Old 03-18-2025, 12:35 AM   #4495
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
Originally Posted by Racecomp Engineering View Post
I'm always so nervous about this that I'm so mega-careful and thankfully have never had it happen to me.
You could always get a new rear subframe.
- Andrew
It's not the subframe that's damaged. It's the threads in the chassis.
Anyway, I ran the tap up through. It barely did anything on one side, so I feel good about that. On the other side, it did quite a bit of cutting, and the thread fit is sloppy, but the torque wrench clicked at 107, so
-Mike
grippgoat is offline   Reply With Quote
Old 03-25-2025, 06:28 PM   #4496
Tokay444
Anti stance.
Tokay444's Avatar
I'll shim the piss out of a clearance bore. Nothing wrong with stacking material. What are the actual dimensions?
What size shim would you start with?
Old 03-25-2025, 10:50 PM   #4497
Ultramaroon
not playing cards
Ultramaroon's Avatar
You're going to need the actual dims when you specify your custom spacers. It would've been easier to give the numbers like I asked.
Old 03-25-2025, 10:59 PM   #4498
Tokay444
Anti stance.
Tokay444's Avatar
Lol.
Old 03-26-2025, 09:10 AM   #4499
Tokay444
Anti stance.
Tokay444's Avatar
Again, I know the original question was very difficult, but I’ve already got them modelled and programmed, so the answer is, “I will be.”
Old 03-26-2025, 12:05 PM   #4500
Ultramaroon
not playing cards
Nobody makes them because they aren't necessary. See how the axes are made collinear at one end? That's all you need. The rest is for ease of assembly.
Old 03-26-2025, 02:25 PM   #4501
Tokay444
Anti stance.
Tokay444's Avatar
Now I make them.
Old 03-26-2025, 04:23 PM   #4502
Ohio Enthusiast
Drives: 2018 BRZ
Now I make them.
Pretty impressive. Report back how it affects installation of the control arm.
Ohio Enthusiast is offline   Reply With Quote
Old 03-26-2025, 05:22 PM   #4503
Tokay444
Anti stance.
Tokay444's Avatar
Won't pose any issue at all.
Old 04-01-2025, 05:43 PM   #4504
Muffled
Anyone have experience with Tein EnduraPro shocks/struts, for lowering springs specifically?
I'm considering pairing these with D2 lowering springs I already have. I want something that can handle a lowering spring long term without blowing like the OE damper. The adjustability is a nice bonus to me.
Tein's marketing is a bit confusing. They say these are intended to be used with OE size springs, but can be used with Tein lowering springs as well. I understand there may be differences in bump/droop travel between this and a B8, but my priority is reliability.
These are WAY cheaper than a Koni Yellow or Bilstein B8 - enough to give me pause. I understand you often get what you pay for in the aftermarket, but I do due diligence when there's a $700+ price delta.
So, what gives?
Muffled is offline   Reply With Quote
Old 05-19-2025, 03:45 AM   #4505
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
The Raceseng plates are/were great, but not a good fit on OEM dampers in my opinion since they ate up some travel.
An option that's getting more popular these days is the Pedders front mounts, which are a non-adjustable OEM type rubber mount that's offset for a little camber and caster. You won't get anywhere near what you'd get with a all-metal adjustable camber plate, but it's easy and reliable. Maybe -2 with the "OEM crash bolt" or thereabouts.
- Andrew
Since I'm going to have the car apart for camber mods it is time to consider springs. The JDM STI springs caught my attention as something that the car probably should have come with. Do you have any experience with how these springs change the car? I've seen good comments from everyone who matured past slamming and dragging, so that is encouraging.
RotARy15 is offline   Reply With Quote
Old 05-20-2025, 06:38 PM   #4506
It's a mild change compared to other springs, which is not a bad thing. I'd run them if I had them laying around.
- Andrew
Old 05-20-2025, 08:58 PM   #4507
new2subaru
Weight Weenie
Drives: 15 FR-S
RCE yellows. I had them on my car for quite some time. Nice casual drop and a good ride. I highly recommend them.
Old 05-20-2025, 09:26 PM   #4508
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
- Andrew
My initial impression of your response is, is that all?
I could not help but wonder what RotARy15 is doing these mods to his car for and how will he drive it...
I guess your answer is brief because you don't want to get into detailed advice based on usage. I wonder about the quality of advice if you don't ask questions so you can give better advice.
Scargod is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
