#29 | |
Drives: UK GT86
As you say, it's also how the tables actually are in the ROMs so it's easier when looking through the likes of ScoobyROM or WInOLS to pick out the tables. In case you didn't have it this is my up-to-date A01G with ratios and metric values.
.: Stealth 86 :.
#30 |
Drives: Toyota 86
TRAC switch doubleclick
Off topic, but related.
With the Arduino Nano going in as a FlexFuel Sensor controller, there is space for much more to be added on. I decided to make a doubleclick TRAC control switch so I don't have to hold down the TRAC switch down for 3+ seconds to turn if off. Simple code and adds 2 resistors and an NPN transistor to the circuitry. If you want it on by default, set initial button state to 4, which acts as a doubleclick a certain time (TRAC_initializeDelay) after power on. Why not the full pedal dance? Mine is a street car and we in Australia can't use the speeds on road which people have issues with VSC activating brakes at, requiring the pedal dance to be used or sent over CANBUS like with OFT. Out of interest, can anyone share the CAN sequence needed for pedal dance active? Code, schematic, and picture of controller box with FlexFuel sensor leads, TRAC switch leads, PLX serial interface. Updated Arduino code: Code:
//Flex Fuel sensor code
//Input frequency on pin 8 - pulled up to 5V through 1.8K resistor
//V_out pin 3 - 0-5V output through 1.8K resistor with 10uf capacitor to ground
//PLX iMFD serial packet on Tx pin 0 through 3.3V TTL voltage divider (3.3K/6.8K)
//TRAC double click code
//Input switch on pin 6 - pulled up to 5V through 3.3K resistor
//Output on pin 10 through NPN transistor to take VSC connection to ground
#include <Arduino.h>
#include <FreqMeasure.h>
//FlexFuel sensor
double sum = 0;
int count = 0;
int ethanol_int, V_out_int;
float freq, ethanol, V_out, E_scalar;
float E0 = 50; //calibration data for pure gasoline
float E85 = 135; //calibration data for E85
//PLX data
long P0, P1, Pdelta;
byte PLXpacket[7] {0x80, 0x00, 0x11, 0x00, 0x00, 0x00, 0x40};
//PLX iMFD packet, sent every 100ms:
//0x80 Start byte
//0x00 0x11 Sensor device fuel level
//0x00 Sensor instance
//0x00 0x00 Sensor value (integer, unscaled)
//0x40 Stop byte
//TRAC switch double click
bool TRAC_buttonMonitor = HIGH;
int debounce = 20;
int doubleClick = 200;
int longClick = 3500;
int TRAC_initializeDelay = 5000;
int TRAC_buttonState = 0; //initialize to 0 for normal operation, 4 for on by default after delay
long TRAC_buttonCounter = 0;
void setup()
pinMode (3, OUTPUT);
pinMode (10, OUTPUT);
digitalWrite (10, LOW);
pinMode (6, INPUT);
FreqMeasure.begin();
Serial.begin(19200);
P0 = millis();
E_scalar = (E85 - E0) / 85;
void loop()
//Read FlexFuel sensor frequency
if (FreqMeasure.available())
// average several readings together
sum = sum + FreqMeasure.read();
count = count + 1;
if (count > 30)
freq = FreqMeasure.countToFrequency(sum / count);
sum = 0;
count = 0;
