View Poll Results: What color of Series.Blue did you opt for?
Blue 176 55.70%
White 140 44.30%
Voters: 316. You may not vote on this poll
Old 09-18-2014, 09:19 PM   #407
Nivaku
Drives: 2015 Blue Series
Dumb question, will this fit?
[ame="http://www.amazon.com/Covercraft-UVS100-Shield-Windshield-Sunshade/dp/B009B8UVJ2"]Amazon.com: Covercraft UVS100 Heat Shield Custom Fit Windshield Sunshade for Select Subaru BRZ Models - Laminate Material (Silver): Automotive[/ame]
Nivaku is offline   Reply With Quote
Old 09-18-2014, 09:36 PM   #408
santir
Drives: Subaru BRZ Edition Blue
Here is mine with a 25mm front 30mm wheel spacers. dropped on ISC coils.
santir is offline   Reply With Quote
Old 09-19-2014, 02:56 PM   #409
trinxified
Drives: Subaru BRZ Aozora Edition
Nice! ^
I kinda wished I did the same thing, I went a bit smaller and put 20/25mm instead. Do you mind taking pics from the front or rear to see the flushness?
trinxified is offline   Reply With Quote
Old 09-21-2014, 04:08 PM   #410
quality_sound
Drives: '15 BRZ Series.Blue
Originally Posted by hanabie View Post
anyone knows where to get sharkfin sti antenna?
Yours didn't come with a sharkfin?
quality_sound is offline   Reply With Quote
Old 09-21-2014, 07:42 PM   #411
BRZ.SeriesBlue28
Drives: 2015 Subaru Series.Blue (WRB)
Pulled the trigger on the Perrin 4" Exhaust Tips. Turns out that the driver's exhaust pipe is much shorter so it took longer to install than expected including adjusting the tip angle to match the opening.
Here is the before and after picture. Much nicer looking.
BRZ.SeriesBlue28 is offline   Reply With Quote
Old 09-21-2014, 08:34 PM   #412
trinxified
Thanks for posting. I got the same things.
Did you notice if the right tip sits a bit lower after installation? Like about half an inch or so?
Old 09-21-2014, 08:40 PM   #413
BRZ.SeriesBlue28
For me, the driver side pipe was offset to the left a little and higher. I fixed that by adjusting the pipe and hanger.
I think you have to play with it. It took me a few tries.
Old 09-21-2014, 08:48 PM   #414
trinxified
How did you adjust them? I guess you had the same problem as me. Did you need new bushings?
Old 09-21-2014, 09:27 PM   #415
BRZ.SeriesBlue28
Mine wasn't that bad. I adjusted the hanger for the exhaust on the driver side and lightly bent the pipe. Knowing that the driver side pipe was shorter, Perrin should have made one tip longer.
Old 09-22-2014, 01:59 AM   #416
trinxified
I actually haven't fixed it yet, I figured replacing the bushings/hangers on the right to pull it up higher would be the best way to fix it.
Old 09-22-2014, 02:54 PM   #417
UrmyboyBLUE
UrmyboyBLUE's Avatar
Drives: 2015 Subaru BRZ "Series.Blue"
Here's mine.....got tint done and yellow fog covers since this was taken, but you get the idea.
UrmyboyBLUE is offline   Reply With Quote
Old 09-22-2014, 02:57 PM   #418
UrmyboyBLUE
another
Old 09-22-2014, 09:52 PM   #419
BRZ.SeriesBlue28
Any pic?
Old 09-22-2014, 09:56 PM   #420
BRZ.SeriesBlue28
Other than spacers and dropping it, I'm done for now.
Looking for something to change that's not too expensive.
Anyone change their side marker yet?
[ame="http://www.youtube.com/watch?v=utvO_nUreTQ"]http://www.youtube.com/watch?v=utvO_nUreTQ[/ame]
2015, brz, heuburger, series.blue
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. vh_supra26 BRZ First-Gen (2012+) — General Topics 393 07-30-2014 01:27 AM
10 series vs. 2015 fr-s initialrt Scion FR-S / Toyota 86 GT86 General Forum 33 06-28-2014 10:40 PM
2015 FR-S or discounted 2013 10 Series? bostnwhalr Scion FR-S / Toyota 86 GT86 General Forum 29 06-12-2014 10:19 PM
(10-SERIES) Any way to disable blue LED on emblems? R4PT0R-X Cosmetic Modification (Interior/Exterior/Lighting) 0 05-27-2014 10:46 PM
