil cooler kit and a number of other parts. I too found the HP A/C port blocked by the S/C intake runner. After a lot of research, I ran across the Aeroquip line of A/C adapters that can be fitted to the stock 10 MM aluminum HP A/C hose ends. If you go to: https://www.facebook.com/foothillsrestorationwerks you will find my posts on this area and several other upgrades. I've built a Track Day (HPDE) car, and completely gone through all the major systems to make it as fast and reliable as needed. Best regards, Barry |
#3922 |
It was a homebuilt project. I'm going to make a few for other members, but will be in the middle of moving for the next month. Toast did it originally so if you can't wait, check out his post:
Post 3357 |
#3923 | |
Drives: Subaru 2020 BRZ
Installation was very easy. With the help of my daughter we put it on in a little over 1 hour. Make sure you buy the tool to remove the exhaust from the rubber hangers it makes installation much easier. |
#3924 | |
Drives: 2013 frs raven
#3925 |
maybe $50, trying to get a hold on someone with some good finishing skills. already have the plans made out. Comes with all fittings and hoses needed.
#3926 |
#3927 |
Drives: 13' white out frs
Would I need to get it retuned? If not add me to the list as well
Sent from my SM-N975U using Tapatalk |
#3928 |
Drives: SWP BRZ
I am in interested in buying this kit
i already have full bolts from header to exhaust (Tomei, OP,FP, Q300) i currently have OFT but i can switch to ECUTek which most tuners prefers. my question is i buy i with without tune or with tune? i think with tune is correct answer but i want to check. |
#3929 | |
#3930 |
It shouldn't require a retune unless its already off a bit.
#3931 |
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
I am also in for this, add me to the list as well, please. I am in no rush, the BRZ is going under the knife for a solid 4-5 months coming up to get ready for next year
#3932 |
I've got it out for CNC machining quotes today and some small revisions to 3d print/fit.
#3933 |
Drives: 2016 Scion FRS Halo
#3934 |
Drives: '14 Ultramarine Fr-S
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
