Old 04-29-2019, 07:45 PM   #43
e1_griego
e1_griego's Avatar
Drives: Many
STX competition at Crow's was fun, and we had a class of 23!
I went with -4.3* of camber in front and it definitely worked better on the concrete. Shoulders of the tires still wore (obviously) but they didn't look near as thrashed as I'm used to. We'll see how that much camber translates to the much-lower-grip Packwood surface this weekend.
e1_griego is offline   Reply With Quote
Old 04-29-2019, 10:33 PM   #44
H1C
Drives: 2014 FR-S MT
Originally Posted by smg1138 View Post
@H1C How much caster can you get with the GC camber plates?
I can't say for sure, but I would guess somewhere between 0.5 and 1 deg more than stock. As soon as I installed mine I slid them to the minimal setting, and that got me 5.7 - 5.8. I would say the slotted holes are around 0.75 inch long. I prefer OEM caster for the reasons given here:
https://www.ft86club.com/forums/show...postcount=3440
Sorry I can't be more specific!
H1C is offline   Reply With Quote
Old 05-01-2019, 11:09 PM   #45
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I'm kind of wishing I went with more front camber for Crow's. Definitely don't want it for Packwood though so that's why I only went with -3.5. All of that is moot is I can't decide on compression/rebound settings though.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-02-2019, 11:42 AM   #46
ka-t_240
I have the GC camber plates, I got very minimal caster gains.
ka-t_240 is offline   Reply With Quote
Old 05-02-2019, 11:51 AM   #47
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I'd mostly just use the adjustment to even out the caster. For whatever reason there's about a 0.5 degree difference from side to side on my FRS. On a different note, the GC camber plates are non-raising, right? Like they don't reduce suspension travel like some other designs?
smg1138 is offline   Reply With Quote
Old 05-02-2019, 01:00 PM   #48
ka-t_240
Yes, the camber plate features are all "above" the standard strut mount.
Old 05-02-2019, 01:24 PM   #49
tony_r
tony_r's Avatar
Drives: '15 STX
Last time I was at Packwood the car worked great at my settings. Just had to make sure to use Stones and not BFG's.
tony_r is offline   Reply With Quote
Old 05-02-2019, 01:49 PM   #50
justint5387
Drives: 4 wheels
Car hasn't change much through the years.
Engine:
Perrin inlet tube
Perrin crank pulley
Perrin engine mounts
JDL UEL Header (Maybe JDL 4-2-1 later)
Perrin over pipe
Perrin mid pipe with high flow cat
Perrin 2.5 resonated cat back (Maybe single exit exhaust)
Shorai battery
Moto East ECUTEK tune (Still 91, probably retune if we go EL)
Radium PCV catch-can
Drivetrain:
Kartboy short shifter
Kartboy trans mount insert
OS Giken diff (re-tuned last year, may try OEM diff later)
Whiteline differential bushings
Suspension
MCS 2WNR (300/450 springs) rear shocks revalved by ProParts
-4.5/-3 (Probably need to lower rear camber, can't launch but probably user error)
Perrin front bar
Mann rear bar
Whiteline sub frame bushing inserts
PLM front end links
Whiteline rear end links
Vorshlag camber plates
SPC lower control arms w/ DIF bushing
OEM rear shock mounts
Wheels/Tires:
3 x Weds Sport TC105N 17x9 +35 (BFG Rival S 1.5, RE-71R, Conti ECS 245/40/17)
Interior:
Sparco Pro2000 seat
Custom aluminum seat base and slider
justint5387 is offline   Reply With Quote
Old 05-02-2019, 03:26 PM   #51
M0nk3y
Engine:
Perrin inlet tube
Perrin crank pulley
Perrin over pipe
Shorai battery
Drivetrain:
Suspension
Perrin front bar
Mann rear bar
PLM front end links
Wheels/Tires:
Interior:
Sparco Pro2000 seat
JDL 4-2-1 sucks, don't waste your time with a retune at all. Just don't buy the header either
What's interesting though is you're thinking about OEM Diff again....
Kyle H. - #89 STX
Old 05-02-2019, 03:40 PM   #52
smg1138
smg1138's Avatar
What makes the JDL 4-2-1 suck? I thought it provided noticeable gains over their UEL version.
Old 05-02-2019, 08:32 PM   #53
strat61caster
strat61caster's Avatar
Eh I'm bored waiting for Kyle to respond, it was talked about in the big STX thread, I bet there's a bunch of 'marginal gains for big bucks' a touch of 'maybe ACE would've been better' or maybe a full dose of "imma be facetious so maybe Tsang doesn't get any more powah by September"
When it comes to the long tube headers I liked Justin's review, a lot of people saw that as validation for the performance/money, I saw that and thought I'd be better off spending the $2k+ on another set of tires or two and as much seat time and test and tuning as I can schedule. I'm certainly not losing because of 15 hp at X.X rpm.
https://www.ft86club.com/forums/showthread.php?t=125559
ineedyourdiddly
Old 05-03-2019, 02:24 PM   #54
justint5387
Drives: 4 wheels
I think Kyle is trolling me. lol
Old 05-03-2019, 02:52 PM   #55
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
They bought the car with the diff and never ran stock. They're too cheap to buy an OS outright
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
Old 05-03-2019, 03:02 PM   #56
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Finally got my car back from the chassis alignment shack,
Front Camber: -2.25 * ( stock top hats whiteline camber bolts only)
Rear Camber: -2.0 rear ( cusco rear could dial in 3.25 from what the guy said)
Front Total Toe: 1/16 out
Rear Total Toe: 1/16 in
Front Caster Matched: 8 Degrees (again stock top hats)
Endlinks reset with no preload at full rest. and draw stiffeners also reduced preload to neutral at rest.
The car handles like a dream now and its extremely manageable. Im shocked by how archaic the suspension is ( the rear subframe is literally a 11 wrx) and the front is macpherson, but it does so well
Clutch Dog is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
2019 CDC & SCCA Autocross Thread JakeRogue Mid-Atlantic 15 05-17-2019 10:58 AM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 01:05 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 11:05 PM