//Convert frequency to E%
ethanol = (freq - E0) / E_scalar; //scale frequency to E% interpolating E0 and E85 values
if (ethanol > 100)
ethanol = 100;
if (ethanol < 0)
ethanol = 0;
ethanol_int = (int)ethanol;
//FlexFuel voltage output
V_out = 5 - (0.05 * ethanol);
V_out = 51 * V_out; //scale to 255
V_out_int = (int)V_out; //convert to integer for analogWrite
analogWrite(3, V_out_int); //output V_out as PWM voltage on pin 3
//PLX data packet
P1 = millis(); //send PLX packet on Tx pin every 100ms
Pdelta = P1 - P0;
if (Pdelta >= 100)
P0 = P1;
PLXpacket[5] = ethanol_int; //set data byte in PLX packet to E%
Serial.write(PLXpacket, 7);
//TRAC switch doubleclick
TRAC_buttonMonitor = digitalRead(6);
switch (TRAC_buttonState)
case 0: //inactive
if (TRAC_buttonMonitor == LOW) // button pressed
digitalWrite (10, HIGH); //Transistor on
TRAC_buttonState = 1; //increment state
break;
case 1: //check for release
if (TRAC_buttonMonitor == HIGH) //if button released
TRAC_buttonCounter = millis(); //start counter
TRAC_buttonState = 2; //increment state
break;
case 2: //wait for doubleClick
if (TRAC_buttonMonitor == LOW && (millis() - TRAC_buttonCounter) > debounce && (millis() - TRAC_buttonCounter) < doubleClick) //second click registered
TRAC_buttonState = 3; //increment state
else if ((millis() - TRAC_buttonCounter) > doubleClick)
digitalWrite (10, LOW); //Transistor off
TRAC_buttonState = 0; //reset state
break;
case 3: //doubleClick made
if ((millis() - TRAC_buttonCounter) > longClick)
break;
case 4: //initialize after delay by default
if (millis() > TRAC_initializeDelay)
TRAC_buttonState = 3; //set state to doubleClick
break;
#31 |
Drives: Toyota 86
Applying scalings to injector routines
Having calculated a fuelling multiplier based on E% and scaling the stock PI (Injector scaling BRZ) and DI (DI pressure multiplier C) multiplier values in the routine described above in post #15, we need to get these values read in the fueling routines.
In the previous code, the following values are shown in the data segment following the code: Code:
000B98B0 FF F8 D4 18 off_B98B0: .data.l RAM_Flex_PI_Scaling ; DATA XREF: sub_B97C0 000B98B4 FF F8 D4 1C off_B98B4: .data.l RAM_Flex_GDI_Mult_C ; DATA XREF: sub_B97C0 000B98CC 00 10 C6 80 off_B98CC: .data.l Injector_Flow_Scaling_BRZ 000B98CC ; DATA XREF: sub_B97C0 000B98D0 00 10 C6 14 off_B98D0: .data.l GDI_Pressure_Multiplier_C 000B98D0 ; DATA XREF: sub_B97C0 What we need to do is find where in the ROM these values exist to be referenced and change them to point to our Flex Fuel scalars in RAM (FFF8D418 for PI and FFF8D41C for DI). This is as simple as searching for 0010C680 and replacing with FFF8D418 (6 instances) and 0010C614 and replacing with FFF8D41C (1 instance). All these instances are referenced by code appropriately: Code:
