Old 07-29-2013, 10:52 AM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by crook View Post
Im running a turbosmart eboost street and it fits snugly into the little phone holder part under the a/c panel (1/4 din size)
That is where I have my GFB G-Force II EBC placed as well. I just pull it out a little when I need to adjust it.
Old 07-29-2013, 10:54 AM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by Alhammadi View Post
u can add me as well =) tomorrow am gonna update the post and upload dyno chart, my 86 did 289 HP at 7PIS thanx to @FullBlown
Here is the link
http://www.ft86club.com/forums/showthread.php?p=828283
Got you added.
Old 07-30-2013, 12:36 AM   #31
crook
crook's Avatar
Drives: storm black GT
Mine fits pretty snug and don't need to pull out at all (just had to cut into the back of the plastic holder to fit it
crook is offline   Reply With Quote
Old 07-30-2013, 01:32 AM   #32
dabocx
dabocx's Avatar
Drives: Scion FRS
Been waiting for the fuel pump and EBCS from FA20 club for over 2 or 3 weeks now Im just going to order them again from another vendor and start the install this week if my installer is down. Hopefully FA20 club can do the tuning if not ill just see if FBM will be generous enough to throw a wastegate basemap my way.
dabocx is offline   Reply With Quote
Old 07-30-2013, 10:05 AM   #33
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Pm'd
FullBlown is offline   Reply With Quote
Old 07-30-2013, 10:12 AM   #34
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Just for you
http://www.ft86club.com/forums/showthread.php?t=42495
Old 07-30-2013, 10:28 AM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I have the BRZ with the smaller phone holder because of the start button. The GFB is a touch screen top, so I have to pull it out a little to hit the buttons on top. I just drilled a hole for the boost reference tube and wiring to fit through the back of the phone holder.
Old 07-30-2013, 10:43 AM   #36
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I guess ill email one of the tuners on here and see what they say.
The electronic solenoid controlled via the stock ECU is the way to go in my mind. I can't really think of an advantage of the stand-a-lone controller, unless you are tuning your own car, and than at that point you would be able to adjust the solenoid yourself. With the solenoid the car always hits target boost.
1. Ability to cut boost in case of an overboost or other conditions via the ECU. IMO this is much safer than a stand-a-lone controller.
2. Ability to raise boost level via cruise control stalk. I have two maps that I can select. Low boost, wastegate spring 6psi, and high boost 11psi. Super easy to change on the fly, takes about 1.5 seconds. No messing with dials or buttons, no setting gain or boost off of %'s
3. Cost, only $100
4. Simplicity of use, just have the tuner set it, and forget it. If you were going to raise you boost more than you were tuned for originally, you were going to need a re-tune anyway...
No Limit Motorsport is offline   Reply With Quote
Old 07-30-2013, 10:52 AM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My GFB EBC does this as well.
I can raise the boost to any level I want from a touch screen display in the car. I have 6 presets that only take a single button press to cycle through while I have the cruise control turned on.
3. Cost, only $100
Cost was $300, but I get a display that also works as a vacuum/boost gauge and the ability to tune the duty cycle, gain, and sensativity without the need of an EcuTek tuner.
A tune should not just fall apart if you decide to turn up the boost, but I agree that simplicity is probably better for some people.
Can we talk negatives? In order to use EcuTek boost control you have to eliminate the OEM fuel tank vent setup. How about the fact that very few solenoids will work for this setup because you are limited by the fact you are using the OEM fuel tank vent setup to control the EBCS. How about the fact that only a few tuners have actually gotten this to work successfully.
Old 07-30-2013, 10:53 AM   #38
jamesm
i've never had success with electronic boost control of any sort. mbc is far easier to get good results with, in my experience.
are there any downsides to not having the fuel vent setup in place? seems kinda important...
Old 07-30-2013, 11:29 AM   #39
No Limit Motorsport
3. Cost, only $100
Why do you always take such a defensive stance of every mod you do, even when posts aren't directed at you at all? Its good you like your GFB controller and it works for you. I just fear for the many people who have little automotive knowledge, who than turbo their cars, which is somewhat risky in itself if you don't understand the system, than you throw a user adjusted boost controller into the mix....
Not every electronic controller has this feature, and no manual controllers do.
You change you boost while your using cruise control?
Why do you need 6 boost levels? High, med-high, med, med-low, low?
3. Cost, only $100
Cost was $300, but I get a display that also works as a vacuum/boost gauge and the ability to tune the duty cycle, gain, and sensitivity without the need of an EcuTek tuner.
Cool. I guess this is about the cost of a boost gauge + EBCS. Once the boost is set right you shouldn't need to adjust any of those settings though.
There are a lot of people out there who don't have the know how to use an electronic controller, who don't care to know, and will screw there car up by using it improperly. After 10 years in this industry I have seen my fair share blown motors due to lack of knowledge.
This would negatively effect emissions somewhat. Just like removing a catalytic converter. There is something to be said about a plug-n-play installation though.
What electronic MAC solenoid doesn't work with this?
Ones that do... Grimmspeed, Perrin, Cobb, AEM, universal MAC valves. I suggest Grimmspeed, Perrin or Cobb since it has the proper connector already on it.
Who can't get it to work? If they can't, I suggest finding a competent tuner. My tuner had it setup and working with no issues in minutes. It works PERFECT.
One last issue with some (all?) stand-a-lone electronic controllers is they do not have a stored memory built into them, therefore if your battery dies, or you have to disconnect your battery for something, you have to setup your boost controller all over again, more than likely on public roads. With the ECU controlled EBCS the ECU always stores the settings. Than if you throw into the mix an uneducated user who doesn't understand gain and duty cycle %'s it is a recipe for disaster or a trip to someone who knows how to use it.
Old 07-30-2013, 11:41 AM   #40
Sportsguy83
Drives: Limited BRZ
Honest question, is this the only negative? Meaning, eliminating the tank vent will not create additional pressure or make something else fail, or just any other issues?
Old 07-30-2013, 11:47 AM   #41
No Limit Motorsport
People have been eliminating these solenoids on cars for years now without issue. They are there for emissions purposes.
I would never do this setup if it was going to hurt something.
Old 07-30-2013, 11:48 AM   #42
Sportsguy83
Drives: Limited BRZ
I bought it too, waiting to get the tune dialed down to start using it.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
