Old 06-19-2015, 10:22 AM   #29
Streetthrowback
Drives: 2015 brz
looks good
Streetthrowback is offline   Reply With Quote
Old 06-19-2015, 10:32 AM   #30
Raven604
How much 😦
Raven604 is offline   Reply With Quote
Old 06-19-2015, 10:44 AM   #31
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Originally Posted by JDLAutoDesign View Post
**Picture removed**
My God! F$cking beautiful
shiro is offline   Reply With Quote
Old 06-19-2015, 12:17 PM   #32
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Raven604 View Post
How much 😦
Your eternal servitude.
Old 06-19-2015, 12:38 PM   #33
FirestormFRS
Originally Posted by D K View Post
Is there no room to go straight 'down' past the frame rail?
This is gonna bring a lot of heat to the engine compartment.
I'm betting not considering they didn't do that......
FirestormFRS is offline   Reply With Quote
Old 06-19-2015, 02:47 PM   #34
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Correct. There isn't room to run them anywhere else.... That said,
You can improve the room and run the collector much lower by removing the front crossmember and replacing it with a tubular unit... People have been doing it to Mustangs for years. I'm alarmed that ANY engine swap guys have kept the stock front crossmember - it's unnecessarily huge and in the way. It would be much easier to make a new crossmember with application-specific motor mounts than trying to make adapters for the stock mounting points, especially because the front crossmember just bolts on and off.
Example is a mustang front crossmember, the single picture is of the FRS front crossmember. Look at how much space you could open up if you replaced that... You could even delete the stock power brace and integrate it, and be left with a proper K-frame.
But look at me ranting. Anyway, anybody who's ever installed an overpipe knows how shit and oversized that stock crossmember is.
Spartarus is offline   Reply With Quote
Old 06-19-2015, 03:04 PM   #35
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
It's super tight down by the steering rod.
We have heat shields for the fuse box, etc. I'm not too concerned with NA headers. Plenty of LS setups in other chassis with less room run twin turbos up top with manifolds, downpipes running right by/over the valve covers that produce much more heat. At this level of a build if you can't figure out simple heat management i'm not sure what to tell someone.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 06-19-2015, 05:11 PM   #36
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
Uhhh where do i get those red subframe crossmembers from?
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 06-19-2015, 06:21 PM   #37
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
The stock subframe really isn't in the way and working around it is quite frankly not that big of a problem for the LSx series. The idea behind the the design of these headers was essentially long tubes in a mid-tube size package. They turned out for lack of a better description....... perfect. Heat management isn't even a concern for me.
With stock LSx manifolds in there, there are gobs of room. A log style for a turbo setup would provide a lot of room as well. Even with these very well designed long tube hybrids there is a surprising amount of room in there still. The FA20 is giant width wise so it makes for a lot of room to play with.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 06-20-2015, 11:13 AM   #38
Spartarus
...Just add nauseum
Spartarus's Avatar
I thought most shops had been forced to use a front sump pan because of the subframe... Some had to cut material from the pan to fit it. Unless you have a custom oil pan...
Insight would be appreciated. Looking at swap options again.
Well, the red one is for a mustang, it was just an example. I was actually lamenting the fact that nobody makes a proper tubular crossmember or K-frame for this car. Numerous advantages, especially to engine swaps, but I don't want to thread-jack this thread to discuss them. There is just too much perfect here already.
Old 06-20-2015, 09:01 PM   #39
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Are those vband ends.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 06-20-2015, 10:53 PM   #40
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Disagree.
Cut OEM mounts off x-member. Then used Cusco FA20 mounts (because I already had them) rotated, and made new mounts from 1UZ to these, wasn't a lot of effort. Certainly a lot less than making a new crossmember would have taken.
Not saying that a new x-member wouldn't have been cool, but IMO it was unnecessary.
Manji is offline   Reply With Quote
Old 06-21-2015, 12:38 AM   #41
AZFA20
AZFA20's Avatar
Yes
Old 06-28-2015, 12:55 PM   #42
Kdej1
Colten Drew
Kdej1's Avatar
Drives: '13 Fr-s // '95 Civic // '09 Vette
What a beaut.. What trans do you have mated up?
Also, what oil pan is that?
Kdej1 is offline   Reply With Quote
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
***JDL Auto Design One-Stop Sale Thread!!! Headers/Overpipes/Frontpipes/Exhaust *** Jesse@JDLAutodesign Engine, Exhaust, Bolt-Ons 86 09-03-2015 12:59 PM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
Question about the design of Borla EL Headers... Kiske Engine, Exhaust, Transmission 4 07-26-2013 12:54 PM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
