Old 03-13-2013, 09:31 AM   #533
Squishy86
Squishy86's Avatar
Drives: Your Car
Originally Posted by CanibeatNoel View Post
Swapped my oem fogs to the Crystal Eye fogs.
How do you always find all this cool shit before everyone else does? Looks nice!
Squishy86 is offline   Reply With Quote
Old 03-13-2013, 09:33 AM   #534
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Those headlights are badass Why can't the U.S. ever get nice parts. They always gotta cheap it out It's the little things that make up a nice car.
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
Old 03-13-2013, 10:44 AM   #535
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Originally Posted by Roberto12 View Post
Full kit with the ballasts
where did you mount your ballasts? i already have hids in my low beams but not sure where i'm going to mount these guys
abutterman is offline   Reply With Quote
Old 03-13-2013, 02:24 PM   #536
CanibeatNoel
CanibeatNoel's Avatar
Drives: Firestorm
Originally Posted by whitefrs View Post
nice
hows the light output compare to stock lights?
So much brighter! Since I had the actual OE version fogs they were plastic so I wasn't able to throw HID's in them due to temperature. Now with the full LED face along with glass housing I think the output is 5x brighter. I think it's even brighter than my headlights, haha!
Overnight parts from Japan!
Firestorm FRS
Airrex - Varis - GReddy - Arqray - Edirb - Whiteline
CanibeatNoel is offline   Reply With Quote
Old 03-13-2013, 09:08 PM   #537
Roberto12
Drives: scion fr-s argento
This is just with fogs on and 6k HID
Roberto12 is offline   Reply With Quote
Old 03-13-2013, 09:13 PM   #538
Roberto12
I mounted the ballasts on the chassis With a screw and bolt. Sorry for the big pictures I'm new at this. There's a hole where they mount perfectly :-)
Old 03-14-2013, 12:59 AM   #539
abutterman
abutterman's Avatar
That' perfect. i was worried about not having enough cable to pull the ballast up somewhere but that'll work great
Old 03-14-2013, 05:08 AM   #540
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
I just recently installed the fogs on @Rollan's FRS with the new harness and new smaller switch from nigels. just a tip, if u guys want to use the switch. u need a extra extension wires that goes thru the firewall, because the wire that suppose to go thru the firewall to the switch from the outside is very short.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 03-14-2013, 06:15 AM   #541
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
How much longer do we need?
I will talk to the factory and try to see if I can get them longer for you guys in the next shipment.
let me know if 50CM extension enough for you guys, I might able to get it for you all.
nigel-jdmparts is offline   Reply With Quote
Old 03-14-2013, 11:21 AM   #542
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Let someone else chime in who has installed it as well, but I think 50CM would reach to the left panel below the steering wheel.
tbwoodlee is offline   Reply With Quote
Old 03-14-2013, 11:32 AM   #543
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
@nigel-jdmparts longer the better!
mezdup is offline   Reply With Quote
Old 03-14-2013, 01:05 PM   #544
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
@nigel-jdmparts if you can make it longer I'll take one!
kmbkk is offline   Reply With Quote
Old 03-14-2013, 01:13 PM   #545
b$m1th91
b$m1th91's Avatar
You miind posting pics of the smaller switch?? Does it match the trunk button better?
Old 03-14-2013, 01:16 PM   #546
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
not really but close enough. i forgot to take a pics when i installed on @Rollan's FRS.
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 06:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 03:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 02:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 08:29 PM
