Old 07-23-2020, 04:53 PM   #29
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If you had to prescribe one platform or the other to an 18 year old who loves Californian YouTubers, has 6 figure budget and wants 750whp with hellaflush, which would you pick?
Old 07-23-2020, 05:19 PM   #30
Originally Posted by konohateo View Post
Would the stock exhaust system (with cat deleted ) of the brz affect much in terms of both performance and reliability standpoint?
With a tune, it would gain some power. Zero reliability impact with a good tune.
Old 07-23-2020, 05:20 PM   #31
Originally Posted by mistople View Post
Which car is more fun to drive and why?
The Supra is more lively
Old 07-23-2020, 05:21 PM   #32
Originally Posted by EAGLE5 View Post
Thanks for the answer, Mike. A90, yes. Hiw about cruising in 8th then drop the hammer. Already having shifted to 4th doesn't count. I want to know response from off boost and off gear since that's where I am most of the time on the street. I read the transmission can shift from 8th to 4th no problem. 200ms, but then that will probably delay building boost even more. Responsiveness compared to an EV is what I care about.
By the time the downshift has happened, boost is already at full.
Yes, the trans can and will skip gears.
Cruising in 8th is still within spool window; I can have full boost at ~1800 rpm, even with my increased power.
Old 07-23-2020, 05:23 PM   #33
Stock top gear 50 to 70 is 2.8 seconds. Model y is 2 seconds. Do mods knock a half second off that, or is it a lot of shift time?
Not an accurate comparison. The Model Y has a top speed on 135mph with 1 gear.
That would be equivalent to approximately 5th gear in the supra, but lets use 6th for posterity.
My 60-80 time in 5th gear only is ~1.4s, and 6th gear only ~1.65s. I've not tried 50-70.
Old 07-23-2020, 05:23 PM   #34
a MKIV Supra.
Old 07-24-2020, 04:33 AM   #35
konohateo
Drives: Subaru Brz
Even if it's turbocharged ? Does the stock system with cat deleted be efficient enough not to cause any reliability issue as well ?
konohateo is offline   Reply With Quote
Old 07-24-2020, 12:42 PM   #36
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Any rattles or creaks in the Supra? The BRZ/86 don't have the highest quality interior so you'll be in for an endless journey trying to track down every noise.
Is the wind buffeting fixed when driving with the windows down on the Supra?
Clueless
YamahaR86 is offline   Reply With Quote
Old 07-24-2020, 08:51 PM   #37
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Which car does you wife bitch less about while riding shotgun?
Old 07-24-2020, 10:09 PM   #38
Responsibly build, with a reasonable amount of power? yes, reliable.
Old 07-24-2020, 10:10 PM   #39
Zero noises.
Buffeting is a fact of life.
Old 07-24-2020, 10:10 PM   #40
This is why I'm not married.
Old 07-25-2020, 04:49 PM   #41
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Are you sure that's the only reason?
Old 07-27-2020, 11:47 AM   #42
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Thoughts on the exterior bits intended to fix it?
https://www.supramkv.com/threads/any...ting-fix.5102/
Vaping in cars+other vape related Packofcrows Off-Topic Lounge [WARNING: NO POLITICS] 22 07-09-2015 02:33 PM
New 97 non turbo supra front rotors x 2 njccmd2002 Miscellaneous 0 08-07-2013 10:55 PM
Toyota 86 GT & Single Turbo Supra Shoot :) RZ86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 08-13-2012 03:32 AM
