Old 12-04-2013, 11:51 PM   #29
tonytduc
tonytduc's Avatar
nice
tonytduc is offline
Old 12-04-2013, 11:54 PM   #30
reardrv
Drives: 2013 Subaru BRZ
Say what you want, still crappy welds.
reardrv is offline
Old 12-04-2013, 11:56 PM   #31
twag4
Drives: frs
Why is everyone so rabid to make everything unequal length? Will someone please make equal length?
twag4 is offline
Old 12-05-2013, 12:09 AM   #32
kuhlka
Drives: 2013 BRZ Limited AT
Maybe you're looking for something like this?
Originally Posted by WiebTech Performance View Post
A lot of people are running catless headers without a tune. Although not ideal, it is totally fine. This is an even better option because it is catted. You will see power gains and will not get a CEL because the 02 sensor stays in basically the same-as-stock location. So again, tuneless should be no problem. Obviously to see the biggest gains, a tune is required.
Really looks like a solid product! Great work
If you consider a check engine light and the fueling switching to limp mode 'totally fine', I guess so... O2 spacer didn't work for me. MASSIVE difference with a tune, though. The car runs worlds better than stock.
Not trying to be mean but who is your welder? Those welds look awful.
They actually don't look too bad, considering it wasn't done by a machine (and you don't need to pass QC-7 certification to weld up and exhaust). The fact that they're not flat gray shows the person doing the welding kept the stainless the proper temperature while welding. My only critique is that they made so many short 1" welds and some look a tad concave. Could have probably dialed the pedal down or used pulse to control the heat. This IS a prototype, though, so final quality is TBD...
In a perfect world, they'd also cap off the ends and use backing gas to ensure the backside of the welds aren't oxidized. If you overheat the stainless or don't have gas coverage while welding, it instantly oxidizes and cooks off the stainless elements in the alloy (often nickel and/or chromium).
kuhlka is offline
Old 12-05-2013, 12:14 AM   #33
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Sounds like you had other issues. Ive been running my car with the Revworks UEL for 3 months without issue. The 02 sensor reads that my CAT efficiency is bad, but it sure as hell did not go into limp mode.
The Racers Line is offline
Old 12-05-2013, 12:28 AM   #34
kuhlka
Nope, the O2 sensors just detected that the cat was missing and the O2 didn't look right, so it threw a CEL and put the car into limp mode (CEL lit, no cruise, RICH fueling, soft throttle response). Can't remember the codes off the top of my head.
All is well after Drift-Office tuning. It seems like there is a 50/50 split of people who get no CEL with catless headers and others who do. Considering the added flow of the catless header, it'll be interesting to see how this catted UEL headers compares.
kuhlka is offline
Old 12-05-2013, 12:29 AM   #35
TeamZleep
Drives: 2013 FRS/2011 TDI
As long as this doesn't cost an arm and a leg... This is what I've been waiting for.
TeamZleep is offline
Old 12-05-2013, 02:36 AM   #36
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
am I the only one who has had no issues running the Borla UEL? I don't get the cel just really loud.
HI is offline
Old 12-05-2013, 02:52 AM   #37
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I personally won't run headers without a tune...not only is there possible fueling issues but most of the power comes from the tune.
Not a fan of catted or weld quality.
We'll see what kind of numbers can be had and if the production version has good welds.
Good luck. Nice to see more options.
GR86 MT premium
StormTrooper is offline
Old 12-05-2013, 04:48 AM   #38
Fast_Freddy
Drives: Passat
Originally Posted by CodyFRS View Post
WHY DID I BUY BORLA?!?!?!?!?!?!?!?!
Best available at the time? Sounds great? Eliminates the TQ dip? Makes very good power? Unmatched warranty support?
Don't kid yourself that any catted header is going to make the same power as un-catted. There are many reasons to choose one over the other but the reasons aren't the same. It's almost apples to oranges.
Not even close! There are far more people happily running the Borla UEL than there are trolls complaining about it. It just doesn't appear that way on this forum because the Borla hating trolls post far more often.
Fast_Freddy is offline
Old 12-05-2013, 10:41 AM   #39
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
I'm also running Borla UEL's with no tune and I have zero issues, just very loud as well.
CodyFRS is offline
Old 12-05-2013, 10:49 AM   #40
FR-S Matt
You should always tune a car with a performance header. A stock tuned car doesn't really know how to adjust properly to the flow change with just a spacer. Rather than attempting to trick the ECU, which doesn't work 100% of the time, get it tuned and eliminate the risk from the start. You'll be much happier you went that route.
The right runner doesn't look very short either. Do you guys expect a mild boxer rumble vs the other UEL's due to that?
FR-S Matt is offline
Old 12-05-2013, 11:19 AM   #41
GremlinGSP
Looks good guys. Keep up the good work.
GremlinGSP is offline
Old 12-05-2013, 11:52 AM   #42
brillo
Drives: 2013 Firestorm FR-S
Please dyno the car with a stock exhaust and a tune. I think this will show the best "bang for your buck" results in terms of dollars as the catback exhaust gains are relatively minor compared to the gains from a header and the associated tune.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
