Old 12-08-2015, 03:27 PM   #477
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
Originally Posted by NotSoJDM View Post
I just had a chance to put my single can in over the weekend. I opted for the universal can because I wanted to mount it in the extra area near my small battery setup, and was not 100% that the Radium bracket would not interfere with my hood struts.
Just an FYI for others with the same concern, I run the grimspeed hood struts with the Radium catch can and bracket with no problem. Cars away for the winter otherwise I'd snap a quick photo for you guys.
D18 is offline   Reply With Quote
Old 12-09-2015, 04:12 PM   #478
Yoda
Drives: Crystal Black BRZ(Sophia)
Silly question do you get that feeling of being pushed back in your seat like what a turbo would give you? How would you describe the feeling of the SC?
Yoda is offline   Reply With Quote
Old 12-09-2015, 04:26 PM   #479
No, it just feels like you have a bigger engine. Like a V6.
Old 12-10-2015, 12:12 PM   #480
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
[ame]http://youtu.be/QZ84KA42M8U[/ame]
NotSoJDM is offline   Reply With Quote
Old 12-10-2015, 02:32 PM   #481
djdnz
1337
Drives: 2013 BRZ WRB S/C
So this morning I was pulling onto the highway and noticed the car surging a little on part throttle, it feels like it's pulling timing and was most noticeable around 3.5k RPM. It's on 91octane, the car was warm, ambient temperature was about 55F. My fuel was less than 1/8th of a tank, could it be related to that?
I'll fill up tonight and check again. Gotta keep ECUtek and the laptop in the car more often I guess.
djdnz is offline   Reply With Quote
Old 12-10-2015, 02:49 PM   #482
CSG David
CSG David's Avatar
Check the following items:
1. Sensors and lines not directly touching hot sources.
2. Hoses are routed properly.
3. All hoses are clamped down properly to prevent vacuum leak.
4. Make sure the intercooler is filled up accordingly (also burped properly).
5. Make sure your radiator is filled up properly.
Logging does help to identify the problems a little more accurately.
Old 12-10-2015, 03:34 PM   #483
skinsfn36
skinsfn36's Avatar
Drives: 2006 Honda Civic Si
Random question for those with this kit or a vendor that has one nearby and can check..
Can the manifold be taking off of the blower unit or is it a single cast piece?
Thanks!
Any pics you have would greatly help
skinsfn36 is offline   Reply With Quote
Old 12-10-2015, 04:01 PM   #484
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Thanks!
The manifold and blower unit are all integrated and a single piece (you can technically "pull off" the eaton from the rear, but don't think that's what you meant). The runners (shown in the pic) does come come off but comes bolted together from edelbrock.
Edit: It looks like the top manifold cover could technically be taken off (pic showing underside of the cover) but you're basically taking the whole thing apart at that point.
Old 12-10-2015, 04:21 PM   #485
skinsfn36
skinsfn36's Avatar
Thanks that perfectly answers my question!
Edit: DO you have an article or link for that picture?
Old 12-10-2015, 04:51 PM   #486
NotSoJDM
NotSoJDM's Avatar
Who's tune are you running?
Old 12-10-2015, 05:01 PM   #487
djdnz
1337
Edelbrock CARB tune. Car is stock other than the edelbrock kit.
Old 12-10-2015, 06:59 PM   #488
Uplink
Uplink's Avatar
Drives: anything you let me
http://dsportmag.com/the-scene/the-h...ind-edelbrock/
It was a general article about the company. Pics are at the end.
Uplink is offline   Reply With Quote
Old 12-10-2015, 07:11 PM   #489
BigFatFlip
BigFatFlip's Avatar
I'm sure glad they moved that surge tank closer to the front, filling that would have been super awkward and I'm pretty sure I would have dumped coolant on the ECU
Old 12-10-2015, 07:30 PM   #490
Uplink
Uplink's Avatar
@NotSoJDM Here's the rest of the pics you were looking for from the article.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
