| Member's Car Journals Car journals by our members. |
#29 |
Drives: 13 Asphalt FRS AT
Nexus 7 Install
I bought a Nexus 7 a few weeks back and have been toying with the idea of mounting it in my FRS. I didn't want anything permanent as I wanted to retain the factory head unit (for now) and also wanted to be able to remove the tablet whenever I wanted so that i could use it for its intended purpose. I searched all around and couldn't really find anything that fit the bill, soo.... I made one.
Parts used: 1. Mountek ngroove CD Slot holder for iPhone (see previous post) 2. Otterbox defender for nexus 7 I disassembled the Mountek, removed the 4 screws holding the actual mount together, drilled 4 holes into the back of the Otterbox cover, secured it with the same 4 screws, and slid it back into the CD Holder. 15 minute job and so far I am happy with the results! I have yet to give it a full roadtest but so far it looks like it may just do the trick! Here are a few pics: I'll update the thread once I have some miles behind me as I haven't fully tested tethering my S3 to it yet, etc... I am hoping I still have enough room behind the Otterbox to manipulate head unit but we shall see...
#30 |
FA20Club.com Header Installation
I installed a new header from @FA20Club.com and am quite pleased with the results!
A few photos... I still need to get one of it installed. Overall very happy with the results. Please note that these are untuned numbers as I am still looking at options for Ecutek (flex tune or just standard 93/E85 map switching). I am sure there is more to squeeze out of this as it's an excellent first step toward FI.
#31 |
Drives: White FR-S, 6M
I appreciate your review of the FA20Club header. I'm seriously considering it as well. I already have his stage 2 tune and highly recommend it to you. I see you are in GA and have made a trip through the Dragon. I have the ECUTek cable if you want to drive up and use it sometime. I live about an hour from the Dragon in the Knoxville, TN area. I got a question, How do you like the header in the low RPMs like off idle to 3k rpm. any driveability loss? Any sacrifices at all with the header?
Thanks, Lane
#32 | |
Sent from my Nexus 7 using Tapatalk 2
#33 |
High Pressure Fuel Pump #3 is now in place. It was quiet on the way home but didn't really heat up much. Time will tell! FA20Club 57 Trim turbo kit has been ordered so in a few weeks or so i should have some additional pics to post up. The first "real" mod...
#34 |
I updated my nexus 7 mount over the weekend. I have been reluctant to completely swap out the head unit as I really like the flexibility of taking the tablet with me to tinker with when I am not driving. I purchased a nexus dock, energizer inverter, and a powered USB hub and went to work... I was looking at ways to mount it and was happy to see it fits perfectly on the lower lip of the bezel. I put the inverter behind the passenger dash bezel and used Velcro to keep it in place. Also stuck the USB hub to the glove box using Velcro and routed all of the cables. I reused part of my mountek CD mount to put a bit of pressure on the tablet to prevent vibration and it works perfectly, even if it does look a little odd. Now to get tasker see up.... I also order an obd2 USB adapter so I can ditch the Bluetooth dongle.
#35 |
Drives: 2013 FRS, 2008 R32
So awesome. I go up to Fontana Village for a huge R32 gathering (just got rid of my R32) every year in April to rip up mountain roads with a bunch of other enthusiasts. Hellbender to the dragon from Fontana is amazing. Cherohala, the same. Love the long sweepers on that road. And the dragon, well, it's the Dragon. You really don't get a chance to get any higher than 3rd. lol.
I've never been there in the fall but according to your pictures, it's amazing. |
#36 |
Long overdue for some updates. I'll start off with the latest mods to my FRS starting with these Grimmspeed Hood Dampers. Well worth the investment for those considering these. Installation was a snap and makes working on the car much easier (don't have to worry about accidentally hitting the prop rod and knocking myself out with the hood).
#37 |
FA20Club Turbo Kit Installation
FA20Club Turbo Kit Installed!!
I can't begin to tell you what a difference this has made in the overall feel of the car. This car needed an extra 100hp at the wheels and this kit delivers exactly that. Mountain Road carving is so much more fun! I am running their Flex Fuel kit along with the turbo and running ethanol adds another 30hp or so to an already strong running car. I have about 7,000 miles on the turbo at this point and no major gripes.Next steps will be adding a Perrin Overpipe (got a deal of a fellow forum member), FA20Club catted front pipe, and recirculating the dump into the downpipe. While the growl this thing emits at WOT with dump to atmosphere is really an attention grabber, it is a bit much for me. FA20Club Turbo Kit Details:
#38 |
Ridge Racerrrrrrrrr
How well does Torque Pro work for monitoring Boost?
#39 |
okay at best. i have noticed a lot of variation between pump gas and e85 and will be replacing it with a proper boost/afr gauge in the new year.
#40 |
Ridge Racerrrrrrrrr
Mmm thanks! I was hoping to save myself some money here and just install a cheap android phone in the car. I would be running only pump gas, so maybe it will be more reliable?
#41 | |
#42 | |
Drives: Subaru BRZ, Nissan 240sx
| GrimmSpeed Engineering's Daily BRZ Journal | GrimmSpeed | Member's Car Journals | 34 | 11-13-2013 10:09 AM |
| Mr. Sociable's BRZ Daily Driver (slow) Build | Mr. Sociable | Member's Car Journals | 23 | 11-01-2012 10:46 AM |
| Jdmitr BRZ Limited journal/build thread | jdmitr | Member's Car Journals | 18 | 10-01-2012 01:50 AM |
| Longo Scion Demo Build Journal - Car arrives next week | xravexboix | Member's Car Journals | 12 | 06-15-2012 01:00 AM |
| The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 02:14 PM |
