Old 06-09-2017, 03:39 PM   #29
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Here are my Konig Hypergrams 16.8lbs. Also Hankook Evo2 tires stock size weight 19.3 lbs! People forget tire weight is more important being farthest on the outside. Went with this setup for lightweight performance over stanced oversized look. I went big with my Vette as its easier to make power on the ls motors. I'd only do big wheels and BBK on this car if I went forced induction.
Also did lightweight pulleys at the same time and waited to drive until they were on the same time. Man it pulls so much quicker and the revs climb faster!
Enjoy!
SuperTom is offline   Reply With Quote
Old 06-09-2017, 08:38 PM   #30
DaveyBonesJones
Drives: 2013 Scion FRS
Damn!!! Want to wrap my interior?! looking awesome!
DaveyBonesJones is offline   Reply With Quote
Old 06-09-2017, 10:37 PM   #31
SuperTom
SuperTom's Avatar
Thanks kinda interior burned out spending 3 years on the vette and my first week of ownership on the 86. Of course if you lived nearby and flashed the cash...
Old 06-11-2017, 11:39 PM   #32
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
very nice, I really like this build. Both the alcantara and trim wrapping are a really nice touch. Makes me consider doing it to my car.
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 06-17-2017, 05:30 PM   #33
SuperTom
SuperTom's Avatar
OK I will chalk this up as a lesson learned you get what you pay for. The GodSnow crank pulley has not worked out for me. I was starting to wobble at idle. Ive read just about every thread on what could be wrong . I ordered new crank bolt and oil seal to make sure. Torqued it just like instructions 14.5 ftlbs then another 90 degrees. Still same results.
During my initial install I know the crank end part slid out maybe a 1/4" and I slid it right back in. But became paranoid after reading it cant move at all. Marked its location and bravely removed it to check for burrs. Everything looked great and I slid right back in.
Measured the thickness of both the godsnow and stock pulley. It appears the godsnow is about 2mm thinner on the mounting area which probably caused some space between the pulley and bolt.
Anyways put back on the stock pulley and everything is normal again. Going to fork up the bucks and get something proven like a Perrin. The other 2 pulleys (alt,water) Godsnow are fine and going to keep them.
Old 06-30-2017, 10:24 PM   #34
SuperTom
SuperTom's Avatar
Here is my '17 specific perrin tube installed. Its close to the belt even with me pulling away while tightening down. over 200+ miles with no issues. Does a much better job sealing with the front bumper area.
Old generic intake
New Perrin
Old 06-30-2017, 10:25 PM   #35
SuperTom
SuperTom's Avatar
well got my used raceeng pulley in for $50 bucks. Everything works now and the shade of red matches up with the godSnow pulleys that I kept !
Old 07-04-2017, 09:59 PM   #36
SuperTom
SuperTom's Avatar
Gent5 UEL
Just wanted to add the pics from my Gent5 UEL header install here:
Here is a review of the Gent5 UEL header + Overpipe found on FRSport.
http://www.frsport.com/Gent5-G1112-G...p_1478692.html
Waiting for the UPS man today got a head start taking off the stock headers and taking some measurements and weigths
First wanted to measure the inside diameter of the overpipe and secondary.
Looks to be 50mm inside or slightly less that 2" WEAK!
Weights
headers 20.8 lbs
overpipe 4.6lbs
Then ordered my own heatshield stuff to cover oil pan near the header. Got some OCD and covered some areas of the engine too!
Old 07-04-2017, 10:01 PM   #37
SuperTom
SuperTom's Avatar
Really Nice looking welds
Best pic I could get of the Merge collector looks real clean and smooth
Then took some weights
Headers 15lbs
Over pipe 3.5 lbs and the overpipe looks nice as well
Inside Diameter of the overpipe and end of the header flange 58mm or about 2.25"
Only minor thing was one small section of the flanged wasn't machined the same but the area was still smooth and flat with the rest of the flange otherwise these are 99% perfect
More OCD kicked in And I always cover any flange, seal or gasket with a layer of Acousti Seal which is a tar like stuff. Wanted to extra seal the connecting pipes
These were sealed very nice from the factory was able to get them apart about a 1/2" which was good enough to get some tar on
All back together and cleaned up. A lot of tar got pushed out telling me the stock seal is very precise.
Stay Tuned Sunday for my install!
