| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Actually, thinner tires may work better, depending on the type of snow you get. I would probably just get the stock size. +/-1 size wouldn't make much difference as each manufacturer's tire specs vary slightly in their actual width even though they might all be 215/45's.
#44 |
Drives: Attitude
Skinnier tires for winter is the norm. On my WRX I run 225/45/17 in the summer and 205/50/17 in the winter, though I could go to a 205/55/16 if I wanted to.
#45 | |
Drives: 1998 Toyota Altezza RS200
![]() image borrowed from http://farnorthracing.com/autocross_secrets3_5.html (good further reading) The circle represents the point at which the tire will begin to slide. Anywhere within the circle and you are ok. Anywhere outside of the circle and you are likely not. This provides a simple visual way to understand a tire's grip. For example, at 100% acceleration you've reached the maximum total grip of the tire; any turn of the steering wheel will cause understeer. However, follow the perimeter of the circle to a point at 75% acceleration. While you'd perhaps expect to be able to corner left/right with the "remaining" 25%, the reality is quite different. The tire is actually capable of generating about 75% of its maximum cornering force WHILE accelerating with 75% of its accelerating force; a far higher total amount of grip than simply using 100% for acceleration. The implication of this is to get the best use of your tires it's ideal to be producing both lateral and forward/backward force at the same time, or in other words both cornering and accelerating/braking. This is exemplified by racing techniques like trail braking and early entry lines (which allow earlier acceleration) that combine the two forces. Queue "the more you know" music..
#46 | |
Drives: FRS :D
![]() We get some crazy snow sometimes here in Vancouver and I still plan to DD. Like what has been repeated snow tires are key
Out of the FRS game
#47 |
Drives: 2003 Corvette Z06, ECS Dry Sump 427
GTO (and CTS-V) was near the top of my new daily driver list until the BRZ caught my eye. In the end I wanted my 2nd car to be a completely different driving experience from my Vette. Figured the GTO may feel too similar. I'm guessing it's fun hopping between the GTO and G35 for similar reasons.
#48 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
My post was about driving in poor conditions however. While on a sunny day the average driver will probably never find the outer limit of the grip circle, on wet and snowy roads it's very likely. So in poor conditions track techniques meant to help budget the grip circle become very effective for the average driver. I'm not telling him how to drive on a track, but how to keep his new RWD car out of the trees. |
#49 | |
Drives: Car
#50 |
On my 9th New England winter, 7 of which were driven with a RWD car. The best years were the ones with RWD + snow tires. The worst years were any with all-season tires, FWD or RWD. The most interesting year was this one, with AWD + summer tires.
I'm glad the BRZ is coming with all-seasons. That gives me two pairs of rear tires for drifting, as I plan on having a dedicated set of summer and winter wheels/tires for the car ![]() Although I plan on modding the BRZ, I think I'll make my MR2 a dedicated track car and leave the BRZ for fun cruising and the occasional drift event because drifting my MR2 is too much of a challenge.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#51 |
Drives: '06 AM V8V Coupe
But they're not all seasons...
#52 |
Exactly - BRZ COMES WITH SUMMER TIRES!.
#53 | |
Drives: BRZ SOON!
I drove a MR2 around in winter with all seasons sometimes fun sometimes scary. Everyone in the NE that drives a rwd or hp car knows either drive extremely careful or get dedicated tires for summer/winter. Town fair tire usually has a extremely crazy deal going on right around august. Its usually 4 snow tires with stealies for 4-5 hundred. I can't remember the brand but even the worst snow tire is better in the snow than a all season tire.
#54 | |
#55 | |
What you're saying is exactly what one would expect, but the truth is tires are not so simple. Let me illustrate it this way: ![]() The red lines I've drawn in illustrate what you'd guess represents a tire's grip: a linear relationship between lateral and longitudinal grip. This would represent a car that can either accelerate/brake at 100% without cornering, corner at 100% without accelerating/braking, or do some combination of the two in which the two forces always add up to 100%, i.e. 50% acceleration and 50% left cornering. This is not how tires work. You can see there is overlap between between the "expected" lines and the actual grip circle at the four extreme forces. At those four points the maximum potential of the tire is the same. The interesting parts are the diagonal areas that represent a combination of lateral and longitudinal forces. The area within the circle but outside the "expected" lines represent the higher potential grip of the tire when combining forces. At any point in that area up until the outer limit of the grip circle you are using more of the tire's potential, and will thus produce faster lap times, than someone who operates only within the "expected" lines. Indeed, the combination of forces in those areas will add up to a greater net force than the maximum the tire can produce in any one direction. In other words using techniques like trail braking that use both lateral and longitudinal grip at the same time will produce more grip, and thus better lap times than someone who only "does one thing at a time." |
#56 |
Drives: 370TT, 2013 FRS
This car will be the company DD car. We will take the z34 and E90 and weekend cars.
| Tags |
| brz, daily driver, snow |
| FT-86 -- daily driver, weekend car, or garage queen? | My86 | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 05-28-2012 01:28 AM |
| Good sporty daily driver? | Staticz | Scion FR-S / Toyota 86 GT86 General Forum | 79 | 03-01-2012 05:20 PM |
| Comfort and daily driving - Should I go with a sports coupe? | Undecided | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 03-01-2012 03:17 AM |
| The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 02:14 PM |
