Old 05-18-2023, 05:18 AM   #4845
tomm.brz
Drives: brz 2017 hksv2
i ve retuned many edelbrock, even after they tuned firsr with delicious
not a single one has idle problems
delicious tunes are like that.
it s a sd 100% based tune and fuel trims are always too erratic and the idle stability strategy isn t well set
it s also quite erratic during open loop
Old 05-18-2023, 03:36 PM   #4846
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Originally Posted by Jeff86 View Post
I have to say that I’ve got a very new Edelbrock SC and a Delicious tune. The warmer the weather has become the more erratic the idle is. It’s super annoying. Right after startup and after driving a fair distance, everything is wonderful… no issues. Get in the car and restarting after going to the grocery and it’s a complete disaster. Idle bouncing and car trying to die. It sucks and I’m about to switch to a tune from CSG. I just want to know… is there anyone out there with this supercharger and a Delicious flex fuel tune that ISN’T having these types of issues at all?
I can't answer your question about a Delicious Tune, but I can confirm (as have many others) that tuning by Zach at CSG has provided great results and in my case more "smiles per mile" than anything short of the SC itself.
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
Old 05-19-2023, 08:48 AM   #4847
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
This is exactly what's happening with my car. Driving from cold start is usually ok with no major issues. After starting up warm, the car seems to rough idle and that's where I am getting the most stuttering and lean fuel trims. Difference from yours is I am running CSG Zach's tune.
Not to mention boost pressure feels weak compared to when I upload a new tune or reconnect the battery. Car feels very powerful at the beginning but as the ECU adjusts, I feel like I lost most of that power I had at the beginning. Still convinced its a vacuum leak...
On an unrelated note, can a completely worn out clutch confuse the ECU? I am at a stage where I just replaced my clutch but did not get the chance to drive it. Wondering if slippage limits some of the power that the SC can output. I upgraded from OEM to OS Giken Single.
GPhilly is offline   Reply With Quote
Old 05-19-2023, 09:17 AM   #4848
tomm.brz
haven t you reached out zach at csg to check on your logs?
DO you have logs then ?
Old 05-19-2023, 09:46 AM   #4849
GPhilly
GPhilly's Avatar
Of course, Zach and I have been in touch. He's aware somethings up.
Unfortunately, I am on the other side of the US so I have to do some mechanical checks on my end and now I'm having a shop specialized in this platform looking at it. Hopefully they find something.
Old 05-22-2023, 11:27 AM   #4850
B T
My car threw a P0171 code the other day, checked my OBD2 and found a 24% LTFT. Turns out the Delicious D-Box DESS module quit sending its signal to the ECU but was still reading the percentage over bluetooth just fine. ECUTEK logs showed a 0% in fuel corrections and ethanol percentage. Has anyone else seen failures on these modules?
B T is offline   Reply With Quote
Old 05-23-2023, 08:56 AM   #4851
Colin86
Drives: 86
My car has had intermediate idle issues and it's always been a failing bypass valve. Have replaced it three times now over nearly ten years and roughly 10k miles. Hoping this new larger bypass lasts longer. For what it's worth Zach's new tunes through CSG seem better than ever, but the idle issue I've experienced haven't been tune related.
I don't have the DESS module, but I have the flex fuel module and the bluetooth has failed as far as I can tell. Although it's the opposite, it's still sending good ethanol content signal (so far) to the ECU.
Colin86 is offline   Reply With Quote
Old 05-23-2023, 01:12 PM   #4852
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
That's irritating to hear. I bought a brand new supercharger directly from Edelbrock. The install was straightforward and solidly executed. I shouldn't be experiencing a mechanical problem with a bypass valve on a brand new install. I'm also curious why heat seems to be a factor and things are smooth until it's restarted warm.
Jeff86 is offline   Reply With Quote
Old 05-23-2023, 02:18 PM   #4853
Colin86
Drives: 86
In theory the new bypass should (hopefully) be more reliable -if you bought the kit relatively recently you probably already have the revised unit. I installed the new style bypass last year, it's not failed yet but I've only driven it a couple thousand miles or so.
Edit: I'll also mention it's not all doom and gloom. Other than the bypass valve my edlebrock kit has functioned flawlessly for nearly ten years with regular track days. Car is driven hard and doesn't skip a beat.
Old 05-23-2023, 02:44 PM   #4854
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
That's what I was hoping when I bought a new one (that the valve would be the newer design). I just bought and installed over the winter. Any way to tell what valve I got?
Old 05-23-2023, 03:53 PM   #4855
B T
How many mounting bolts does it have? I seem to remember the original had 3 and the new has 2. I replaced mine with the newer version about 3/4 years ago and haven't change it since. 20k driven since then.
Old 05-23-2023, 05:58 PM   #4856
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I bought a used unit. The seller provided an uninstalled updated bypass. I removed the original 3 bolt bypass and installed & calibrated the updated 2 bolt version. It has been flawless. Mind you, it is fed vacuum from a remote MAP sensor set-up. Not directly from the manifold.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 05-23-2023, 06:11 PM   #4857
B T
Mine pulls from the brake booster line.
Old 05-23-2023, 06:14 PM   #4858
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Welp... mine's the new type. lol
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