Old 07-04-2017, 10:02 PM   #38
SuperTom
SuperTom's Avatar
Installed this morning man this was the easiest header install Ive ever done. Didn't even need swivel attachments like others have said.
Here are the Siruda gaskets which can be purchased with the headers
The went to coating every flange with Acousti-Seal. Man I really love this stuff for making a sound/airproof seal, just wear some gloves because it can get messy.
Installed the overpipe first. Couldn't imagine installing an overpipe with the headers still on the car
Bad pic but loosened the bottom bolt of the stock cat pipe to have some play with the overpipe to rear cat connection.
All buttoned up everything fit perfect
Plenty of space between the overpipe and suspension. I had added a layer of the insulation on the suspension incase it was close. Not the case had a good finger gap.
Final Top down view
Sound - don't have a good setup to record yet but there are plenty of clips of UEL headers with stock midpipe and catback on youtube.
First cold startup I thought man that's loud but not the case at all. Even without a cat this sounds quiet with the rest of the stock exhaust with a slight change to the rumble.
I could defineantly upgrade to a highflow cat and a more flowing catback but I would still go with something on the quieter scale
Power- NO tune yet but that delay in the middle rpms seems gone. Accelerated more linear. Cant wait to feel what a tune will do. Plus eliminating that cold start non-sense will be on my list.
Also the Blox CEL eliminator seems to be working so far with 100 miles driven we'll see. Time to drive again!
Old 07-15-2017, 08:09 PM   #39
SuperTom
SuperTom's Avatar
HKS Dual Resonated frontpipe with HKS Legamax premium
I will be installing this weekend but here are some preliminary pics.
BIG box
Packaging was great as to not get hurt in transport.
Hard to see from the pic but the outsite diameter is 60mm claimed. Measured inside diameter is 56mm consistent all the front pipe and rear exhaust. Was hoping it would be exact match to the end of my overpipe which is 58mm inside diameter. Again at least its consistent all the way through to keep velocity high.
Here are the weights (my cat likes to be in every damn picture) :
Dual resonated Front Pipe - 8.25lbs
Midpipe - 13.25 lbs
axleback - 24.75
So the front should be about 2lbs lighter than stock and the total catback about the same as stock
Nicely polished really like the big tips on this
CON: I'm going to say this but the welds do not look clean especially compared to my no name(gruppe-s/ gent5) Uel headers. They are thick and lumpy but hopefully should hold up well. You can see where they burn through to the inner pipe on a few and will need to be grinded smooth
Explains why the price is nearly cut in half, A nice system if you don't look at the welds. But overall I'm very excited to hear this car roar with this setup. Stay tuned
Old 07-15-2017, 08:42 PM   #40
SuperTom
SuperTom's Avatar
Started off this morning removing and weighting the stock parts
Front pipe: 12.1lbs
Midpipe: 12.5lbs
Axleback : 26.75lbs
So Final weight Tally
HKS vs Stock Frontpipe: 8.25 vs 12.1
Midpipe: 13.25 vs 12.75
axleback: 24.75 vs 26.75
Total loss with HKS setup: 46.25 vs 51.6 = -5.35lbs
Spent some time with a harborfrieght die grinder to grind down the inside of the welds smooth
Easy Job used my tar stuff again on the gaskets and bolted everything on. Just match the direction of the flanges exact and everything fit perfect first time! Fitment gets A+
Cat Strikes again photobombing me
Nice tips fill the hole
Sound: again I wish I could set something up for clips that will come later
Its very Jeckly/Hyde in a good way. Obviously cold start is loud. While cruising the exhaust is very quiet close to stock. Put you foot into and WHAM the sound volume jump up quickly. Not too low bassy, no drone, more on the higher pitched scale but without the rasp. So flooring its pretty loud enough for me but no annoying sounds just a straight wail.
Old 07-18-2017, 04:52 PM   #41
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Your level of detail is amazing. OCD or not, I'm sure it pays off.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 07-18-2017, 05:17 PM   #42
SuperTom
SuperTom's Avatar
In the past ive half-assed projects to rush because I needed my car. Having a three car rotation allows me to take my time. Plus hopefully the detail will help someone out.
I would recommend to anyone to at least get a beater car in your stable. I pay $40 a month insurance for my old Cherokee. Now I can take my time on projects and do them right.
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
