Old 06-07-2017, 01:01 PM   #421
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Originally Posted by eddieflyinv View Post
Sorry for the delayed response,
Thats how those tables are supposed to look in their unmodified form, base timing B table looks normal, and so do all the others.
in mine I changed the rpm scaling for the base timing idle. Rather than the table ending @ 1800 I just combined/ eliminated tge duplicate values and used the last 4 columns to put negative values in the higher rpm range
So theres nothing wrong with your tables, thats just what they looked like before I changed anything,
If you dont mind me asking how did you go about changing the scaling on the Base Timing Idle table? I have been researching everywhere and have not gotten a good answer. Do I have to change it in the XML definition file?
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 06-07-2017, 01:19 PM   #422
eddieflyinv
eddieflyinv's Avatar
Nope, no xml editing needed
Click on a cell that holds the rpm values in the very top row of the table, and type in what you want it to be instead, hit enter (or in some cases manually click "set") and it will change the value. Thats what i mean by rescaling the axis
So stock has 550rpm to 750rpm all being the same value, I simply put 750 where 550 was in the first column, then since 800 & 1300 are the same, I put 1300rpm beside that, and just shifted the rest of the table over in the same way,
Getting rid of duplicate values gave me 4 columns to play with, so after moving everything over and having the 1800rpm column where 1300rpm used to be, I just filled in the rest of the table with what I wanted to see
eddieflyinv is offline   Reply With Quote
Old 06-07-2017, 02:42 PM   #423
Detroiter
Detroiter's Avatar
I was hoping it would be that. Way easier than what I was attempting to do. Thanks man!
I am going to be playing with values at different rpm to get more aggressive pops the harder I'm driving. Also I'm attempting to get the gun shot loud ones on downshift only in an attempt to avoid too much police attention.
Raven
Old 06-07-2017, 06:16 PM   #424
eddieflyinv
Aha if you figure out anything thats not already in here be sure to share it 👍
My biggest thing was wanting to reduce the delay in gun shots when downshifting, and I have some ideas but I havent been playing around with it much lately,
Old 06-11-2017, 04:54 AM   #425
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Aha if you figure out anything thats not already in here be sure to share it ��
Thank you for your great effort. I'm running a Gruppe-S UEL + overpipe, and a front pipe with a high flow cat and a custom exhaust. It pops like crazy with these settings:
Video (check around 3:10 for the best popcorn):
https://goo.gl/photos/Uhyg8jNZxd1uFKCL7
However I'm after no pops, just burbles, did you find that sweet spot? After shooting this video I limited the Base Timing Idle to 50% (-2.42), but not that much has changed. I'll see what it will do with halving it again.
Vin is offline   Reply With Quote
Old 06-11-2017, 08:17 AM   #426
eddieflyinv
I think low positives work best for burbles, i used to ramp the negative values in more conservatively and still have +10 around 2500, +5 around 3500 and then start getting further toward negative.
Also playing with the enrichment at the same time could help, seems that less fuel ignites more aggresively, and more fuel can help keep it to a burble along with extending thr burble duration
Old 06-11-2017, 09:54 AM   #427
Vin
Vin's Avatar
Thanks for the reply, never thought about going in the positives, I'll do as you suggested. I'll keep you posted on the findings
Old 06-21-2017, 04:56 AM   #428
Vin
Vin's Avatar
Small update on this. First I've tried like @eddieflyinv suggested, mostly to find the sweet spot:
+10 @ 2500
+5 @ 3500
+2.5 @ 4500
0 @ 5500
This produces some nice burbles, but also still some harder pops if you really want to. Sweet spot seemed to be around 3-3.5k rpm, so around +6 I assumed, so:
Then I tried +6 constant, which was to loud in the low revs
Also tried +10 constant, which was very nice in the low revs, but didnt produce any sounds above 5k rpm, so it seems the sound differs with RPM also, even if keeping the timing constant. For now I'll settle with the +10 +5 +2.5 0 settings posted above, might try something like +10 +5 +5 +5 or so in the future, but don't think it will make that much of a difference.
