#393 |
Drives: GT86
The OE port injectors flow around 200cc/min @ 3 bar. This equates to approx 170bhp on petrol, or considerably less on E85.
I wonder if anyone has flow tested the DI system yet to truly understand the limits? |
#394 |
Drives: Raven M/T FR-S
Easily an extra 30whp when paired with the unicorn.
#395 | |
Drives: 2013 SWP BRZ
I was joking a little bit there. If you don't know what you are buying, you shouldn't be buying it or even modifying a car. |
#396 |
@moto-mike found several spots where the injectors were at 100% duty cycle when running E85. That's enough for me to invest the $300 and swap injectors.
I'm not sure if there are other ways to alleviate max duty cycle but if injectors can fix it, well it's an easy swap. I'm assuming when people upgrade to the intercooler and higher boost pulley they will need injectors on pump too.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#397 | |
Just making a point that theres a lot of information being thrown around. |
#398 |
#399 |
Drives: American Made Shift!
55-210-070213-0010
#400 |
Done
Drives: WRB BRZ
S5-210-180213-0025
#401 | |
Drives: 2013 Asphalt FRS
![]() p.s this is obv with the innovate twin screw of god!
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#402 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
#403 |
Corner Junkie
@DarrenDriven
Just dug out the blower to get the SN. Seems I managed to get an early build: S5-210-080213-0003 |
#404 |
This may make me drop E85 completely.... Looking for owner/shop expeirence answer though.
2013 Sion FRS
#405 |
Drives: 2013 White Out FR-S
ok ill help you guys out the stop system ive had give out around 280whp with injectors in i have the pump lose flow at 290whp. this was on 93 octane. if you factor in the 30% increase in fuel needed the injectors only will cause fueling issues without the pump on e85 at lower hp levels. you can try to lean on the DI system to help but you wont get far. I dont understand why its the innovate guys that seemed to be the most concerned about blowing an engine compared to the turbo/vortech guys but are the most resistant to not want to upgrade the fuel system. Nick lemme know i have pump and injectors instock.
#406 |
Drives: 2013 Black FR-S
Robispec is leaning on the DI with a deutswerks pump and is probably around 280 whp on a dynojet. When I asked him if he and his tuner thought that was safe or a good idea he said that it was and that you wanna rely on the DI as much as possible before having to go to the ports.
There are two sides of the coin I guess.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
