Old 09-28-2017, 07:59 PM   #4159
@milanojess there should have been instructions specific to the oil cooler installation, but it does assume you already have the SC installed.
As always, don't hesitate to reach out if you need support.
Old 09-28-2017, 08:38 PM   #4160
milanojess
milanojess's Avatar
Drives: 2013 FRS
hey Mike, yes there was separate manual assuming pre-existing installation of JRSC.
What I tried to point out is that it would be nice to have install instructions where cooler and SC kit are installed at same time, save some guesses
it's more of a wishlist for the next person in line doing the installs
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 09-29-2017, 08:32 PM   #4161
ozone42
Drives: SSM BRZ Limited
Originally Posted by ozone42 View Post
Confirmed the bypass valve is not closing. Have one of the alternative aluminum ones mentioned earlier on in the thread enroute.
new bypass valve is on... and everything is fixed.
This is the one I bought https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
No idea if the spring is similar, but it does work and solved my wonkiness and leak. Back to having a single woosh when it activates vs the weird sputter/cough I was having.
ozone42 is offline   Reply With Quote
Old 09-29-2017, 08:36 PM   #4162
ozone42
Originally Posted by milanojess View Post
Question:
1. Do all of you with FI still drop the car off at dealer for maintenances and oil changes? do they make your life difficult seeing after market stuff?
2. Is CARB sticker required in the engine bay? What would be the preferred location for it? or can I just keep it in the glove compartment with registration?
I'm in Austin, TX. We have emissions testing, and they hook up to the computer to check things. Got inspected a month after putting it on, passed with flying colors. Don't have the carb sticker on, but do have it in the glove box just in case (they didn't ask.)
This particular inspection place has given me hell before trying to get a salvaged 1996 f150 to pass.
Old 10-03-2017, 02:55 PM   #4163
mrg666
pessimistic skeptic
mrg666's Avatar
For the record, RKX diverter valve also works. I am using it now instead of the plastic I have received with the kit. I have installed with the red spring which is good up to 17psi.
Old 10-04-2017, 09:11 PM   #4164
mrg666
pessimistic skeptic
mrg666's Avatar
Installed a Cusco catch can and an STI PCV valve. I have installed the STI PCV valve on the intake manifold hose in place of the plastic check valve that came with the JRSC kit which was soaked in oil and leaking air out from the intake manifold. I left the stock PCV valve in place. Hopefully no more oil will be blowing into the intake manifold anymore.
Old 10-04-2017, 09:22 PM   #4165
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Quick question — how often are you finding that you need to add oil to the rotrex reservoir? I can’t locate any visible leaks but it seems like every time I check the oil after a couple months it’s at the “min” mark.
keithr is offline   Reply With Quote
Old 10-04-2017, 09:50 PM   #4166
mrg666
pessimistic skeptic
mrg666's Avatar
I check about once a month and never needed to add Rotrex traction fluid in the last four-
five months.
Old 10-04-2017, 11:00 PM   #4167
keithr
keithr's Avatar
five months.
I’m at about 20,000 miles and right at 2 years with the current rotrex. My first one failed. I just bought the stuff to change the rotrex oil, but I’m driving to San Diego tomorrow so I was checking fluids today. I just topped it off not that long ago and I was at “min” again today. I was surprised to learn that the thing loses oil in the first place, but this seems like a lot. I have looked every line over multiple times and I can’t find any evidence of a leak but I don’t know where this oil is going. The rotrex fluid ain’t exactly cheap.
Old 10-04-2017, 11:06 PM   #4168
You do lose a little bit to evaporation; you're out in Arizona so it's more possible for you than for others.
Also remember that the fluid is highly temperature sensitive, and expands quite a bit when hot, so over-filling can result in overflowing out the reservoir.
The reservoir is not sealed; it is intentional, so the fluid can expand and contract.
Old 10-04-2017, 11:24 PM   #4169
keithr
keithr's Avatar
I understand... it’s a bit disconcerting to always find it at “min” though and I’m not sure how often I’m going to have to keep adding oil to keep it in the middle of the range.
Old 10-05-2017, 12:09 AM   #4170
SoCalArgento
Drives: 2014 Argento FRS
Does it keep going down to “minimum” even when you look at it right after driving when temps are hot?
SoCalArgento is offline   Reply With Quote
Old 10-05-2017, 12:23 AM   #4171
keithr
keithr's Avatar
Yep... I follow the procedure by the book. Full operating temp after driving, hold rpm at 2000-2500 for one minute, back to idle and check the level.
Old 10-05-2017, 12:37 AM   #4172
gtengr
Drives: 2017 BRZ
Have you checked the rotrex oil cooling system? I don't know how exposed that stuff is but maybe something kicked up and made a pin hole in the radiator or something.
gtengr is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
