| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#43 | |
Drives: 2022 BRZ Limited SBP
https://www.ft86club.com/forums/showthread.php?t=147937 |
#44 |
Drives: 22 BRZ limited
I'm not sure that there should be any more wires. With the lights on, the dots on the homelink buttons are illuminated like they should be. It just doesn't recognize the button presses.
#45 |
I am not getting any lights on the HomeLink buttons or on in the mirror with or without the headlights on. I guess I will ask the dealer about it.
#46 |
Drives: Subaru BRZ
I showed my dealer this today. They're going to escalate with subaru corporate. They asked I do the same, as nothing will happen fast without a bunch of attention on the topic.
#47 |
My local Subaru dealer is getting on my nerves. They ordered the wrong mirror again. This is after it came in on the 4th and the parts dept didn't tell anybody. This will be the 4th mirror order and third homelink mirror(if they order the right one).
They told me we could test plug the mirror before sending it to the shop to save time if it didn't work. Nope. Gotta wait half an hour to find out they don't even have the right mirror. Then have to wait 5 minutes to even leave the parking lot because the car is blocked in the service drive through. |
#48 |
Drives: 2022 BRZ
There is no real testing needed. Just look at the harness that plugs into the mirror. If there are 4 wires and one is a blue wire, its good. If there isn't its part of a small batch that went out with the wrong harnesses.
If they've ordered 4 mirrors and gotten a bad one every time, you should probably play the lottery. There is no way it was wrong that many times. There is a tech bulletin that states to look at the production date, all mirrors with a production date of 6/30 or earlier need to be replaced. Anything after 6/30/21 is OK |
#49 |
I asked you about this on Dec 31 and got nothing. They have ordered 2 wrong mirrors. The first was a normal mirror, but they didn't say what was wrong with this one.
Why don't you post a picture of both ends of your jumper harness and we can put this to bed. |
#50 |
Drives: white limited
I just picked up my limited manual this past weekend and my homelink works fine.
Works great with my chamberlain at my place. |
#51 |
It seems @Kado can't bother to be a help either time I asked him, so here's a picture of my old harness and new harness together.
After 4 trips to the dealer and 2 non homelink mirrors ordered by them I finally have a working mirror. Original harness on right, new working on left. |
#52 |
Drives: 2022 BRZ
"If there are 4 wires and one is a blue wire, its good."
3 wires bad.. 4 wires good. Not super complicated. I have been nowhere near my car to take a picture. Congrats on getting your mirror all squared up. |
#53 | |
Thanks for the update! Can the dealer order just a new wire harness, or do they have to order the whole mirror? Sent from my iPhone using Tapatalk |
#54 | |
While not proper, you could also just jump the red and blue wires on the mirror. I tried this and it worked. |
#55 | |
Drives: 22 BRZ Limited
Is there any way to confirm that's what's happening further up the wire bundle? I assume so as the wire harness from the car is only 3 wires. I think it's just constant power, switched power, and ground. So red is probably either constant or switched. |
#56 |
You are correct. The 4th blue wire is teed off under the sheathing.
| Tail lights not working, brake lights and turn signals are working | Inter | Electronics | Audio | NAV | Infotainment | 10 | 09-15-2022 02:50 AM |
| FS: Homelink mirror | SWPinATL | Interior Parts (Incl. Lighting) | 8 | 05-22-2015 06:37 PM |
| DIY Homelink Install | DrunkMonkey45 | DIY (Do-It-Yourself) Guides | 7 | 12-26-2014 04:57 PM |
| Homelink fuse | Deathalo | Electronics | Audio | NAV | Infotainment | 2 | 03-19-2014 03:02 PM |
| HomeLink FRS | dav0777x | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 08-02-2013 09:53 AM |
