Old 08-20-2025, 04:33 PM   #4537
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
Originally Posted by Racecomp Engineering View Post
Lol. Someone at MCA and someone at STI owes me a beer.
- Andrew
2 beers.
Installed the MCA TMv2 along with STI trailing arms and subframe bushing inserts. Ride quality is much better. As others have said, feels like a properly sorted car now.
I haven't tested balance at the limit since the street offers little room for that but the couple of turns I can play with on the way to work seem to suggest improved rear traction out of a 20mph right hand turn so... that's a good sign.
I elected to simply bend the handbrake bracket to accommodate. Keep in mind that as the suspension compresses, the bracket pinches the brake cable even harder. So I jacked the knuckle up to ride height while I bent the bracket in a bench vise and test fit several times. Then I test fit with my ARC8/R-S4 for clearance. Had over an inch of room so that wasn't a problem at all. The bracket ended up really only limiting lateral movement of the brake cable. Seemed a good result since I expect actual suspension compression would obviously make the angles even worse.
Very happy with this mod. The change in ride quality is enough that even if this induces understeer, I'm happy to correct that by other means. I don't want to remove this mod from the car.
Even after installing all these parts at once, and loosening the subframe to do so, I'm surprised to find the alignment feels unaffected. Haven't measured it yet as I already planned to realign in a few weeks, but it feels like maybe the rear toed in just a hair. I had a very rough 0 toe setup before which drove like a 0 toe (hint of wondering on highway), but after the install it seems a bit more centered now. I plan to return to 0 toe anyway. Just wanted to note that the alignment is, for most purposes, unaffected.
RotARy15 is offline   Reply With Quote
Old 08-20-2025, 05:54 PM   #4538
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Originally Posted by new2subaru View Post
It's Andrews fault...I look forward to trying these.
What are these?
Sent from my SM-S901U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 08-20-2025, 07:51 PM   #4539
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by bmacfrs View Post
What are these?
MCA traction mod and the STI trailing arms.
Old 08-30-2025, 08:44 AM   #4540
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I bought the Cusco 965 935 A steering rack bushings for and it didn't come with any grease. I'm used to seeing PU bushings from other brands come with a small packet of grease, so is it not required when installing these bushings? The installation instructions don't mention anything about grease either.
N_Raged is offline   Reply With Quote
Old 08-30-2025, 11:39 AM   #4541
2.2Lude
2.2Lude's Avatar
How in the world can I stop the Brembo GT calipers from squealing? Grease doesn’t work at all, I can’t even look at the brake pedal without them making noise. Pretty insane actually.
2.2Lude is offline   Reply With Quote
Old 08-31-2025, 01:25 PM   #4542
What pads?
- Andrew
Old 08-31-2025, 01:26 PM   #4543
I'd probably put a little in there. Some PU I think will claim to be "self lubricating" or whatever...not my area of expertise though.
- Andrew
Old 09-01-2025, 01:58 AM   #4544
2.2Lude
2.2Lude's Avatar
What pads?
- Andrew
XP12’s currently. I’ve ran this same compound on the base calipers and while they weren’t super quiet, they weren’t this embarrassingly loud.
I’m thinking of grabbing a set of 1521 or GS1’s but I’m worried even those won’t be quiet as I’ve read of people using your average ceramic of semi-met pads but still dealing with a crazy amount of noise.
Old 09-01-2025, 09:58 AM   #4545
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Get blank discs. This was literally only thing that has worked for me.
MrSkubi is offline   Reply With Quote
Old 09-01-2025, 10:05 PM   #4546
Hmmm, I've only got a limited amount of experience with those pads but I do remember them being a little loud with the Brembos.
- Andrew
Old 09-02-2025, 10:50 AM   #4547
2.2Lude
2.2Lude's Avatar
Already on blanks unfortunately. Thank you for the suggestion though.
Old 09-02-2025, 10:53 AM   #4548
2.2Lude
2.2Lude's Avatar
- Andrew
Andrew,
Any experience shims with the Brembos?
FWIW I have the CSG spec Brembo GT calipers on blank rotors and XP12’s.
Old 09-03-2025, 02:57 AM   #4549
MrSkubi
MrSkubi's Avatar
That's unfortunate. I did swap to blank discs in my GT 6005A kit a while ago and it get noticeably quieter even with Ferodo DS Uno pads. On Brembo Xtra pads it almost never makes any noises even unlubricated.
Old 09-03-2025, 07:55 PM   #4550
RotARy15
So prior to this I was aligning the car with strings but without a way to reduce friction so I was just lifting the car, making a change based on the difference between ground and airbourne measurements, then re-measuring on the ground. Front was no problem. But the rear was a fight I couldn't explain.
Then I finally got some alignment plates and built wheel stands. The amount that rear toe and camber affect each other is giving me flashbacks to working at a shop and trying to align NA/NB Miatas.
Also, holy crap does driver weight affect passenger side camber. First alignment attempt was also without weight and the right front was locked down at -2.5. With driver weight, it measured -3.0. This is on imported STI pink springs. Driver side didn't seem to move as much with weight.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
