Old 12-14-2022, 12:42 AM   #4747
Originally Posted by Jeff86 View Post
I'm a little afraid that high rpms could slip on a 270 tq clutch (ACT HDSS). The OS Giken seems a better choice at 300. I'm also interested in the ACT XTSS. It seems quite up to the task if it isn't a pain to drive. What are your thoughts on that option?
The HDSS should hold fine, unless you're driving abusively!
Old 12-14-2022, 11:17 AM   #4748
B T
@CSG_Mike How is the pedal feel with the OS Giken vs the ACT? Stiffer, lighter or about the same?
B T is offline   Reply With Quote
Old 12-14-2022, 03:03 PM   #4749
ACT is heavier at the hump, and lightens at the bottom, like OEM.
The CSG OS Giken single is lighter at the hump, but (almost) linearly increases in weight as you go down.
Old 12-14-2022, 05:26 PM   #4750
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
You guys' impressions are super useful. Thank you so much! I know a stiffass clutch will hold, but it takes a lot of practice to launch without shuddering. I'd love to avoid that in this car!
Jeff86 is offline   Reply With Quote
Old 12-14-2022, 06:49 PM   #4751
Both suggestions I made are 100% streetable with a minimal learning curve. If you're getting shuddering, you need to give it slightly more rpm.
Old 12-14-2022, 10:26 PM   #4752
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
After 14 years on my stage 4, 6 puck CC on the Acura, I’m good at it lol. Just not really wanting to roll that way with this car. Thanks again for these options.
Old 12-28-2022, 11:28 AM   #4753
B T
Finally did my 3.7 final drive gear over the weekend and I love it. If you're on the fence just go for it. I'm measuring roughly 6 mpg higher average on the interstate and it's much quieter at the lower rpm. You'll basically lose 6th gear for anything other than interstate driving however. It still pulls great through 3rd, which now gets me over 100 mph.
Old 12-29-2022, 03:22 PM   #4754
FrickingReallySlow
Drives: 2015 FR-S
Did you do this mainly for the MPG and noise or so that you can stay in 3rd for a specific speed range? do you not feel it struggle more taking off at lights or do not car?
FrickingReallySlow is offline   Reply With Quote
Old 12-30-2022, 10:38 AM   #4755
B T
I wanted a little better traction in 1st and 2nd on ethanol, less noise and more mpg so it was just all around a good idea since I daily drive my car. It won't be as fast out of corners at the track anymore but I'll still have fun. It does struggle a little at the lights, but it was already struggling with all the parasitic loss. Overall driving is much more relaxed. I wonder if the 3.9 may have been a better option but not going to change it again. NOLA usually gets me up to about 120 on the straight, most other places in the south east is 110, so the gearing fits pretty nicely.
Old 01-06-2023, 08:43 PM   #4756
RSR02
Drives: 2015 FRS
I have a 2015 FRS with an Edelbrock kit, bigger fuel pump, 700cc injectors, catless header with TRD exhaust, and the Delicous flex fuel sensor and tune. I am now on my second tune revision and still having idle issues.
Car has about 94K and before the swap ran fine with no idle issues.
The car will cold and hot start fine and seems to run fine everywhere except at idle. At almost every stop it will either idle around 1900-2000 or bounce from 500 to 1300ish over and over. It has also died several times in traffic.
So far I've pulled the battery and done the complete idle re-learn procedure several times. Cleaned the battery terminals and alternator connection. Cleaned the MAF and TMAP sensors along with the throttle body. Iv'e also checked for vacuum leaks with no luck.
What do I try next?
RSR02 is offline   Reply With Quote
Old 01-07-2023, 02:17 AM   #4757
dpfarr
Drives: BRZ ts
No codes?
dpfarr is offline   Reply With Quote
Old 01-07-2023, 11:27 PM   #4758
What do I try next?
Is your tuner unable to give you any direction on possible causes?
Old 01-08-2023, 03:24 AM   #4759
tomm.brz
Drives: brz 2017 hksv2
What do I try next?
probably tune related , as for example a bad maf rescaling , would need to see some logs of it to know better
Old 01-10-2023, 07:56 PM   #4760
RSR02
Drives: 2015 FRS
The tuner (Delicious Tuning) has sent a third tune which I'm now trying. Still had issues with the high idle several times today but it didn't do the low rpm bounce/stall.
No codes. Stock MAF and using the TMAP that comes with the supercharger.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