Address Function Instruction ------- -------- ----------- ROM:0003D260 .data.l Injector_Flow_Scaling_BRZ ROM:0003F7FC .data.l Injector_Flow_Scaling_BRZ ROM:00058528 .data.l Injector_Flow_Scaling_BRZ ROM:00058AF0 sub_585FC .data.l Injector_Flow_Scaling_BRZ ROM:0007B938 .data.l Injector_Flow_Scaling_BRZ ROM:000A779C sub_A7280 .data.l Injector_Flow_Scaling_BRZ Address Function Instruction ------- -------- ----------- ROM:0005763C .data.l GDI_Pressure_Multiplier_C |
#32 |
Drives: Toyota 86
Cranking Compensations
Edit ***This v.1 code has not worked the way I thought - I get an appropriate multiplier and this does not get applied to the cranking fuel. Error due to delay in Arduino reading ethanol. v.2 code in Post #46, v.3 code in Post #49. ***
For this, we'll hijack the IAT cranking compensation lookup table which normally returns 1.0 for all IAT temperatures. There are two references to the IAT cranking compensation lookup table and we'll hook both to insert an ECT based cranking multiplier which is scaled by the Flex Fuelling multiplier. Stock code location A: Code:
ROM:00057880 loc_57880: ; CODE XREF: Cranking_Fuelling_Comp ROM:00057880 D4 24 mov.l #stru_B424C, r4 ROM:00057882 D6 21 mov.l #Pull_2D_A, r6 ROM:00057884 46 0B jsr @r6 ; Pull_2D_A ROM:00057886 F4 EC fmov fr14, fr4 ROM:00057888 3D 01 30 02 fmov.s fr0, @((RAM_Cranking_Comp_Accel - RAM_Cranking_Comp),r13) ROM:0005788C ROM:0005788C loc_5788C: ; CODE XREF: Cranking_Fuelling_Comp ROM:0005788C D4 22 mov.l #Table_Cranking_Fuel_IPW_Compensation_IAT, r4 ROM:0005788E D6 1E mov.l #Pull_2D_A, r6 ROM:00057890 46 0B jsr @r6 ; Pull_2D_A ROM:00057892 F4 FC fmov fr15, fr4 ROM:00057894 3D 01 30 03 fmov.s fr0, @((RAM_Cranking_Comp_IAT - RAM_Cranking_Comp),r13) ROM:00057898 B0 05 bsr Apply_Cranking_Compensation ROM:0005789A 64 E3 mov r14, r4 ROM:0005789C FD 0A fmov.s fr0, @r13 ROM:00057918 00 0B 42 20 off_57918: .data.l Table_Cranking_Fuel_IPW_Compensation_IAT ROM:00057918 ; DATA XREF: Cranking_Fuelling_Comp:loc_5788C Code:
00057880 loc_57880: ; CODE XREF: Cranking_Compensations 00057880 D4 24 mov.l #off_B424C, r4 00057882 D6 21 mov.l #Pull_2D_A, r6 00057884 46 0B jsr @r6 ; Pull_2D_A 00057886 F4 EC fmov fr14, fr4 00057888 3D 01 30 02 fmov.s fr0, @((RAM_Cranking_Comp_Accel - Cranking_Final),r13) 0005788C 0005788C loc_5788C: ; CODE XREF: Cranking_Compensations 0005788C D2 22 mov.l #FlexFuel_Cranking_Comp, r2 0005788E 04 80 90 A4 movi20 #RAM_ECT, r4 00057892 42 4B jsr/n @R2 ; FlexFuel_Cranking_Comp 00057894 3D 01 30 03 fmov.s fr0, @((RAM_Cranking_Comp_Flex_Fuel - Cranking_Final),r13) 00057898 B0 05 bsr sub_578A6 0005789A 64 E3 mov r14, r4 0005789C FD 0A fmov.s fr0, @((Cranking_Final - Cranking_Final),r13) 00057918 00 0B 98 70 off_57918: .data.l FlexFuel_Cranking_Comp 00057918 ; DATA XREF: Cranking_Compensations:loc_5788C 000B9870 FlexFuel_Cranking_Comp: ; CODE XREF: Cranking_Compensations 000B9870 ; Cranking_Compensations_0 000B9870 ; DATA XREF: ... 