Old 06-21-2017, 05:19 AM   #429
Minsekt
Minsekt's Avatar
Drives: GT86
can confirm positive digits produce nice burbles too. for me -15 doesnt produce anything, -10 gives crazy pops, im using +8 for 800-2500, +3 2500-4000 and -8 4000-7400. i guess its different for every exhaust setup though.
Minsekt is offline   Reply With Quote
Old 07-03-2017, 07:41 AM   #430
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
Just read through the full post, but having some trouble understanding how RomRaider works as I just got my OFT last week, and just installed RR over the weekend. I just flashed to Stage 2 E85 last week, but I want loud pops and flames here and there, what do you guys recommend for the best results? Barely learning here, so no bashing please haha
WolF_RS is offline   Reply With Quote
Old 07-03-2017, 09:52 AM   #431
eddieflyinv
Someone pm'd me about not getting much pops with e85 before using these settings,
Not sure what the deal ended up being but my guess would be to use more initial enrichment when using e85 with the same ignition retard
Old 07-03-2017, 12:48 PM   #432
WolF_RS
WolF_RS's Avatar
Uhh... new language to me
2015 Ultramarine FRS - OFT Stage 2 E85 - TRD Intake - TRD Strut Bar - Tein Street Flex - Avid.1 AV-20 18x8.5/9.5 Staggered - Muteki Burnt Blue lugs - Toyo T1 Sports F:225/40/18, R: 245/40/18 - TOMEI UEL - TOMEI OP - BERK Straight Pipe - Tomei 80R - Valenti v2 Sequential Clear/Red Tail lights/4th Brake Light - TRD Japan Short Shift - LIKEWISE Deathgrip shift knob - LIKEWISE The Love Button drift knob
Old 07-03-2017, 01:01 PM   #433
Detroiter
Detroiter's Avatar
I definitely recommend using the method eddieflyinv and I are using for pops. It allows for pops on overrun rather than having to slightly hold the throttle. The latter felt more gimmicky to me where as the overrun way feels more like what you see in big turbo supra videos
With the method you will get very loud gunshot pops and I'm assuming flames if you're catless.
@504 @sqd @dhuang finally got around to this.
Just an example of my current settings for overrun, not too much has changed from my previous experiment, mind you im just starting playing with it again
First 3 tables are located in Fueling - Overrun Folder
- Overrun Initial Enrichment @ 1.2
- Fuel Cut Threshold @ 6000
- Overrun Enrichment Activation Delta @ -15
Last 2 Tables found in Ignition Timing - Advance Folder
- Rescaled the Base Timing Idle (In Gear Above Speed Threshold) table, like I mentioned before, my preference was for this to only start occurring when the engine was almost warmed up
- Raised the value in Base Timing Idle Vehicle Speed Threshold table, this helped quite a bit to avoid low speed jerkiness (10km/h because canada)
As mentioned before, may have to play with the amount of Overrun Enrichment and the values used to retard timing in the Base Timing Idle table, previous tunes were Stage 1 with Stock headers and catless overpipe, and with the stage 2 tune and no cats I have reduced Initial Enrichment from 2.8-1.8 to 1.2
Things acheived
- Lots of explosive crackles at high rpm lift,
- Crackles between shifts (with slight delay, seems to be more time related than rpm related, so OL/CL transition delay settings may potentially alter that)
- downshift bangs, lately they seem to be singular (only had this tune up again since last night) but theyre loud, though they are not rpm limited anymore, (never used to get them above 3krpm before)
- feathering popping/crackle, find that spot and it will pop endlessly, often on tip in there is a slight initial crackle, and if you have your cruise on going down hill your car will sound like automatic gunfire the whole way down �� not sure if the tip in crackles can be gotten rid of, seems to be table switching delay so maybe messing with the OL/CL transition delays could reduce or eliminate that as well.
Sent from my LG-H812 using Tapatalk
Raven
Old 07-03-2017, 01:24 PM   #434
WolF_RS
WolF_RS's Avatar
So, if I’m reading this properly, all I have to do is type in the same numbers as shown in the posted picture?
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
