#29 |
Drives: Skoda Yeti DSG diesel 4x4
Perhaps back off where they fine tuned it, to a safe level, to allow for differences but still have a decent base map for the set up?
#30 |
Drives: Scion FR-S
As far as I understand it, most tuners are leaving in that "safety margin" out of the gate. Some tunes remove the margin by making the advance multiplier 1, but the stock tune, Visconti's tune, etc leave the multi at 0.7. This means right after reflash, it's only utilizing 70% of the timing advance table. As high load events occur without detonation, it feeds in more advance over time. This is why the stock tune feels so "sloppy" after a reset, soft pedal, etc.
I could be totally wrong, so feel free to correct me here pro's... but if i'm understanding the multiplier right, that safety net should cover discrepancies in vehicle, local octane, etc. |
#31 |
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
#32 |
Drives: 2013 FRS
I'm sure they'd prefer to back off timing a bit before they sent it over. Only other variable would be the Maf calibration for your local area(providing you're using the same exact intake in the first place).
Sent from my SGH-T999 using Tapatalk 2 |
#33 | |
Bob at Drift office showed me quite of different setups which he dynoed so I think figures will be much realistic for comparison on the same dyno
#34 |
Drives: 2013 Scion FRS
#35 | |
WUB WUB
Drives: 2013 Firestorm
wish there was a better way to make even comparisons on different dynos.
#36 |
Drives: Very very slowly
That's a great looking curve after the dip. Nice and smooth, just like all damned torque curves should be. Watch out for the jaggies!
budi |
#37 | |
Drives: FRS :D
HKS has headers with a cat option
Out of the FRS game
#38 |
If there's enough interests, we can build a CATTED Front pipe
#39 |
Drives: BRZ (Satin White Pearl)
So for warranty purposes, after a tune, is there anyway to switch the car back to normal when taking it to the dealership to make it seem as if no modifications were made?
#40 |
Grip>Slip
Yes, just reflash the stock rom. If the dealer REALLY wanted to check for a reflash, they would have to send the ECU back to Toyota or possibly even Denso to prove it. I have never seen them actually do this though.
#41 |
Drives: FR-S 6MT
#42 |
Grip>Slip
Not sure if ECUtek pulls its flash counter from the same location, but I had a flash fail once and after re-installing the ecutek license on the ECU my flashcounter referenced in ProECU was reset as well.
| Have you hit 200whp NA? | empower-auto | Engine, Exhaust, Transmission | 323 | 11-26-2015 08:49 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Cheap Dyno? Sponsored Dyno? | swift996 | Mid-Atlantic | 3 | 02-09-2013 01:29 PM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