000B9870 4F 22 sts.l pr, @-r15 000B9872 F4 48 fmov.s @r4, fr4 ; r4=ECT 000B9874 02 10 13 88 movi20 #Pull_2D_A, r2 000B9878 D4 19 mov.l #Ethanol_Cranking_Comp_Table, r4 ; Pull_2D_A 000B987A 42 4B jsr/n @R2 ; Pull_2D_A 000B987C D4 0E mov.l #RAM_Flex_Crank_Comp, r4 000B987E F5 9D fldi1 fr5 000B9880 D6 0A mov.l #RAM_Flex_Fuelling_Multiplier, r6 000B9882 F4 68 fmov.s @r6, fr4 000B9884 F4 51 fsub fr5, fr4 ; fr4-1.0 000B9886 F5 4E fmac fr0, fr4, fr5 ; 1+(crank_comp*(fuelling multiplier-1)) 000B9888 F0 5C fmov fr5, fr0 000B988A F4 0A fmov.s fr0, @r4 000B988C 4F 26 lds.l @r15+, pr 000B988E 00 6B rts/n Code:
ROM:00057F4C D4 18 mov.l #Table_Cranking_Fuel_IPW_Compensation_Accelerator, r4 ROM:00057F4E D2 17 mov.l #Pull_2D_A, r2 ROM:00057F50 42 0B jsr @R2 ; Pull_2D_A ROM:00057F52 F4 EC fmov fr14, fr4 ROM:00057F54 FC 0C fmov fr0, fr12 ROM:00057F56 D4 17 mov.l #Table_Cranking_Fuel_IPW_Compensation_IAT, r4 ROM:00057F58 D2 14 mov.l #Pull_2D_A, r2 ROM:00057F5A 42 0B jsr @R2 ; Pull_2D_A ROM:00057F5C F4 FC fmov fr15, fr4 ROM:00057F5E FE 0C fmov fr0, fr14 ROM:00057FB4 00 0B 42 20 off_57FB4: .data.l Table_Cranking_Fuel_IPW_Compensation_IAT ROM:00057FB4 ; DATA XREF: sub_57F00 Code:
00057F4C D4 18 mov.l #Table_Cranking_Fuel_IPW_Compensation_Accelerator, r4 00057F4E D2 17 mov.l #Pull_2D_A, r2 00057F50 42 0B jsr @R2 ; Pull_2D_A 00057F52 F4 EC fmov fr14, fr4 00057F54 FC 0C fmov fr0, fr12 00057F56 D2 17 mov.l #FlexFuel_Cranking_Comp, r2 00057F58 04 80 90 A4 movi20 #RAM_ECT, r4 ; FlexFuel_Cranking_Comp 00057F5C 42 4B jsr/n @R2 ; FlexFuel_Cranking_Comp 00057F5E FE 0C fmov fr0, fr14 00057FB4 00 0B 98 70 off_57FB4: .data.l FlexFuel_Cranking_Comp 00057FB4 ; DATA XREF: Cranking_Compensations_0 000B9870 FlexFuel_Cranking_Comp: ; CODE XREF: Cranking_Compensations 000B9870 ; Cranking_Compensations_0 000B9870 ; DATA XREF: ... 000B9870 4F 22 sts.l pr, @-r15 000B9872 F4 48 fmov.s @r4, fr4 ; r4=ECT 000B9874 02 10 13 88 movi20 #Pull_2D_A, r2 000B9878 D4 19 mov.l #Ethanol_Cranking_Comp_Table, r4 ; Pull_2D_A 000B987A 42 4B jsr/n @R2 ; Pull_2D_A 000B987C D4 0E mov.l #RAM_Flex_Crank_Comp, r4 000B987E F5 9D fldi1 fr5 000B9880 D6 0A mov.l #RAM_Flex_Fuelling_Multiplier, r6 000B9882 F4 68 fmov.s @r6, fr4 000B9884 F4 51 fsub fr5, fr4 ; fr4-1.0 000B9886 F5 4E fmac fr0, fr4, fr5 ; 1+(crank_comp*(fuelling multiplier-1)) 000B9888 F0 5C fmov fr5, fr0 000B988A F4 0A fmov.s fr0, @r4 000B988C 4F 26 lds.l @r15+, pr 000B988E 00 6B rts/n Last edited by ztan; 12-18-2015 at 06:56 PM. |
#34 |
Drives: Toyota 86
Beta testing
It Works!!!
Early beta testing, still need to post up fuelling and timing interpolation code, verify reasonable use of multipliers. Have filled up to E20 (up to E35 with E85 sitting in the tank before mixing in with residual fuel) and using a E85 multiplier of 1.35, trims look quite stable at present. |
#35 |
Drives: 2013 frs
Great job man, this is also way out of my league but great to have contributors like yourself and steve99 on this forum.
#36 |
Drives: Toyota 86
Flex Fuel Primary OL fuelling
This one is tricky.
