Old 05-28-2025, 12:19 AM   #4523
Originally Posted by J95 View Post
can you please elaborate? I meant that my tyres seemed to fade pretty early (2 laps at 2min track), while the pads seemed to last ok, so I wonder if I can make profit of track pads in my current setup. thx!
If you're tires are overheating in 2 laps, you'll want to make sure you have appropriate tires and are not overdriving them.
You'll always benefit from having better pads.
Old 05-29-2025, 04:34 PM   #4524
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
Originally Posted by Racecomp Engineering View Post
Correct. The Cusco rear LCA has what's basically a ”flip chip” to give you the option and some other LCAs have multiple holes.
I like and use the Cuscos on my 1st gen. I've added rear track width but still use the "old" lower motion ratio setting. You get a tiny bit more wheel travel in that setting. The difference in stiffness isn't very big either way, it's much less than a 1 kg/mm jump in spring rates for example.
- Andrew
I ordered several STI parts because why not. Springs, Engine and Trans mount, and steering rack long bolt kit. I also ordered Whiteline diff inserts and the Perrin Lockdown stuff. I got the feeling that subframe inserts would add the most NVH, so I'm going to see how high NVH gets with all of these one at a time, and if I end up with leftover tolerance, then I'll keep going.
Of all the options for anti-squat, which do you recommend? I'm hopeful that these tame the rear during throttle spikes more than they promote general understeer.
RotARy15 is offline   Reply With Quote
Old 05-29-2025, 08:59 PM   #4525
I recommend and use the MCA traction mod on my car. I'd consider the GP sports piece, I'd not use the GKtech one.
For the diff inserts, you can reduce the resulting noise quite a bit if you don't install either the top or bottom of the forward inserts. I think I removed the bottom after installing and it was just right for me.
- Andrew
Old 05-29-2025, 11:32 PM   #4526
RotARy15
- Andrew
Does anyone state-side carry these things? Also, where the hell do I buy or even pirate a service manual? There is a bunch of bracing under here that took more than 1 ugaduga to remove.
Old 05-30-2025, 12:43 AM   #4527
2.2Lude
2.2Lude's Avatar
Manual with ChatGPT built in : https://chatgpt.com/g/g-6833a1665544...013-frs-expert
2.2Lude is offline   Reply With Quote
Old 06-02-2025, 08:31 PM   #4528
RotARy15
Not sure this is the right thread for driveline mod reviews so I'll keep it brief.
Perrin Lockdown + STI long bolts: Absolutely worth it, but the dollar to benefit ratio isn't super high. I can afford it, but others may find more value in other mods. I'm super happy with it. One downside, surprise surprise, if you unbolt the steering rack, expect to need an alignment.
STI Transmission Mount: Absolutely worth it. I only notice gear whine on smooth roads with the radio off in a stock car while actively trying to hear it. Well worth the money. Car actually seems smoother to drive, and more responsive. Do it.
I managed to bandsaw the blocks off the STI engine mounts, just waiting on hardware from Subaru. Prepping to do diff bushing inserts this week.
Old 06-03-2025, 02:01 PM   #4529
smoltz
Drives: 01 911 Turbo, 03 G500
Running Tarmac 2s. After having the car corner balanced, I noticed a clunking from right front. Lifted it up and it appears because the adjustable perch is so low (to get cross weights even) that there isn't any tension on the spring causing this to rattle. Is there a solution here or do I just live with it? Car is only driven on track, I just don't like rattles because hard to tell if it's a normal rattle or a bad rattle.
https://www.youtube.com/shorts/mNksa_48p0g
smoltz is offline   Reply With Quote
Old 06-03-2025, 02:16 PM   #4530
Ohio Enthusiast
Drives: 2018 BRZ
Those look like Swift springs. How long are they? From what I read Swift doesn't offer 170mm springs like the original KW ones, you either use 6" (too short) or 7" (too long). Are yours 6"? The RCE setup guide has a minimal distance from spring perch to top mounting hole of the strut of 70mm. What's your measurement there? If you're below 70mm you might need to raise all four corners so that every corner is above the minimum height.
Ohio Enthusiast is offline   Reply With Quote
Old 06-04-2025, 09:41 AM   #4531
smoltz
Thanks for the suggestion and pointers to to docs, I will take some measurements and see what I find.
Old 06-04-2025, 09:18 PM   #4532
We're on travel to gridlife, but give us a call or email and we can sort you out.
- Andrew
Old 07-16-2025, 05:14 PM   #4533
new2subaru
Weight Weenie
Drives: 15 FR-S
It's Andrews fault...I look forward to trying these.
Old 07-16-2025, 11:00 PM   #4534
Lol. Someone at MCA and someone at STI owes me a beer.
- Andrew
Old 07-16-2025, 11:09 PM   #4535
new2subaru
Weight Weenie
Drives: 15 FR-S
- Andrew
Aussieland and Japan are a long ways to go for a beer but it would be nice!
Old 07-17-2025, 10:47 PM   #4536
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You won't be disappointed. Definitely on list of mods I'd do right away if I got another one.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
