#43 | |
Drives: 2015 FRS
The SX2 is "fine". For half the price. |
#44 |
Drives: Toyota GT86
He already has them and maybe I’m wrong but he didn’t want to change them.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#45 |
Drives: BRZ 2023
Money is not an object, convenience is. I want something that works in rain with standing water on track and I don't want to switch for track days. That's why thinking about 4S.
#46 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
The 4S will get greasy very quickly in the dry and it's not a wet tire, though it's passable. Just get another set of wheels. Swapping wheels is 20 minutes. You'll need to rotate tires anyway.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#47 | |
Drives: '23 GR86, '17 BRZ
Everywhere I've run with or instructed with... if you have a small slide and catch it the correct response is "hell yeah nice work". Not "turn on the nannies". Maybe if you were repeatedly spinning and getting black flagged that would make sense. But that's odd. Is it a track with zero runoff or something? |
#48 | |
Drives: BRZ 2023
I understand tires make compromise somewhere and given my skills they might be enough. For now 4 get greasy on hot days and in 4th session onwards for me. 4S might be it and last me enough in next season, if I think I need dedicated track tires then I would look. Most Porsche guys were using 4S at track day, so I thought might be good enough for me, still evaluating. |
#49 | |
Drives: BRZ 2023
#50 | |
Drives: Toyota GT86
But the point still stands the 4 and 4s are fine for track usage and if the OP is good with fine who cares
#51 | |
I have a video somewhere of a 992 GT3 fucking up my BRZ pb and hours of video of me making GT4s look stupid in the "advanced" group or whatever they call the 2nd to top group (there were 1/3 the number of cars so I went there instead of the top group).
#52 | |
Drives: 2018 BRZ
And yes, for the slow group street tires are just fine. If you intend to get faster and push the car more and more, you'd need to have your car set up for that or you'd quickly run into limitations (tires get greasy, brakes fade, engine overheats) that would force you to slow down. I prefer to go balls out for a full session without worrying about managing brakes and tires, so even though I don't care about lap times I invested in track pads and tires (ECF). Luckily the endurance racing space is very similar to HPDE in terms of requirements, so going with endurance tires is an easy choice. |
#53 | ||
Brakes are a safety item. I dont understand why anyone runs compromise pads. Just swap the damn pads before and after an event. It also depends on your weather. If it is cool out, you'll do a lot better than if its hot out. Heck, better tires may require more management as we get into winter. I found myself in the sand pit last weekend after the 2500ft straight because I forgot that tires cool off a lot in the straights- and a miata spends a lot of time in the straights. Went from pretty hot to pretty cold and went right off the track in miata. In case you're wondering, it's exceptionally embarrassing to go into a turn so fast you go STRAIGHT off in a Miata. The track owner was texting me the next day about it
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. Last edited by GrandSport; 11-08-2023 at 03:04 PM. |
#54 |
Drives: BRZ 2023
Not much to update but still going to. Did one more track day, this time with ACNW (Audi club), they had 4 run groups so got less track time. Started going to ridge Motorsports and probably going to stick to that track this year. I don't want to go to Pacific, doesn't seems like worth the higher risk. I might check out Portland track as well.
This year's plan is to do 5-8 track days, 2-3 car control clinic with PCA. Last year car control with PCA was very fun, learned a lot like autocross and got significant seat time. I have also bought sim racing setup to practice ridge track. Tires are still stock but I am going to get SX2 this year. Brake pads are still DS2500 with significant life left, I would probably switch to CSG CP after they wear out. If run out of limit on those I am going to get BRZ tS for bbk. |
#55 | |
Drives: Toyota GT86
The CP seems to be listed as a high performance street pad like the DS2500.
#56 |
Drives: BRZ 2023
I went by temperature range when calling it an upgrade DS2500 has 0-500°C and CP have 50-700°C. And I would have some comparison points as CP cost about double and there are no comparison anywhere.
| Wheels setup advice to learn drifting | ShadowTS | Tracking / Autocross / HPDE / Drifting | 2 | 03-22-2016 04:26 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 07:36 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 11:48 AM |
| How does the ECU learn? | boredom.is.me | Software Tuning | 19 | 10-10-2013 09:29 PM |
