#29 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Is there I way to seal the AN fitting fittings with so type tread sealer or something? I'm having issues with my fittings as well, very minimal but noticeable.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#31 |
Drives: 2015 Raven FRS
#32 |
#33 |
Drives: 10 Series #2435
Hey guys so this thread has been inactive since october of last year so sorry for the necro but I had a couple questions. I recently bought and installed the kit and it's great! but i've been having some leaking issues recently. Im pretty sure it's the o-ring on the sandwich plate which has gone bad due to the amount of times I've taken it on and off to try to diagnose my small leaks :/ So I was curious if one of you guys could supply me with the specifications on the o-ring so I could order the proper replacement? Also how in the hell did you guys tighten the sandwich bolt correctly? I cant for the life of me find a socket that fits between the tstat and the head of the bolt. Thanks in advance. -Grant
#34 | |
Carefully use a 12 point 27mm socket for the adapter. |
#35 |
Drives: Scion FR-S
Hi, cannot decide between Perrin and JR OC.
Is it really worth $70? TIA. |
#36 |
For a MUCH larger oil cooler? Absolutely. Too much won't hurt you (thermostatic plate prevents overcooling), but if you're looking for an oil cooler because you drive hard, then too little can hurt you.
#37 |
has anyone noticed any damage to the stock airbox due to the little clearance of the AN fittings? I have probably about 4mm of clearance from the fitting and my stock airbox. I might put some reflective tape on the airbox but I am still monitoring it after every drive to see if it rubs or anything like that.
#38 | ||
Thanks
For me I saw my lines were rubbing on the frame in one spot and the washer bottle. Zip tie the lines together tightly to increase clearance. That stopped my rubbing on the frame but it still touches the washer bottle neck.
#39 |
Drives: 2014 GT86
CSG Mike: but is MUCH larger oil cooler needed? Imho it's not that bad if smaller is sufficient for worst case you can throw it at .. everything above that is redundant and extra deadweight, no?
#40 |
Drives: Scion FR-S
I have TRD CIA. Is it going to interfere with oil filter adapter?
TIA. |
#41 | |
#42 | |
It's less than 3lbs extra. That's less than half a gallon of gas. Unless you're so worried about weight that you only run a quarter tank of fuel or less at all times, this weight won't matter. |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 10:48 AM |
