Old 09-30-2020, 09:12 PM   #29
ls1ac
ls1ac's Avatar
I know that some cars will through a code that can not be cleared with anything but the tech unit at the dealership. (ask me how i know). I even got the dreaded count down until engine stop.
I had problems that the dealer had to fix as it was part of the emissions. Check to see if their messing with the emissions codes will still make them responsible.
Call national number for manufacturer information.
Old 09-30-2020, 09:25 PM   #30
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Originally Posted by RZNT4R View Post
And those "good ol' cars", when they were still going, pissed oil like baskets and delighted the enthusiast with steering and suspension tolerances rivaled only by the horse drawn carriage.
Yep. The SS was a fun car at the time, but the cam gear had plastic teeth on aluminium body that shredded every 40k miles or so (I replaced it twice), water pumps had half lives measured in months, as did control arm bushings, it was incredibly heavy, and the 350 horse 396ci engine was probably good for 275 - 300 most of the time. However, it didn't leak oil, just drank gas by the supertanker full. Looking down the carb throats and blipping the throttle looked like a toilet flushing. I sold it during the 73 oil crisis.
I much prefer my BRZ for all the reasons you mention and more.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 10-01-2020, 01:40 AM   #31
mo4sho
Drives: Toyota
Still a ridiculous answer and a ridiculous price - Oh wait, I would assume this is covered under the extended warranty?
But still, that's blasting a mouse with a blunderbuss. Honestly I would assume the issue to be in the evap pump module, it's a little black box clipped to the vent filter BESIDES the charcoal canister... they're probably trying to nuke the problem from orbit with an all new EVAP system.
So kind of ridiculous.
[edit]
Further, I presume that price is the overall bill, I just remembered the canister pump module is above the rear subframe lol, so they're probably laying on a bit of time for a rear subframe R&R
Unfortunately the charcoal canister is not part of the powertrain....so I haven't had the work done yet. ~$2500 is a bit tough to swallow
mo4sho is offline   Reply With Quote
Old 10-01-2020, 05:41 AM   #32
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Oh crap, that extended warranty is just powertrain? Fuuuuuuuu
Get that car to an independant shop asap.
Old 12-06-2020, 02:39 PM   #33
mo4sho
Drives: Toyota
In case anyone was still following this thread, it was not actually an ECU or even charcoal canister issue.
It was an loose wire issue, that they ended up covering for me under the warranty so the car now runs great!
Thanks for all the input, this thread can be locked/closed
brz, check engine light, ecm, evap, help needed
check engine comes on and off Chefboyarmin Issues | Warranty | Recalls / TSB 5 10-10-2017 05:29 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
