08-07-2020, 06:00 PM | #43 |
Forgot to knock on wood so I think I have this issue now.
Does this sound like the issue to anyone? I hear it from the engine bay too, but the noise seems much lower than my Pedders front suspension mounts. |
08-09-2020, 08:27 PM | #44 |
^^ I have similar noise coming from lower front passenger side. It only happens when I put it in reverse and turning right though.
08-12-2020, 03:14 PM | #45 | |
Even after replacing my coupler I still get the thump when turning left/right while stationary so that isn't a definitive test. If you can do 15 - 25MPH over small bumps (I like to test on road reflectors) and not hear knocking then you are probably fine. |
08-18-2020, 10:32 PM | #46 | |
Drives: Scion FR-S
I found they are 14mm "nuts" on bolts as some have said. But also how would everyone rate how hard was it to get those nuts loose? Mine do not budge and I am in danger of rounding the nuts off. Possible my socket isn't deep enough. Going to get another one to be sure, but I stopped at this point because I'm a bit freaked out the nuts were starting to round. I triple checked I was using a 14mm socket also. |
08-19-2020, 12:01 PM | #47 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
The Following User Says Thank You to Dave-ROR For This Useful Post: | Opie (08-19-2020) |
08-19-2020, 12:01 PM | #48 |
Site Moderator
Drives: Stuff
This is almost surely a slightly loose metal undertray. Just go tighten all those 12s and 10s real good.
-Dave
08-19-2020, 12:14 PM | #49 |
Drives: Scion FR-S
08-19-2020, 06:51 PM | #50 |
Drives: '13 BRZ TLM Spec
Dave-ROR makes a great point, the entire dash comes out pretty quickly (like under an hour) and you can then get the EPS apart without meddling in the floorboard...much easier in my opinion.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
08-19-2020, 06:52 PM | #51 |
TRACKBREAD
08-19-2020, 08:28 PM | #52 | |
Drives: Scion FR-S
They didn't budge. So I saw someone say that alternative is take the dash out? Meaning instrument cluster? This is getting disappointing. |
08-19-2020, 08:54 PM | #53 | |
Site Moderator
Drives: Stuff
Dash is easy really, just a lot of crap to take off. Center console, hvac, radio, a pillar trim, speaker covers, lower dash panels, OBD2 plug, pass airbag, etc. After doing it a few times it's easy. The OBD2 plug sucks the most. Now my dash is held in with 6 screws.. obd2 sits where hvac was. Makes taking out the dash a 1 minute job
-Dave
08-19-2020, 10:45 PM | #54 | |
Drives: Scion FR-S
I bit the bullet and headed to the store for an extractor set. Got them off. They are toast, but they are off. |
The Following User Says Thank You to Hayseed For This Useful Post: | Dave-ROR (08-19-2020) |
02-28-2021, 06:50 PM | #55 |
Drives: 2013 BRZ Limited
THANK YOU! THANK YOU! THANK YOU! This solved my rattle and steering is like new!
This is what owner forums are for! |
03-04-2021, 01:06 PM | #56 |
Drives: 2016 Scion FR-S
I think I may have this issue on my 2016 FR-S. I hear a small clunking or rattling sound at lower speeds, it sounds like it’s on the drivers side. The steering feel isn’t quite as sharp either. I was thinking it might be something in the suspension, but after reading this I’m not sure. I’m worried about doing this fix and messing up something else. I’m only at 33K miles
Similar Threads | ||||
Is building a motor necessary for FI on this motor? | Irace86.2.0 | Forced Induction | 44 | 02-27-2018 02:19 PM |
Shifter Rattle and Replacement | boredom.is.me | Issues | Warranty | Recalls / TSB | 19 | 04-27-2015 05:29 PM |
Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 03:39 PM |
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED) | Sportsguy83 | Engine, Exhaust, Transmission | 11 | 06-19-2014 12:29 AM |
