Old 09-02-2016, 02:44 PM   #43
Frsboxer
Drives: 2015 scion frs
Hey Shiv can you message me i have a important question for you about the e85 tune
Originally Posted by Shiv@Openflash View Post
I will be testing a FlexFuel 6AT ROM this weekend on a spare ECU that I bought from Ebay last week. Fingers crossed!
Frsboxer is offline   Reply With Quote
Old 09-04-2016, 12:41 AM   #44
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
interested in this as well...
@Shiv@Openflash, i have Phantom ESC Ver 3.0 with 6MT.
currently have stock header, Overpipe, front pipe (catted), and Q300..
if you need test on mine, let me know
Old 09-07-2016, 11:13 PM   #45
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
@Shiv@Openflash
see my sig. I'll gladly test for you if you still need guinea pigs. Ive been on E85 straight for a year now.
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 09-08-2016, 09:08 PM   #46
MaxxCann
Hey Shiv, the kit is on back order until next Thursday. It supposed to ship then.
2013 Asphalt FR-86 (badge conversion) | TRD wheels | TRD CAI | TRD exhaust | TRD lowering springs | TRD front strut tower brace | TRD door stabilizers | TRD member brace kit | TRD spoiler | TRD quick shifter | TRD door speaker panels | TRD seat gap fillers | GT86 Armrest | Red Perrin Lightweight Pulleys, Drift Button, and Reverse Lockout | Winjet Foglights | Full LED swap | Custom dash and HVAC LEDs
MaxxCann is offline   Reply With Quote
Old 09-28-2016, 02:18 PM   #47
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Been a little while now, how has the testing been coming along?
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 09-30-2016, 10:57 PM   #48
MaxxCann
Installed the kit and added a switch so I can go back to stock whenever I want. It was pretty easy to install
Old 10-01-2016, 03:14 PM   #49
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You cut the evap signal wire?
Intent > Content
Old 10-02-2016, 09:12 AM   #50
bryansuriel3
bryansuriel3's Avatar
Drives: Red Brz
i have all the requirements except for the flex fuel kit let me know if its possible for me to test
bryansuriel3 is offline   Reply With Quote
Old 10-02-2016, 11:24 PM   #51
customyota
Drives: WRB BRZ
Does the flex fuel kit put out a straight proportional voltage? IE, 0% ethanol = 0v and 100% ethanol = 5v? If so, does that mean it will work with other kits that do the same, like the Zeitronix one? Or cheaper/more dangerous, the manual pot that was mentioned earlier.
customyota is offline   Reply With Quote
Old 10-05-2016, 12:17 AM   #52
Aussie
Drives: 2013 Scion FR-S 6MT
Can Torque display the current ethanol content?
Just bought the FFTEC flex fuel kit and am taking Shiv up on his free custom e-tuning 😊
One question: does anyone know if it would be possible to use Torque to display the current ethanol content reported by the flex fuel kit?
Thanks
Aussie is offline   Reply With Quote
Old 10-05-2016, 12:34 AM   #53
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Thanks
No
Old 10-05-2016, 06:56 AM   #54
steve99
It should work with any flex kit set up to connect into the evap pressure on the ecu.
you may need to tweak the tables for e% vs voltage if their are differences in sensor calibration most kits put out 0 to 5v.
you can also just switch the evap inut from earth to open circuit as the ecu has an internall pull up resistor to 5v, this give you basicly e85 to petrol map switching on the fly no reflash needed and cost you $5 for a switch.
Old 10-05-2016, 07:03 AM   #55
steve99
Just bought the FFTEC flex fuel kit and am taking Shiv up on his free custom e-tuning ��
Thanks
Originally Posted by Wayno View Post
No
Actually it might be possible, i just looked at torque and it has a loggable parameter "evap pressure" if that works then you could monitor that and it would give you a representation of E%. If you findcthe pid for evap pressure you could then make your own custom pid and scale it to read E%.
Old 10-05-2016, 11:37 AM   #56
Aussie
Thanks Steve, When I'm up and running I'll give it a go and report back including comparing it with the value reported by OFT.
End of Summer Sale! OpenFlash tablet+OpenFlash Header+OEM Gaskets Shiv@Openflash Engine, Exhaust, Bolt-Ons 2 10-01-2015 07:25 PM
FS: New Openflash Tablet, New Openflash Header, New Ducktail Spoiler, NewCrawford BPB FT86POWER Engine, Exhaust, Bolt-Ons 5 09-16-2015 04:26 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