I've used the routine for Primary OL enrichment lookup and assigned that to E85. The OL additive is a table that gets used normally when IAM < 1.0 and I've used that for an E0 table. The modified code is also a bit longer than the original and overlaps (by 2 bytes) a routine that is not used in stock A01G. Stock code: Code:
ROM:00061420 D6 67 mov.l #byte_114663, r6 ; Move Immediate Long Data ROM:00061422 62 60 mov.b @r6, r2 ; r2=0 ROM:00061424 22 28 tst r2, r2 ; Test Logical ROM:00061426 8B 3A bf Not_Used ; T ROM:00061426 ROM:00061428 D6 66 mov.l #byte_10C319, r6 ; Move Immediate Long Data ROM:0006142A 60 60 mov.b @r6, r0 ; r0=0 ROM:0006142C 88 5A cmp/eq #h'5A, r0 ; 'Z' ; Compare: Equal ROM:0006142E 89 18 bt Not_Used_1 ; Branch if True ROM:0006142E ROM:00061430 D4 65 mov.l #Table_Primary_Open_Loop_Fueling, r4 ; Move Immediate Long Data ROM:00061432 D2 66 mov.l #Pull_3D_A, r2 ; Move Immediate Long Data ROM:00061434 34 F1 70 01 fmov.s @(4,r15), fr4 ; Floating-point move single precision ROM:00061438 42 0B jsr @R2 ; Pull_3D_A ; Jump to Subroutine ROM:0006143A F5 F8 fmov.s @r15, fr5 ; Floating-point move single precision ROM:0006143A ROM:0006143C 3F 01 30 03 fmov.s fr0, @(h'C,r15) ; Floating-point move single precision ROM:00061440 D4 63 mov.l #Table_Primary_Open_Loop_Fueling_Additive, r4 ; Move Immediate Long Data ROM:00061442 F7 F8 fmov.s @r15, fr7 ; Floating-point move single precision ROM:00061444 34 F1 70 01 fmov.s @(4,r15), fr4 ; Floating-point move single precision ROM:00061448 D2 60 mov.l #Pull_3D_A, r2 ; Move Immediate Long Data ROM:0006144A 42 0B jsr @R2 ; Pull_3D_A ; Jump to Subroutine ROM:0006144C F5 7C fmov fr7, fr5 ; Floating-point move ROM:0006144C ROM:0006144E 3A 01 30 16 fmov.s fr0, @((flt_FFF8A8FC - flt_FFF8A8A4),r10) ; Floating-point move single precision ROM:00061452 F0 9D fldi1 fr0 ; fr0=1.0 ROM:00061454 F0 D1 fsub fr13, fr0 ; fr0=1.0-IAM ROM:00061456 35 F1 70 03 fmov.s @(h'C,r15), fr5 ; fr5= return from Primary OL table ROM:0006145A 39 A1 70 16 fmov.s @((flt_FFF8A8FC - flt_FFF8A8A4),r10), fr9 ; fr9=return from primary open loop additive table ROM:0006145E A0 4D bra loc_614FC ; Branch ROM:00061460 F5 9E fmac fr0, fr9, fr5 ; fr5=fr0*fr9+fr5 Code:
00061420 D6 01 mov.l #RAM_Flex_Fuelling_Interpolant, r6 00061422 A0 05 bra loc_61430 00061424 F8 68 fmov.s @r6, fr8 00061424 ; --------------------------------------------------------------------------- 00061426 FF FF .data.w h'FFFF 00061428 FF F8 D4 24 off_61428: .data.l RAM_Flex_Fuelling_Interpolant 00061428 ; DATA XREF: sub_613A2 0006142C FF FF FF FF .data.l h'FFFFFFFF 00061430 ; --------------------------------------------------------------------------- 00061430 00061430 loc_61430: ; CODE XREF: sub_613A2 00061430 D4 65 mov.l #Table_Primary_OL_Fueling_E85, r4 00061432 D2 66 mov.l #Pull_3D_A, r2 00061434 34 F1 70 01 fmov.s @(4,r15), fr4 ; Load 00061438 42 0B jsr @R2 ; Pull_3D_A 0006143A F5 F8 fmov.s @r15, fr5 ; RPM 0006143C 3F 01 30 03 fmov.s fr0, @(h'C,r15) ; Primary OL Fuelling E85 result 00061440 D4 63 mov.l #Table_Primary_OL_Fueling_E0, r4 00061442 F7 F8 fmov.s @r15, fr7 ; RPM 00061444 34 F1 70 01 fmov.s @(4,r15), fr4 ; Load 00061448 D2 60 mov.l #Pull_3D_A, r2 0006144A 42 0B jsr @R2 ; Pull_3D_A 0006144C F5 7C fmov fr7, fr5 ; RPM 0006144E 3A 01 30 16 fmov.s fr0, @((RAM_Primary_OL_E0_Result - flt_FFF8A8A4),r10) 00061452 F0 9D fldi1 fr0 ; fr0=1.0 00061454 F0 81 fsub fr8, fr0 ; fr0=1.0-FF_interpolant 00061456 35 F1 70 03 fmov.s @(h'C,r15), fr5 ; fr5= return from Primary OL E85 table 0006145A 39 A1 70 16 fmov.s @((RAM_Primary_OL_E0_Result - flt_FFF8A8A4),r10), fr9 ; fr9=return from primary OL E0 table 0006145E F5 82 fmul fr8, fr5 ; fr5=Primary OL E85 * FF_Interpolant 00061460 A0 4C bra loc_614FC 00061462 F5 9E fmac fr0, fr9, fr5 ; (1-FF_interpolant)*(Primary_OL_E0) + (FF_interpolant*Primary_OL_E85) Stock table defs: Code:
ROM:000B5854 00 0D 00 17 Table_Primary_Open_Loop_Fueling:Table_Type <h'D, 0, h'17> ROM:000B5854 ; DATA XREF: sub_613A2 ROM:000B5854 ; sub_613A2 ROM:000B5858 00 11 14 34 .data.l Primary_Open_Loop_Fueling_X_Axis ROM:000B585C 00 11 14 68 .data.l Primary_Open_Loop_Fueling_Y_Axis ROM:000B5860 00 11 14 C4 .data.l Primary_Open_Loop_Fueling ROM:000B5864 04 00 .data.w h'400 ROM:000B5866 00 00 .data.w 0 ROM:000B5868 3C 00 00 00 .float 0.0078125 ROM:000B586C 00 00 00 00 .float 0.0 ROM:000B588C 00 0D 00 17 Table_Primary_Open_Loop_Fueling_Additive:Table_Type <h'D, 0, h'17> ROM:000B588C ; DATA XREF: sub_613A2 ROM:000B588C ; sub_613A2:off_615D0 ROM:000B5890 00 11 16 04 .data.l unk_111604 ROM:000B5894 00 11 16 38 .data.l unk_111638 ROM:000B5898 00 11 16 94 .data.l Primary_Open_Loop_Fueling_Additive ROM:000B589C 04 00 .data.w h'400 ROM:000B589E 00 00 .data.w 0 ROM:000B58A0 3C 00 00 00 .float 0.0078125 ROM:000B58A4 BF 80 00 00 .float -1.0 Code:
000B5854 00 0D 00 17 Table_Primary_OL_Fueling_E85:Table_Type <h'D, 0, h'17> 000B5854 ; DATA XREF: sub_613A2:loc_61430 000B5854 ; sub_613A2:off_615C8 000B5858 00 11 14 34 .data.l Primary_Open_Loop_Fueling_X_Axis 000B585C 00 11 14 68 .data.l Primary_Open_Loop_Fueling_Y_Axis 000B5860 00 11 14 C4 .data.l Primary_Open_Loop_Fueling 000B5864 04 00 00 00 .data.l h'4000000 000B5868 3C 00 00 00 .float 0.0078125 000B586C 00 00 00 00 .float 0.0 000B588C 00 0D 00 17 Table_Primary_OL_Fueling_E0:Table_Type <h'D, 0, h'17> 000B588C ; DATA XREF: sub_613A2 000B588C ; sub_613A2:off_615D0 000B5890 00 11 16 04 .data.l Primary_Open_Loop_Fueling_Additive_X_Axis 000B5894 00 11 16 38 .data.l Primary_Open_Loop_Fueling_Additive_Y_Axis 000B5898 00 11 16 94 .data.l Primary_Open_Loop_Fueling_Additive 000B589C 04 00 00 00 .data.l h'4000000 000B58A0 3C 00 00 00 .float 0.0078125 000B58A4 00 00 00 00 .float 0.0 |
#37 |
Drives: slow frs
Awesome progress man. Keep up the good work!
