Old 04-17-2023, 11:14 AM   #29
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
My track wheels were PF01s. Were great, cleared BBK easily, light weight, reasonable cost, never bent even with a few spin offs and street driving in NYC, and look simple and clean IMO. It’s actually the only thing I have left from my BRZ, I just couldn’t part with them.
Glad to hear this. I just took delivery of a set to run as my autocross wheels. I found good reviews other places, but it's always good to hear more.
Desertnate is offline   Reply With Quote
Old 04-17-2023, 01:19 PM   #30
fryfun
Drives: 2014 Subaru BRZ DGM Limited
Bought the car with Konig Hypergram shoes on. 18x8.5+38 I believe. Light and strong, no complaints so far, which prevents me from buying the SSR GTX03 for 3 years now.
fryfun is offline   Reply With Quote
Old 04-17-2023, 04:57 PM   #31
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
So instead of a spreadsheet, which can get out of hand fairly quickly, I started writing a web app. My day job is working with React, so why not
https://wheels.ft86partpicker.com
Only a few wheels to get the design thought out. I'll add more over time. The www site is a much older, but maybe still relevant with a list of basic parts.
Mike
mike_ekim1024 is offline   Reply With Quote
Old 04-19-2023, 06:50 PM   #32
mike_ekim1024
Doing more research, WORK Emotion ZR10 is listed as "1 Piece / WORK Flowforming Technology (WFT)". I don't see any other Emotion products listed with WFT, but I feel there could be?
https://www.workwheelsusa.com/product/emotion-zr10
It's difficult to find weight information for this wheel other than it is "lightweight"
Old 04-20-2023, 03:20 AM   #33
mike_ekim1024
Another flow-formed wheel, but I’m not familiar with the brand:
https://neuspeedrswheels.com/product...31935766528113
At $380 / wheel (18x8.5), they’re in the mid-range of flow-formed wheels.
Old 04-20-2023, 10:10 AM   #34
Racecomp Engineering
BRAID Fullrace A. Made to order, essentially any size and offset. Not super light, priority is strength but they're commonly used in motorsport. I use them and like them.
- Andrew
Old 04-20-2023, 10:25 AM   #35
Desertnate
Spelling Impaired
They are fairly popular in some German car circles from what I remember. Only heard good things about them.
Old 04-20-2023, 11:07 AM   #36
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Yes - Neuspeed is a very popular VW/Audi tuner that's been around for decades. Problem with the wheels for our platform is that the center bore is wrong (57.1mm for the wheels vs. 56.1mm for our cars), and you can't get a hubcentric ring to fit because the difference is so small.
EDIT: I guess since back in the day when I was a VW guy, Neuspeed has added products for BMW, Fiat, Mini and Porsche as well.
Tatsu333 is offline   Reply With Quote
Old 04-20-2023, 01:54 PM   #37
mike_ekim1024
There’s some conflicting info about hub-centric rings, but I believe this post the most, that they don’t carry any load, but do help make sure the wheel is centered.
https://www.ft86club.com/forums/show...57&postcount=7
I do see Neuspeed wheels in the wheel directory:
https://www.ft86club.com/forums/showthread.php?t=18732
Old 04-20-2023, 04:32 PM   #38
Tatsu333
That's correct - they are for centering only. That's why plastic hubcentric rings are viable.
I'd say it's near-zero possibility that you can get 0.5mm thick hubcentric rings to bridge the 1mm difference in center bore, so you'd be chancing slight mis-centering with these wheels every time you fit them. That said, if the bolt holes are tapered, then the lug nuts will do their own bit of centering, so it *could* be just fine...
Old 04-20-2023, 04:46 PM   #39
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That post is pretty spot on. I personally have never run them, though the Arc-8's are hubcentric already without rings. 57DR's are loosey goosey on the hub.
Old 04-21-2023, 12:56 AM   #40
mike_ekim1024
- Andrew
"These wheels are manufactured using the very latest in full flowcast technology which allows a more uniform arrangement of the alloy structure and granularity greatly increasing the wheel's final characteristics. The result is a lighter and stiffer wheel with much improved strength both in terms of bending and cracking."
A little pricey, but they sound like super tough wheels and the weight is not bad at 20.3 lbs for 18x8, in line with the other flow-formed wheel brands.
One thing that is hard to convey is strength. Well, without buying some and running some torture tests
Old 04-21-2023, 07:46 PM   #41
mike_ekim1024
Added load rating to the specs on https://wheels.ft86partpicker.com, as well as a few more wheels. With some wheels, it's difficult to find the rating, even with brands such as WedsSport (found the TC105X but not the SA-75R).
In general, 1500 lbs seems to be the high end with these collection of wheels, with some lower such as 1190 lbs for the Konig Rennform. I wonder if load rating include sideways forces such as when hard cornering?
https://www.ft86club.com/forums/showthread.php?t=32942
Old 04-21-2023, 08:50 PM   #42
Kaotic Lazagna
Drives: GR Corolla
I bought the ZR10! Granted, they're not for the twins since I no longer have one.
18x9.5, ET38 for the set I got.
FS 18x8.5 Forgestar CF5 Gunmetal Rotary Forged Wheels FRS BRZ RWDRIFT Wheels and Tires 9 10-10-2013 09:44 PM
MTechnica multipiece rotary forged line-up eight08customs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-17-2012 12:56 AM
** New TSW Panorama rotary forged wheels speed depot Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-02-2012 12:20 PM
TSW Nurburgring Rotary Forged Wheels Eric@GetYourWheels Wheels and Tires 6 08-01-2012 01:19 PM
TSW Interlagos Rotary Forged Wheels Eric@GetYourWheels Wheels and Tires 9 08-01-2012 01:15 PM
