Old 04-14-2014, 04:23 AM   #43
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Ps: I do appreciate your solution, thank you for posting it
OjiGeorge is offline   Reply With Quote
Old 04-14-2014, 12:37 PM   #44
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Post a picture of the coil wire if you get it. I still need to wire mine in. Right now its just wired up as a wideband for the ecm.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-14-2014, 06:24 PM   #45
OjiGeorge
OjiGeorge's Avatar
Will do. Looks like the car won't be going into the shop until next week so should have some time to play around with it this week. @AZFA20, does the gauge need to be configured for 2 revolutions for every signal?
Sent from my SGH-I747M using Tapatalk
Old 04-19-2014, 05:55 AM   #46
OjiGeorge
OjiGeorge's Avatar
Before I go into tapping one of the coils leading into the ECU harness, has anyone else actually used @AZFA20 method with the AEM fail safe with seamless success, and no worries about messing up the ECU/motor?
Don't have the funds burning a hole my my pocket to be a pioneer here...
Old 04-25-2014, 06:52 AM   #47
HRTROB
HRTROB's Avatar
Drives: Toyota 86
How long did you guys set the alarm delay? I keep getting false alarms when tipping in the throttle after an upshift when the AFR jumps to 18:1 for a split second. I currently have it set at 550ms.
HRTROB is offline   Reply With Quote
Old 04-25-2014, 11:53 AM   #48
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't think that is a delay issue, that is a setting issue. I would not worry about setting any alarms prior to the gauge seeing boost. If you are indeed seeing 18:1 at 1 psi, then I would work on your tune and your tip in enrichment.
Old 04-25-2014, 12:08 PM   #49
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I think the problem is with the alarm delay setting because when I release the throttle for an upshift, AFR jumps to 18:1 and when I tip in the throttle, AFR is still at 18:1 before it goes back down.
I can't set the alarm threshold higher than 18:1 at 0 boost because the next setting adjustment is at 0.3 bar (4.35 psi). If I set it at 18:1 at 0 boost, the threshold will be sloping down to whatever I set it at 0.3 bar (11.7 in my case). That means I won't get any alarms from 0-4 psi.
Old 04-25-2014, 12:33 PM   #50
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It has been awhile since I messed with my AEM Failsafe, so I forgot the resolution is that poor. I still think your tip in enrichment could be improved in your tune, but if you don't want to see that alarm then go ahead and up the delay till you don't see it anymore. You really only want it alarming you when there is clearly something wrong, not border line wrong, which would mean more than a second worth of unsafe AFR/PSI.
Old 03-28-2016, 07:10 PM   #51
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Can anyone explain to me how to install aem afr/Boost wide band failsafe. Just need a little help trying to wire to my ecu.
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 08-14-2016, 12:06 PM   #52
brznoob
brznoob's Avatar
Drives: 2014 subaru brz Limited 6mt
+1 Also need help with this
2014 BRZ Limited 6MT World Rally Blue.
Mods: Tomei UEL header, Tomei overpipe, HKS Dual Resonated Front Pipe, Stock Catback, JR C30 kit with HBP, DW700cc injectors, DW 65C pump, Delicious Tuning FF kit, Forrester XT oilcooler, ACT HD Street clutch, ecutek #mototuned.
brznoob is offline   Reply With Quote
AEM Failsafe Scalzo Electronics | Audio | NAV | Infotainment 11 06-05-2013 09:10 PM
AEM Failsafe wideband gauge. skatery1989 Interior Parts (Incl. Lighting) 2 04-14-2013 10:12 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