#38 |
Drives: 2013 FRS
Amazing!
#39 |
Drives: FR-S Whiteout
Gangster!
Intent > Content
cowardice is the mother of cruelty. |
#40 |
Drives: 2013 Ultramarine FR-S
Excited to see this so close. Great Job!!
#41 |
Drives: Toyota 86
Updated log data
Fuelling daily drive data from the last couple of weeks, slowly moving across to E85. This data is with the Flex fuelling multiplier applied to 2 values only: PI scaling BRZ and GDI pressure multiplier C.
OL data is similar, though there is a early crossover period that looks rich when a higher E% is in the DI line where my sensor sits and fuel with a lower E% is still getting flushed out of that line. |
#42 |
Drives: Toyota 86
Flex Fuel Timing
For this code, I'm using Base Timing B as a E85 table, Base Timing A as an E0 table and interpolating between them based on E%.
The stock ROM has a value (FFF8ADB8 in A01G) which interpolates between the tables and we'll hijack that. Base Timing A gets used after a flash in the first few minutes AVCS is calibrating then switches to Base Timing B for the rest of the time. Stock code for the base timing table pull: Code:
ROM:00069C76 D2 46 mov.l #RAM_ECT, r2 ROM:00069C78 F8 28 fmov.s @R2, fr8 ROM:00069C7A FF 8A fmov.s fr8, @r15 ROM:00069C7C D2 45 mov.l #RAM_E_Load, r2 ROM:00069C7E FD 28 fmov.s @R2, fr13 ROM:00069C80 0E 80 AD 70 movi20 #RAM_Base_Timing, r14 ROM:00069C84 35 E1 70 0D fmov.s @((RAM_RPM_1 - RAM_Base_Timing),r14), fr5 ROM:00069C88 FC 5C fmov fr5, fr12 ROM:00069C8A D4 43 mov.l #Table_Base_Timing_B, r4 ROM:00069C8C D2 3E mov.l #Pull_3D_A, r2 ROM:00069C8E 42 0B jsr @R2 ; Pull_3D_A ROM:00069C90 F4 DC fmov fr13, fr4 ROM:00069C90 ROM:00069C92 E0 5C mov #h'5C, r0 ; '\' ROM:00069C94 FE 07 fmov.s fr0, @(r0,r14) ; ADCC ROM:00069C96 FE E6 fmov.s @(r0,r14), fr14 ROM:00069C98 3F E1 70 12 fmov.s @((RAM_Base_Timing_Interp_Factor - RAM_Base_Timing),r14), fr15 ROM:00069C9C D4 3F mov.l #Table_Base_Timing_A, r4 ROM:00069C9E F4 DC fmov fr13, fr4 ROM:00069CA0 D2 39 mov.l #Pull_3D_A, r2 ROM:00069CA2 42 0B jsr @R2 ; Pull_3D_A ROM:00069CA4 F5 CC fmov fr12, fr5 ROM:00069CA4 ROM:00069CA6 E0 60 mov #h'60, r0 ; '`' ROM:00069CA8 FE 07 fmov.s fr0, @(r0,r14) ; FFF8ADD0 ROM:00069CAA FE F2 fmul fr15, fr14 ; FFF8ADB8*Base Timing B result ROM:00069CAC F0 9D fldi1 fr0 ROM:00069CAE F0 F1 fsub fr15, fr0 ; 1.0-FFF8ADB8 ROM:00069CB0 F8 E6 fmov.s @(r0,r14), fr8 ROM:00069CB2 FE 8E fmac fr0, fr8, fr14 ; Base_Timing A *(1-FFF8ADB8) + Base_Timing_B * FFF8ADB8 Code:
