Old 11-25-2011, 11:32 PM   #29
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
There is also Big Crank which is Deka battery, Big Crank is cheaper in some places online
http://www.bigcrank.com/models.html
adprokid is offline   Reply With Quote
Old 11-26-2011, 09:14 AM   #30
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
You guys got me wondering if I could use one of these motorcycle batteries for my v6
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 11-26-2011, 10:41 AM   #31
speed-wiz
speed-wiz's Avatar
Drives: MR2
I've used Odyssey batteries for rotary engines, which are not easy to crank.
speed-wiz is offline   Reply With Quote
Old 06-02-2012, 09:50 AM   #32
speed-wiz
speed-wiz's Avatar
Drives: MR2
Has anyone installed an aftermarket battery in their BRZ or FR-S yet?
Old 06-02-2012, 03:11 PM   #33
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
Yup!
Weighs 20.8lbs
Stock weight is 29.6
This battery puts out the same power as the OEM but less reserve.
This is also the size that almost all normal cars in Japan come with.
I had to use post adapters so it fits the terminals.
Ishii
Ishii Motors is offline   Reply With Quote
Old 06-03-2012, 01:32 PM   #34
AzFranz
Az to Nm to Az
AzFranz's Avatar
My thing living in Arizona is not so much the weight savings, but I have had, along with friends, is wet cell batteries leaking from the intense heat an acid blasting your engine bay. A dry cell is what I look for and have always used Optima red tops. never a single problem and they have lasted an average of 4 years in each of my cars in Az. That is West Valley Phoenix...already hit 112 last Friday Phoenix!
My 2 cents...
AzFranz is offline   Reply With Quote
Old 06-03-2012, 01:54 PM   #35
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
I would opt for the Braille battery as well. They have the 4-cylinder special-- an 11lb. battery for around $160. I saw one for 6lb. but i don't know how much i'd trust it; not to mention the cost was about $50 more.
Asterisked Accolade is offline   Reply With Quote
Old 06-03-2012, 05:02 PM   #36
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I've used Braille batteries for a while. My first one was a 17 lb. It was OK at first but you can't forget to leave your lights on for more than 5 minutes or it will not give you enough cranking power to start the engine. I had to jump start it quite a few times - even asking a stranger for help once. In the winter it struggled a bit but never failed to start. And after about 2 years, it would barely hold a charge at all. So I replaced it with the 21 lb model which should have higher reserve capacity. It's fine so far but it seems to dim and whine more when you do two things at once. That could have to do with something else though...
So yeah, I'm not sure if I would use a lightweight battery for this car since I will be getting a touchscreen navigation system and would like to mess around with it a bit sometimes when the engine is off. But as someone else said, I don't like the idea of wet cell batteries. But the Optima's are even heavier than the wet cell batteries. So... I'll just stick with the stock battery until it dies and go from there.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 06-03-2012, 05:55 PM   #37
FT_Monk
Drives: Over the hill WRX
I have used the Deka 15 pound battery in my WRX for more then 4 years. Everyday I listen to the radio for about an hour or more in my lunch break. The Deka has no messy acid leaks like a wet cell battery and 20 pounds lighter as a big bonus.
FT_Monk is offline   Reply With Quote
Old 06-03-2012, 06:29 PM   #38
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
If your battery is too light will it throw off the handling?
For the Cayman R battery, it's centre mounted, so it doesn't really matter.
quik1987 is offline   Reply With Quote
Old 06-03-2012, 06:38 PM   #39
Bristecom
Bristecom's Avatar
The battery is on the right along with the exhaust. So it's already heavier on that side if you don't have a passenger. It will likely improve the balance further (lowers CoG and lessens frontal weight).
Toyota + Subaru =
Old 06-03-2012, 11:39 PM   #40
Asterisked Accolade
Well, my lights are automatic and aren't ever on when the engine isn't running. I could also disconnect the negative every night or something to help it last. I have been doing that with my Celica(non-daily driver). Hopefully i'll have better luck than you had with them. If not, i could always upgrade like you did.
Old 06-04-2012, 01:17 AM   #41
Godzpeed
Drives: Nissan GTR
I've used cheap lightweight batteries and also the porsche lithium battery on my GT3RS. So far, none of the cheap batteries are remotely close in terms of reliability compare to the porsche battery.
Godzpeed is offline   Reply With Quote
Old 06-04-2012, 01:54 AM   #42
Partial Stall
Drives: '13 WRB BRZ
Anyone know the tech specs on the stock panasonic battery?
Partial Stall is offline   Reply With Quote
battery
Aftermarket wheels chopped onto Modellista 86 JDM-dono FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 12-20-2011 05:20 AM
What Aftermarket parts would you like to see for the FT86/FRS mkivalex Scion FR-S / Toyota 86 GT86 General Forum 78 11-14-2011 11:50 AM
Toyota FT-86: a goldmine for aftermarket parts Axel Scion FR-S / Toyota 86 GT86 General Forum 16 12-27-2009 11:16 AM
