Old 07-22-2013, 09:22 PM   #407
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by FA20Club.com View Post
ok ill help you guys out the stop system ive had give out around 280whp with injectors in i have the pump lose flow at 290whp. this was on 93 octane. if you factor in the 30% increase in fuel needed the injectors only will cause fueling issues without the pump on e85 at lower hp levels. you can try to lean on the DI system to help but you wont get far. I dont understand why its the innovate guys that seemed to be the most concerned about blowing an engine compared to the turbo/vortech guys but are the most resistant to not want to upgrade the fuel system. Nick lemme know i have pump and injectors instock.
Pm'd.
I would like to not upgrade injectors + pump atm. I'm not looking for crazy power. But I have a reliable E85 station 1 mile away from my home. So it would seem like a viable option. i've also had lots of boosted cars (wrx's STi's) and I know how subaru engines are. Not trying to go for insane HP numbers until the engine is completly built... Then i'll get a smaller pully + intercooler + bigger injectors + fuel pump and go for real numbers. (our current 02 WRX wagon is at 400WHP 400TQ on 19lbs of boost.... fully built) + I DD this car.
Do you think stock pump + injectors would be okay with corn around the 250WHP numbers? @robispec
(I doubt my car would make more then 250 on corn)
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 07-22-2013, 09:26 PM   #408
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by NickFRS View Post
Pm'd.
According to @moto-mike - yes. but i would like to hear @FA20Club.com 's input on this as well. if this is the case i wonder if the fuel package on his special can be modified to ditch the 525's and FP for some 700's and maybe a price adjustment if appropriate.
Old 07-22-2013, 09:30 PM   #409
swift996
swift996's Avatar
Innovate:
E50, K&N Drop In, FA20Club Catted Header, FA20Club Resonated Front Pipe
Vortech:
93, Borla UEL Headers, Perrin Over Pipe, Perrin Front Pipe, Borla Cat-Back
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-22-2013, 10:08 PM   #410
getbent
Drives: 2013 FR-S Blue MT
What's the details on this?
... I'll also be running a Nameless Performance oil cooler. ...
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 07-22-2013, 10:22 PM   #411
NickFRS
i'll let Jason get to that.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 07-23-2013, 12:21 AM   #412
wrxgoose
WUB WUB
Drives: 2013 Firestorm
so i tried to make a useful vid, where you could hear the SC, and some impressions and stuffs. also: i need to shut up in this vid. lol.
[ame="http://www.youtube.com/watch?v=Qdi7XDWbdQY"]FRS Innovate SC, drive/ impressions pt 1 - YouTube[/ame]
edit: i sound like an idiot. two and 3/4 thousand. *facepalm* don't make too much fun of me.
I really need a go-pro, or to borrow someone's
wrxgoose is offline   Reply With Quote
Old 07-23-2013, 12:25 AM   #413
Alabang 86
Alabang 86's Avatar
Drives: GT86
that sounds frik'n awesome
...my turn...
Alabang 86 is offline   Reply With Quote
Old 07-23-2013, 12:27 AM   #414
FA20Club.com
Drives: 2013 White Out FR-S
youll get farther with a pump upgrade than injectors. none of our kits so far are running over 40% total flow of ports. even our 60 trim 430whp car is only using 35% of the 850cc @ that power level. our normal 550cc tunes only use 35% port. but none of that is possible without a pump upgrade. without the pump upgrade youll start to drop pressure eventually to the DI pump. nthe innovate has one thing that helps you guys out which is: it doesnt move allot of air so fuel isnt as critical as with a vortech or turbo. but you never want to drop flow to the motor. so between the two i would opt for the pump before injectors.
FA20Club.com is offline   Reply With Quote
Old 07-23-2013, 12:58 AM   #415
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I thought someone earlier was seeing high PI duty cycles and was able to smooth out the top end and gain a little with larger injectors on the stock pump.
Old 07-23-2013, 01:04 AM   #416
FA20Club.com
you can change how much of the total ratio is used from DI vs port. so that varies but both need supply. if you have larger injectors you will empty the rail faster without flow from the intank supply. i can lower port duty cycle by using more of the DI system but the DI system will require more supply so it doesnt drop pressure in the system. hope that makes more sense to you guys. this isnt a std fuel system so normal theory isnt solid here. i have learned from my experience tuning these kits as well as other with different size injectors and pumps.
Old 07-23-2013, 01:05 AM   #417
s2d4
s2d4's Avatar
Originally Posted by Draco-REX View Post
From what I've been reading, injectors are a BIG yes, pump is a maybe.
robi isn't running larger injectors.
Using DI will have much larger benefit with E85 than with port so a larger pump will do, proven fact but yeah, injectors make money!
Running too large injectors and only use 35% is no where near the designed atomisation. It will run and be better controlled with the right size, known fact also. Bigger isn't always better with injectors.
Edit:6 hrs late..
Old 07-23-2013, 09:20 AM   #418
Alabang 86
Alabang 86's Avatar
Drives: GT86
had mine installed while I'm away, sent me a graph today...
comments please.
mods....
Nameless front pipe w/hiflo cat
Nameless axle back
K&N drop in
Innovate SC
...my turn...
Old 07-23-2013, 09:33 AM   #419
Draco-REX
Corner Junkie
Draco-REX's Avatar
So the injector results vs pump results are dependant on how much the tuner uses the DI system?
That makes me wonder about something else.. I wonder if the people having DI seal issues are running really low DI duty cycles at WOT. The fuel could be cooling the injectors, and a low dc might be letting the injectors overheat and weaken the seals. Dunno, just a sudden thought..
But back OT: So it seems to me, that there's a noticeable divide between the tuning philosophies out there. If some are getting results on just injectors and some with just a pump, it seems some tuners perfer to use the PI system instead of the DI system.
I see long threads of heated discussion in the near future...
Old 07-23-2013, 09:33 AM   #420
regal
comments please.
mods....
Nameless axle back
K&N drop in
Innovate SC
nice no squiggles
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
