#29 |
Drives: 13 FRS
I installed the front and rear Hotchkis sway bars two weeks.
The front has been making noise and I can't seem to figured it out. I'll try this weekend when am back in town.. I can't believe so many people having issues with the sway bars and the whiteline end links.
Current: FRS(Daily), Cayenne(Weekend), 1000RR(Fun), 650Maxim(Fun).
Recently Sold: 13 Boxster(Crash), 08&10 335i, 08 M3, 12 A4, 97 NSX.... |
#30 |
Drives: 2013 Scion FRS 6 Speed Raven Black
Hey guys, to revisit this thread. I have been encountering the clunk with my front eibach sway. I hadn't seen this thread until today. I had been trying to fix it myself and after doing so much I was starting to believe it was my drivers front coilover clunking. Running Fortune Auto Coils. Can you guys confirm that when you go over bumps, when the sway clunks (drivers side only for me) that you can feel the physical clunk. It almost feels like something is loose. Just trying to make sure I'm experiencing the same clunk.
#31 | |
Drives: 2015 FR-S (Halo)
Sent from my HTC One_M8 using Tapatalk
#32 |
Drives: RX8 -> 2013 FRS
Oh holy shit, I have the same issues with these end links. Its driving me crazy. I need to thoroughly inspect to make sure they're not rubbing but im pretty certain concerning mine, the lower endlink keeps knocking against the bar. I am tempted to try the washer trick.
#33 | |
Custom User Title
I've just developed a clunking noise in my front left wheel when taking hard right turns at auto-cross. It also happens when driving 5MPH over a very small bump. I'm hopeful that it's one of these issues (I'm still on stock suspension; I have the TRD springs from the factory because it's an RS1.0) because I have another event tomorrow and really don't want to deal with a second broken race car.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#34 | |
Drives: Scion FR-S (Hot Lava)
With the popping noise up front gone, I now hear a slight sound from the rear that must have been masked before... Oh well, I'll check it out the next time the car is up on jacks, its not nearly as bad as the front was! I'm also on stock suspension otherwise. |
#35 |
I've been having this problem a while. New perrin sway bars on stock end links. Rattled and popped a lot even though it was right. Replaced end links with perrin ones, no more noise.
#36 |
Are these issues just typically found on Whiteline EndLinks? I've been meaning to put Whiteline Front and Rear Adjustable Endlinks with my TRD Swaybars
#37 |
Looks like it had to do with length of endlink and how much mobility they have ie: a ball joint as opposed to a rubber bushing. I imagine any adjustable endlink will be fine
Sent from my SAMSUNG-SGH-I747 using Tapatalk |
#38 |
I was thinking the same as well, but was wondering why no one as issue with the non-adjustable Perrin sets but plenty of issues with the Whitelines adjustability. Apparently the bolts hit the inside too much, but these posts make it seem as if they caused other issues instead.
#39 | |
Drives: FRS
were you able to solve this issue? for others reading, I have the same problem as the above but I am on Tein Flex coilovers with stock swaybars and endlinks.
'14 Scion FRS
Tein Flex TE37 |
#40 |
The sway bar could be binding on the bushing. Jack up the car from the center in the front or back(not on the side), loosen the seat bar bushings and end links, set the wheels down on ramps(or blocks) then tighten bushings and end links. Then drive off ramps. The important part is the car is level with weight on the suspension when you tighten the bushings and links
#41 |
First 86 Driver Baby!
Drives: FR-S, Flex
I just ran across this thread and have a popping noise as well. I have Eibach pro springs and sway bars installed, stock endlinks, for about a year. I started hearing a popping noise when coming to a stop. It would also pop a couple times after I stopped. Any thoughts?
#42 | |
| Tags |
| brace, endlink, suspension, swaybar, whiteline |
| Loud popping in the intake | Yruyur | Engine, Exhaust, Transmission | 72 | 02-22-2015 03:11 PM |
| foot rest popping noise | abutterman | Issues | Warranty | Recalls / TSB | 34 | 02-21-2014 12:56 AM |
| Anyone heard any loud popping? | Kimsey47 | BRZ First-Gen (2012+) — General Topics | 103 | 07-30-2013 10:27 PM |
| BRZ gas pedal popping/squeaking noise | chenshuo | Issues | Warranty | Recalls / TSB | 8 | 05-10-2013 10:52 AM |
| The number 86 popping up everywhere.. | CSSM | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 06-19-2012 12:15 PM |
