Old 07-05-2012, 07:41 PM   #29
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Installed a set of these today. You definitely need to push them past where the original bolt was to get them to look correct, IMO.
I pushed them back as far as they could go, and it seemed about right. There are bumps inside the tip to prevent it from going on too far, plus the exhaust starts to bend and prevents the tips from going on further. Still once installed the way I did, they look pretty close to the proper Japanese fitment, about properly flush with the bumper.
I'll post some pics in a bit.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-05-2012, 07:45 PM   #30
ayau
Drives: Some rust bucket
Jeff
what did you do with the stock bolt indents since they didn't line up?
i wonder if those bolt indents were created when they put on the usdm tips at the factory and torqued it enough to create a dent. maybe the usdm muffler is the same as the jdm muffler after all?
Old 07-05-2012, 08:21 PM   #31
Jeff Lange
Jeff Lange's Avatar
I didn't do anything with the original indents. They're still there, being all indented and stuff, lol.
They may have been created at the factory, not sure. The part numbers are still different between the US and Japan exhausts, however that can be for various reasons.
The US exhaust comes with the tips installed when you order it, the Japanese one does not, so that could be the reason for the different part numbers, or it could actually be different in other ways as well. Without having them side by side or taking measurements, it's hard to know.
Jeff
Old 07-05-2012, 08:56 PM   #32
ayau
Jeff
the JDM mid and high spec comes with the tips installed. only the base/stripped spec doesn't have the tips. you can see it on the JDM brz site pictures and spec sheets.
did you put the stock bolts back on anyway? do the bolts stick out a little bit because they don't line up with the stock indents?
please take some pictures for us if you can. if possible, try to take the pictures at an angle to show how far the exhaust sticks out the rear bumper.
edit: one more thing: can you post the part # for the tips?
Old 07-05-2012, 09:50 PM   #33
Jeff Lange
Jeff Lange's Avatar
I was talking about supply parts, not what the cars come with.
If you order an FR-S muffler, it comes with tips installed.
If you order an 86 muffler, it does not come with tips, you have to order them separately.
The bolts are the same for the USDM and JDM tips.
I've posted the part number for the tips before, I'd have to find it. They are not in the North American Toyota system, I brought them in from Japan.
I've got a couple pics showing the tips from various angles. I'll post them in a bit.
Jeff
Old 07-05-2012, 10:21 PM   #34
Jeff Lange
Jeff Lange's Avatar
Side, looks about right, the flared out part above the curve is basically in line with the top of the bumper cutout:
Top, showing the same thing:
A couple further away shots showing fitment:
Jeff
Old 07-05-2012, 10:24 PM   #35
thermobox
Drives: 16 Impreza 5dr CWP
Here's a few before and after
Originally Posted by thermobox View Post
Puny USDM exhaust cutter. Meh.
Godzilla exhaust cutter kit.
thermobox is offline   Reply With Quote
Old 07-05-2012, 10:36 PM   #36
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Jeff
The place were the bolt is original placed is pretty much bent in such a way that the bolt "fits" inside that bent. Are you not concerned that since now the bolt is pressing against the face of the pipe (not flush inside a bent) the tips are easier to fall or/being removed by someone?
I will look into this tomorrow and see how they look farther in.
Old 07-05-2012, 10:38 PM   #37
Jeff Lange
Jeff Lange's Avatar
No I am not worried about that at all. They are very secure and the bolts were tightened completely. It probably made a new (possibly not quite as large) indentation. The bolts were able to be tightened completely as far as they can go.
Jeff
Old 07-06-2012, 12:20 AM   #38
ayau
i just removed the stock usdm tips and this is what i think.
the stock usdm tips are pushed all the way in at the factory. there's a lip at the end of the inner oval to prevent the assembler from installing the exhaust tip too recessed. once the tip is mounted, the assembler then takes the 10mm bolts and screws it in all the way until it stops. i matched the size of the indentation with the 10mm bolts and they seem to match perfectly.
to get the jdm fit and finish, i'm going to guess that you push the jdm tips all the way in until it hits the lip. then you can take the same 10mm bolts and tighten the tips down until it creates an indentation on the muffler tube.
here are 2 more pics of the jdm exhaust tips fit and finish.
Old 07-06-2012, 12:49 AM   #39
Sportsguy83
Drives: Limited BRZ
Both of you have got my attention, I'll look into this tomorrow.
Old 07-06-2012, 07:56 PM   #40
Sportsguy83
Drives: Limited BRZ
Jeff
Thanks for your pics and calling to my attention how you installed them.
I did it today. Pushed them in as far as they would go and noticed you are absolutely correct, the lip keeps them from going too far in. At that point I screwed the 10 mm bolt and now they seem like they belong. Thanks!
Old 07-06-2012, 08:19 PM   #41
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
How's the sound with these? Any change over the stock FRS/BRZ tips?
Re~Mix is offline   Reply With Quote
Old 07-07-2012, 10:44 AM   #42
thermobox
Agreed.
Exhaust Tips *UPDATED* with pics Ericfrs Cosmetic Modification (Interior/Exterior/Lighting) 35 01-13-2017 03:58 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Exhaust tips rawbz Cosmetic Modification (Interior/Exterior/Lighting) 37 01-19-2013 09:12 PM
Let's keep it simple, I want to change out my exhaust tips. Liquidsnake Engine, Exhaust, Transmission 11 06-30-2012 04:08 AM
Overseas OEM Exhaust Tips (Japanese/European models) frsaraiki Cosmetic Modification (Interior/Exterior/Lighting) 4 05-25-2012 01:03 AM