00069C76 D2 46 mov.l #RAM_ECT, r2 00069C78 F8 28 fmov.s @R2, fr8 00069C7A FF 8A fmov.s fr8, @r15 00069C7C D2 45 mov.l #RAM_E_Load, r2 00069C7E FD 28 fmov.s @R2, fr13 00069C80 0E 80 AD 70 movi20 #RAM_Base_Timing, r14 00069C84 35 E1 70 0D fmov.s @((RAM_RPM_1 - RAM_Base_Timing),r14), fr5 00069C88 FC 5C fmov fr5, fr12 00069C8A D4 43 mov.l #Table_Base_Timing_E85, r4 00069C8C D2 3E mov.l #Pull_3D_A, r2 00069C8E 42 0B jsr @R2 ; Pull_3D_A 00069C90 F4 DC fmov fr13, fr4 00069C92 D2 02 mov.l #FlexFuel_Timing_Interpolation, r2 00069C94 42 4B jsr/n @R2 ; FlexFuel_Timing_Interpolation 00069C96 A0 03 bra loc_69CA0 00069C98 00 09 nop 00069C98 ; --------------------------------------------------------------------------- 00069C9A FF FF .data.w h'FFFF 00069C9C 00 0B 98 50 off_69C9C: .data.l FlexFuel_Timing_Interpolation 00069C9C ; DATA XREF: Base_Timing_Lookup 00069CA0 ; --------------------------------------------------------------------------- 00069CA0 00069CA0 loc_69CA0: ; CODE XREF: Base_Timing_Lookup 00069CA0 D2 39 mov.l #Pull_3D_A, r2 00069CA2 42 0B jsr @R2 ; Pull_3D_A 00069CA4 F5 CC fmov fr12, fr5 00069CA6 E0 60 mov #h'60, r0 ; '`' 00069CA8 FE 07 fmov.s fr0, @(r0,r14) ; FFF8ADD0: Base Timing E0 Result 00069CAA FE F2 fmul fr15, fr14 ; Base timing E85 * FF_Timing_Interpolant 00069CAC F0 9D fldi1 fr0 00069CAE F0 F1 fsub fr15, fr0 ; 1-FF_Timing_Interpolant 00069CB0 F8 E6 fmov.s @(r0,r14), fr8 00069CB2 FE 8E fmac fr0, fr8, fr14 ; (Base timing E0 * (1-FF_Timing_Interpolant)) + (Base timing E85 * FF_Timing_Interpolant) 000B9850 FlexFuel_Timing_Interpolation: ; CODE XREF: Base_Timing_Lookup 000B9850 ; DATA XREF: Base_Timing_Lookup 000B9850 4F 22 sts.l pr, @-r15 000B9852 E0 5C mov #h'5C, r0 ; '\' 000B9854 FE 07 fmov.s fr0, @(r0,r14) 000B9856 FE E6 fmov.s @(r0,r14), fr14 000B9858 D4 19 mov.l #RAM_Flex_Timing_Interpolant, r4 000B985A FF 48 fmov.s @r4, fr15 000B985C D4 24 mov.l #Table_Base_Timing_E0, r4 000B985E F4 DC fmov fr13, fr4 000B9860 4F 26 lds.l @r15+, pr 000B9862 00 6B rts/n |
| Open source Over Boost Fuel Cut | ztan | Software Tuning | 19 | 02-15-2026 02:32 AM |
| Open Source Electric Supercharger | neutron256 | Forced Induction | 913 | 08-22-2021 06:16 PM |
| open source software question | GeeTee86 | AFRICA | 15 | 02-15-2015 07:52 PM |
| The Retrofit Source summer open house! | soundman98 | Southeast | 0 | 06-23-2014 09:41 PM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 10:36 AM |
