Old 11-01-2015, 04:56 PM   #477
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
If you are going catless, the stock muffler will sound like tin can... Quiet though.
Intent > Content
Old 11-01-2015, 05:02 PM   #478
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by kuno View Post
What about switching to the stock front pipe and see whether that will reduce the noise. Should be an easy swap before you start selling the catback etc
Sent from my SM-G920I using Tapatalk
This. The stock front pipe should be a little quieter.
jawn is offline   Reply With Quote
Old 11-01-2015, 05:38 PM   #479
twag4
Drives: frs
restricting the flow with a stock cat kinda defeats the purpose of an excellent flowing header. I do have a high flow cat already. just need to figure out a muffler situation that will quiet this down. But it is worth a try for experimental purposes- when I have time.
twag4 is offline   Reply With Quote
Old 11-01-2015, 07:02 PM   #480
sw20kosh
Drives: 2013 Black FR-S
I am going with the ace muffler. It will be tested on ACE header/FP equiped vehicles and will be tuned to sound the best combined with these parts. Put on your stock muffler temporarily and also tripple check for exhaust leaks.
Old 11-01-2015, 07:30 PM   #481
Hawk77FT
Drives: GTS 86
I would drive the car for couple of hundred kms/miles as the carbon build up in the header will make it a bit quieter. Like much quieter...with that said however, if it is too loud you might want to look into bolting in a Helmholtz resonator in, or maybe even a nice hotdog resonator (use the perforated one, not the louvered one). You should not have any issues finding something suitable as 2.5 diam are the most common. You can even take the resonator you have out, and replace it with something longer.
I have 2.75 header back and is not that loud (but I have the silencers in). So I am always trying to find a way to take them out and make my exhaust quieter too!
Good luck!
Hawk77FT is offline   Reply With Quote
Old 11-01-2015, 08:48 PM   #482
churchx
churchx's Avatar
Drives: 2014 GT86
Not exactly so. 2ndary cat in frontpipe doesn't hurt exhaust performance that much as 1st stock one, placed very close to cylinders in exhaust path (to heat up to working temps sooner to ease passing regulations soon after cold start). Many keep stock 2nd cat to pass smog checks in their countries, when highflow one was not sufficient. CSG got wonderful performance out of Type A 350 even with stock everything rest. So i don't see much problems except maybe religious ones due OE being not kosher in putting back stock as temporary interim solution to get noise in check (unless of course it's sold when you got your current aftermarket catback )
Old 11-01-2015, 10:44 PM   #483
I don't need stock quiet. In fact, I don't want stock quiet. Like I said in my above post, it was a bit loud, but sounded very good before the header. What would be your honest recommendation for 2.5" front pipe and cat back. I must do something different. I am considering stock catback. I am also considering just putting stock manifold back on until I can afford something different. I never imagined this header would more than double my volume. I have done many headers on v8 hot rods in the past. I've even done some cat deletes among some of the more modern of them, but nothing has ever been even close to this drastic of a change. Please give me your recommendation, this setup now is going to get me arrested.
A compromise would be your stock front pipe, with ace header, and Corsa exhaust.
Try it, before doing anything that costs money.
Old 11-01-2015, 11:01 PM   #484
twag4
Drives: frs
Two people now have suggested this. I will make it my next step.
Old 11-01-2015, 11:06 PM   #485
twag4
Drives: frs
You are not the only one to have suggested this. Thanks, and I will give it a try.
Old 11-02-2015, 12:42 AM   #486
kuno
No worries. I suggested it cause that is the likely setup that I will try on my car. (Tanabe concept G catback, stock front pipe and ace header). Fingers crossed it would not be too loud or drone :p
kuno is offline   Reply With Quote
Old 11-02-2015, 07:07 AM   #487
dazbrz
I just recently got mine installed over weekend... Ace headers, stock front/mid pipe and sti exhaust......only slightly louder when im daily driving...but foot to the floor...the thing screams =)
dazbrz is offline   Reply With Quote
Old 11-02-2015, 02:10 PM   #488
twag4
Drives: frs
I went to a local guy today, who has a fix for my high volume. The Corsa exhaust has a two piece mid pipe. He is going to make a new front half with a 22" long x 4"diameter straight through resonator that he promises will quiet everything down. This is great news because I won't have to cut up any part of my Corsa system now. Going to go ahead and try the stock front pipe today, just to see. I will report back...
Old 11-02-2015, 03:30 PM   #489
solidONE
solidONE's Avatar
The stock front pipe will work for sure, but I like the idea of a large resonator either on the FP or mid-pipe (or both), as big as one can fit without clearance issue since it seem to be the best solution to cancel out drone. If you can imagine in your mind how an exhaust vibrates under high exhaust loads it's not hard to understand way this works so well and why those track pipes /mufler delete/axlebacks that retain the large factory mid-pipe make such a nice note.
I've actually fabricated a 63mm front pipe with a very long resonator. To be honest, I cannot tell much of a difference in exhaust volume or note between my resonated pipe vs the stock pipe. Though it's not easy to fit such a big resonator on the front pipe.
Intent > Content
Old 11-02-2015, 03:36 PM   #490
Slowmotion
Drives: 04.5 GLI, 01 A4 Avant, RS 1.0
Well, installed the Type A 350 header and it is magnificent to behold. There is a problem however: I am running a JDL ultra quiet front pipe and Corsa cat back and it is loud. I mean ear drums bleeding loud. I finally have my dream setup, and it is stupid. It also has Jackson racing supercharger on it. The ultra quiet front pipe has a 200 cell cat and a resonator in it, the Corsa has a big resonator and a muffler. What now? I daily this car, and I need to quiet it down. Please don't tell me to put the stock cat back on it, they get pretty buzzy. Has anybody had experience with adding another resonator to the system? What about a bigger muffler? @CSG Mike what say you? I have spent a bunch of money on my car, especially on the exhaust, and it is too loud for a track now- let alone the street.
If your exhaust setup is as loud as you say it is, I'll be sad since your exhaust setup is what I wanted for my FRS! I was thinking that with the ACE header, a HFC and Corsa exhaust would've been reasonable... but I guess not. Though, I'm curious to see what you find quiets down the exhaust. Though, I do have one question though, when was it ear bleeding loud? Cruising, acceleration or both?
Slowmotion is offline   Reply With Quote
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
