#477 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Additionally, I am not being funded or asked to say these things. I really want this platform to grow!
#478 | |
If it's that easy, we would have plenty of options already as well as being cheap so swaps would be everywhere, instead of people struggling in this thread for years?
#479 | |
First 86 Driver Baby!
Drives: FR-S, Flex
I'm moving to the DC area in a couple of months and definitely want to check out your swap! I'm considering an LS3 swap in the future and this may very well sway me to do a swap. |
#480 | |
Drives: FRS Silver LS1 swapped.
#481 |
Drives: 85 corolla gts
To integrate the box into the can system it requires 2 wires run to the can that would typically go to the ecu. You also need to add in a 120 ohm resistor for termination. Delphi offers one using a gt150 2 pin connector and mouser stocks them. For install you would want to build a harness. For some applications, redoing the engine bay connectors and making a plug and play adapter harness to plug in were the factory ecu goes would work. For other applications I feel the factory engine harness connector is to close to the exhaust and could pose issues. In that application I recommend building a engine harness, removing the unused wires at the factory engine harness connector, and repin / make new connectors for the needed wiring at the factory engine harness connector.
#482 |
Road-hole
Drives: 2013 Whiteout FR-S
Sorry...
I avoid ANYTHING that isn't willing to have a price posted up front.. I'll stick with the DIY arduino when I do a swap that requires canbus functionality...
Jaden |
#483 |
What is your reasoning? Do you feel that they're going to cheat you? Or are you too lazy to send a PM/email to someone?
#484 | |
That Guy
Drives: 2013 asphalt FRS MT
That lack of transparency seems pretty shady to me. If I had the money for this I'm not sure if it would steer me away from them or not, but it would certainly give me pause. |
#485 | |
As I have the Emtron KV8 EMS powering my 2JZ swapped FRS, I can tell you first hand it's worth the time and money for this standalone. If you want to have a haggard car with multiple piggybacks, go ahead. Just seems like a band-aid attempt to fix something.
#486 | |
Road-hole
because in my experience...
Jaden |
#487 | |
Road-hole
multiple piggybacks...
Jaden |
#488 | |
I can tell you with 100% certainty that the Emtron EMS is not overpriced.
#489 | |
That Guy
And I didn't question the product. By every account I've read of it, it's awesome. I was only suggesting a reason why the no public prices stipulation could be viewed as a negative. |
#490 |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I doubt a kit from Vorshlag will be sold at this point.
| FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates | Steeze_Its | Brakes, Suspension, Chassis | 7 | 06-27-2014 10:32 PM |
| FS: Vorshlag Front Camber Plates | h4nh | Brakes, Suspension, Chassis | 1 | 03-01-2014 11:49 PM |
| FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 09:51 PM |
| WTB: Front Vorshlag Camber Plates | YDNA | Brakes, Suspension, Chassis | 0 | 05-03-2013 06:31 PM |
| Maybe a repost, but have you seen the Vorshlag project car? | Bart1 | BRZ First-Gen (2012+) — General Topics | 3 | 01-07-2013 02:19 PM |
