Old 08-11-2014, 05:30 PM   #435
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by lucid215 View Post
it was a wot log from 2800 rpms to about 7500 rpms. this was done in 3rd gear
What scaling did you try and do? That will only be open loop which has no impact on LTFT at all.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-11-2014, 06:16 PM   #436
lucid215
ah gotcha. well damn then trying to figure out that javascript was for nothing haha what range of rpms should i be logging to try and scale the maf?
lucid215 is offline   Reply With Quote
Old 08-11-2014, 06:58 PM   #437
Kodename47
Kodename47's Avatar
Drives: UK GT86
Look at @steve99's signature, there's a link with good info.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-11-2014, 07:10 PM   #438
steve99
Originally Posted by troek View Post
im comparing tables and not seeing any differences other than a couple changes in low rpms in knock correction advance max A. were there no changes for 93 users? just toned down maps for 91?
Yes the 91/93 maps in v2 tunes only the one ignition table different, but many changes between v1.5x and V2 maps including Maf and fueling tables.
Old 08-11-2014, 08:57 PM   #439
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by JB86'd View Post
plugged in my OFT to take a datalog after a mellow freeway drive toward home..to my surprise my IAM was down at .7 already when I plugged it in. So I did a datalog anyway, and am seeing some Fuel Trim, FLKC and KC Learned values and am not sure that they're acceptable.
I now have about 100 miles on this tune, so I'm guessing it should be fully learned? Do I need to reflash and do something differently? Or is this just a result of California 91 Octane?
http://datazap.me/u/joshbustos86/frs...ata=1-6-8-9-12
Please help @steve99 @Shiv@Openflash
Actually gonna try the Vishnu Reset trick to get my IAM back up to 1 tomorrow and see if it helps.
What intake are you running? Curious since you seem to be logging higher MAF voltages than I am with a stage 1 tune.
Old 08-11-2014, 09:05 PM   #440
lucid215
Yea I've looked his stuff. Still trying to comprehend some of it haha
Old 08-11-2014, 09:51 PM   #441
JB86'd
JB86'd's Avatar
Drives: JAWS
Stock intake, unmodified, AFE dryflow filter. You on the 2.0 maps?
Old 08-11-2014, 10:20 PM   #442
steve99
Based on feedback for a few guys posting in this thread made some changes to the Knock correction thread to hopefully make it easier to understand
http://www.ft86club.com/forums/showthread.php?t=61820
Old 08-12-2014, 12:23 AM   #443
troek
troek's Avatar
Drives: 2012 Toyota 86
no i was talking about my 1.5 UEL map vs the 2.0 UEL 93. but i realised i was lookinig at one map with the incorrect xml file, since you cant load 2 xmls at once. ill have to figure out a different way to compare the tables.
Old 08-12-2014, 01:05 AM   #444
steve99
ROMRAIDER can load two tunes with different xml definitions. however the oft roms have had the calid,s changed so that the oft will load roms but it confuses romraider sometimes.
If you manually switch definition files each time you open a rom by making the correct xml the first or only one in list you can get around it. just make sure you have correct def in for a save or it might be nasty.
always best to re-open a saved rom and check the tables to be sure
Old 08-12-2014, 01:41 AM   #445
troek
troek's Avatar
arigatou, sensei.
Old 08-12-2014, 02:11 AM   #446
clintavo
Has anyone else noticed hesitation/ bogging at 1500 rpm when floored?
I realize this is a somewhat rare scenario, but I have run into it twice:
Loafing around a parking lot in 2nd gear, suddenly to get out of someone's way.
Starting from a stop uphill.
It is repeatable; floor it at 1500 rpm and it completely bogs. It never happened with 1.3 or 1.6
BTW the throttle calibration seems much smoother in this tune : )
Thanks Shiv!
clintavo is offline   Reply With Quote
Old 08-12-2014, 02:57 AM   #447
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I can't tell what version the maps are on my tablet. How do I load the 2.0 maps onto the OFT?
Download the maps, unzip the maps folder into the Openflash folder?
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 08-12-2014, 03:12 AM   #448
steve99
see OFT TIPS post below links to youtube tutorial
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
