Old 10-26-2012, 03:08 PM   #29
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
Originally Posted by celica73 View Post
Are the rear shocks adjustable (on the car)? I don't see an adjuster anywhere.
Yes, the rears are adjustable. We are using Koni single adjustable shocks on the FRS/BRZ.
GC_Adam is offline   Reply With Quote
Old 10-26-2012, 03:11 PM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by GC_Adam View Post
Yes, the rears are adjustable. We are using Koni 30 Series single adjustable shocks on the FRS/BRZ.
Spring off for adjustment (button like a normal series 30)?? Can you modify them to be externally adjustable as an option?
I love this stuff! If I wasn't going with another vendor/ITR Expo Sponsor I'd be ordering this setup.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2012, 03:15 PM   #31
CBR600RR
Drives: Raven Black
So if I use the GC set up on my stock shocks - what is the min and max lowering capability?
I would hope something like: OEM ride hight to 2" drop. (good for winter and summer)
Old 10-26-2012, 03:16 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by CBR600RR View Post
how much is this?
$2,200 list based on their website, without any extra charge options (custom colors, double adjustable front strut, koni race front strut instead of sport, etc). Maybe a charge for custom rates (back in the day it was an upcharge, not sure about that anymore).
http://www.ground-control-store.com/.../II=925/CA=205
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2012, 03:17 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
2" drop is massive unless you run larger diameter tires, I'm running slightly shorter with Eibach Sportline's (~1.4") and much lower and it would be too low. Now if you ran larger diameter tires I could see it since you'd gain some back in the tire height.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2012, 03:22 PM   #34
CBR600RR
Drives: Raven Black
I agree 2" is a LOT.. but thaving the extra range would be nice - I'd likely not drop much more than 1" (my drive way is kinda steep)
what is most important is the ability to run OEM hight for winter driving.
Old 10-26-2012, 03:40 PM   #35
GC_Adam
GC_Adam's Avatar
All of our kits/systems are height adjustable so for those of you that are concerned about winter ride height you can return your back to stock with in a short amount of time.
Old 10-26-2012, 04:16 PM   #36
Mechazawa
Drives: FR-S, 6MT, White
Thank you Adam, looks like a good value when you factor in the super cool camber plates and the bling bling STB. More questions.
Will these leave the springs uncompressed at full droop like my old GC setup on the bimmer did? If so can that be addressed with some helper springs? and at what cost?
Also, do the provided strut housings still permit the use of "crash bolts"?
Weight of all the parts would be nice too?
Do you feel like the STB serves a useful purpose in this application? Some may want to skip it to save a few pounds and a few bucks, or because it doesn't clear an innovate (still a little shocked myself) supercharger.
Mechazawa is offline   Reply With Quote
Old 10-26-2012, 05:22 PM   #37
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Very interesting, I have had good luck with GC stuff in the past myself.
mines13 is offline   Reply With Quote
Old 10-26-2012, 09:07 PM   #38
GC_Adam
GC_Adam's Avatar
Mechazawa,
1. Yes, When at full droop the springs will be uncompressed, but this is generally not a problem when the vehicle is on the ground. You do have the option (at an additional charge) of using a "helper spring" setup.
2. Yes ,our strut housings do allow the use of the factory "crash bolt".
3. The weight difference between a factory strut mount/upper spring perch and our camber plate/spring perch is about .25 #. The stress bar weights in at less then 4 pounds.
4. Our stress bar is designed with function in mind. The farther the strut towers are away from the firewall, the more flex you are going to experience in the engine bay. Our bar is significantly more robust than any other bar we've seen on the market.
Old 10-26-2012, 11:09 PM   #39
Mechazawa
I have to admit, I'm so impressed with the engineering that I'm tempted to spring (no pun intended) for the whole package, even though it's absolute overkill for my daily driver.
Old 10-26-2012, 11:18 PM   #40
gmookher
spring rates?
gmookher is offline   Reply With Quote
Old 10-27-2012, 12:05 AM   #41
mines13
mines13's Avatar
Originally Posted by gmookher View Post
spring rates?
That is the wonderful thing about Ground Control, you can have whatever spring rates you want.
Old 10-27-2012, 12:08 AM   #42
gmookher
how does something like this compare to kw3?
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 08:56 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 06:08 PM
Perils of ground hugging FRiSson Scion FR-S / Toyota 86 GT86 General Forum 21 07-31-2012 11:39 PM
Ground Control is working on some stuff for us :) D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-24-2012 07:21 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
