Old 11-06-2019, 11:44 AM   #4929
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by Pat View Post
How did you break your wheels?
Had a suspension failure and went into the wall. One wheel lost a chunk, the other one is grinded down from scraping along the wall. Both of them held air and are still round, but I wouldnt use them in that state. They both took the brunt of the impact and resulted in very little damage to the chasis (couple of control arms bent, and a bit of body work to do).
Old 11-06-2019, 12:03 PM   #4930
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by Takumi788 View Post
Hmm. What size tire would you run on this wheel? I have found the widest extreme performance tire (200 tw) is usually at 255/40/17. I suppose there is always r-comps and race slicks but a slight stretch to the 255/40/17 with the extra .5" wheel comparison will be interesting.
255/40/17 still. The idea being that the additional width grants a bit of artificial sidewall stiffening, allowing lower tire pressures. The Miata boys run 245/40/15 on a 10 inch wheel all day, everyday without issues. Worth noting that the 200TW tires generally run wider than normal tires, but I assume everyone in this forum section already knows that and already runs 200TW's, Hoosiers, or some form of track tire etc.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 11-06-2019, 12:26 PM   #4931
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by Goingnowherefast View Post
255/40/17 still.
Any idea on a timeline? This seems like a good option to try out.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-06-2019, 12:41 PM   #4932
i8ur911
Drives: 17 BRZ Series.Yellow
From what I've been told, they are hoping to have it out for next year.
i8ur911 is offline   Reply With Quote
Old 11-07-2019, 07:24 PM   #4933
icybrzzz
Drives: 2015 Scion frz
I’m going to try fitting 17x10s on my Brz next spring, looking to run the A052 or pirelli Trofeo R in 255 :p
icybrzzz is offline   Reply With Quote
Old 11-08-2019, 10:34 AM   #4934
Goingnowherefast
Yep, same. I heard the A052's are the new 200TW jam. Can't wait to try them out!
I couldn't get a definitive answer, but it sounds like it'll be next year sometime.
Old 11-10-2019, 04:02 AM   #4935
Originally Posted by TommyW View Post
I’m blown away on how many people just come back to the paddock and park it.
what is your favorite streetable track pad?
CSG C2
Old 11-15-2019, 11:58 AM   #4936
ML
ML's Avatar
Drives: 13 White MT FR-S
I have a set of Kosei k1-Ts 17x7 14lbs~ and a set of konig hypergrams 18x8.5 18lbs. Staying with the Kosei and a 225/45 is 25lbs per tire @ 156lbs total. If I moved up to 245/40/18 26.6lbs per tire on the konigs it would be 178lbs total. So question is it worth the extra weight to go to the larger tire, or is a lighter setup better.
for context, this is a track only car, NA for now (maybe next year FI). BBK, Fortune autos 8k fronts, 6k rear (I believe, cant quite remember), stock sway bars. The car has a good bit of oversteer on the 225/45/17s which I realize could probably be toned down with suspension settings, and my own driving habits. But I need new tires any way so just wanted to hear opinions on this one aspect. I know its nit-picky and probably will be fine either way.
Old 11-15-2019, 01:56 PM   #4937
i8ur911
What 245 tire are you considering and what is the current 225 tire?
Sent from my Pixel 3 using Tapatalk
Old 11-15-2019, 05:58 PM   #4938
ML
ML's Avatar
Currently on falken rt615k+ and that is what I apexes for the weights as well.
Old 11-15-2019, 07:08 PM   #4939
i8ur911
Considering you're staying with the same tire, I would think you'll get a small increase in rear grip, but not substantial. Does that outweigh (pun intended) the additional weight???
FWIW, I ran 225 NT01's a bunch this year and could get the rear to break free "if I wanted". My car is pretty neutral in terms of set up (may be similar to yours???....spring rates are identical).
I like your thinking, but ultimately I think the only way to figure out your answer is going to be data given that it's a relatively small change in the grand scheme of things.
Old 11-18-2019, 05:04 PM   #4940
peaches
Drives: '14 BRZ Limited
Anybody here has had the car reach or go past 130MPH? I want to know if you experience vibration or shake. When my car reaches 130 at the track I feel a vibration in the seat (not the steering wheel). I have changed the wheels and tires as it's what everybody said was the problem and there was no change. I have upgraded motor mounts, tranny mount, cf drive shaft, diff brace, clutch, and flywheel.
Any ideas?
peaches is offline   Reply With Quote
Old 11-21-2019, 06:06 PM   #4941
86league
Drives: '13 BRZ Limited
Recently have driven on a couple of tracks that have an uphill transition in a heavy braking zone before a corner. I'm using the compression to really help get the car slowed quickly, and am trying to trail brake into the corner.
The steering is really heavy in this circumstance. Normal?
Suspect it is and I'm just now driving hard enough to notice it.
Thanks.
86league is offline   Reply With Quote
Old 11-25-2019, 04:32 PM   #4942
Thanks.
Your front tires are bottoming out in the wheel well.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
