Old 03-16-2016, 02:17 AM   #43
Northwest86
Drives: Velocity Orange 86 GT
Good to see that MRT can't measure a piston size correctly. At least they are consistently horrible at everything. (for the Americans they alone are the Ecutek dealer in aus. Hence why across Australia we laugh at anyone locally with Ecutek. They do extremely shoddy work, expecially with tuning.)
Long story short. GTS/BRZ brakes fit the GT fine. You just transfer Calipers, Rotors and pads and you are done.
Northwest86 is offline   Reply With Quote
Old 06-20-2016, 04:11 AM   #44
jng
jng's Avatar
Drives: Toyota 86
Originally Posted by ultra View Post
I have the entry level GT86 as well.
I have an Alcon BBK on now but when zi had the stock brakes on I ran Ferodo DS2500 pads front and rear with SS lines and AP Racing 600 fluid. Brakes held up fine on the track performance wise. Very consistent feel, no real pad or fluid fade. The front rotors wore down pretty quick though.
Anyhow, I had to do the same research when trying to find the right pads for my car and I basically found that our cars use WRX brakes front and rear. Rears are unventilated but that doesn't seem to be such a big deal. For me it was the front brakes that took a real pounding.
I've listed the caliper/pad part numbers as well.
Brakes info:
FRONT- Subaru WRX 2008-2011
D929
Pic on my car:
http://db.tt/OxYWXYEr
REAR - Subaru WRX 2008-2011
D1114
Pic on my car:
http://db.tt/Xucf1m8z
Apologies for my layman understanding, but does having two same calipers as the '08-'11 WRX mean that a GRB STI Brembo swap can be done without any change in brake bias (in the "entry level" spec 86), vs. the GT version?
jng is offline   Reply With Quote
Old 06-20-2016, 05:59 AM   #45
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Subaru has been using the same brembo front calipers for about a decade and they're a direct bolt on to the 86 regardless of spec/versions. The front mounting holes on the hub carriers are identical. Its the rear calipers that you'll need to make sure you get the '08+ models for direct bolt on without adaptors. As for brake bias, I'm sure you'd have read discussions about pros/cons and there are different opinions out there, but I can only offer my personal opinion as I've done the full STI brembo swap myself.
On street use, brakes feel strong with none of the "shit...too much front bias" effect whatsoever. Front pads wore evenly too. Can't say much about prolonged use/abuse at the tracks though....but if you visit the tracks very frequently these "OEM" brembo brakes aren't as good as say aftermarket AP or Alcon setups anyways
Fizz is offline   Reply With Quote
Old 06-20-2016, 06:05 AM   #46
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
By the way you can't really just bolt on the wrx brakes and expect the brake bias to be similar....because they're not. Theoretically you'd get more front bias when used on the 86 due to differences in chassis balance and other factors. The wrx has a heavier front end for instance. So to counter this I ran rear pads which were 1 step more aggressive than the fronts. No issues.
Old 06-20-2016, 06:19 AM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by sam69 View Post
Bringing this back to life as just did a GT86 with GTS front rotor upgrade.
When doing the swap I happened to measure the caliper pistons on both to find that the base GT runs bigger 43mm pistons than the GTS 40mm.
Why Subaru would do this is beyond me but figured that they should be better than the GTS brakes with the bigger pistons and gts rotors .
In general, bigger pistons are better. Pressure in the brake fluid is measured in force per area, therefore the more piston area you have exposed to the fluid the more force is exerted onto the pad/disc.
However, it is also important how far the pistons are placed from the center of the wheel. Are the GTS pistons farther from the center or they have same distance with the ones in GT?
Old 06-20-2016, 08:00 AM   #48
churchx
churchx's Avatar
Drives: 2014 GT86
Are you sure on bigger pistons bit? I always thought that it's relative master cylinder area vs pistons area, so per same brake pedal travel imho with bigger pistons you'll get less pistons&pads travel/less braking. as with bigger diameter there is more volume for brake fluid, hence less piston travel per same incoming oil volume.
Old 06-20-2016, 08:39 AM   #49
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I believe the argument is correct. The idea is to maximize the pistons area and at the same time place the pistons as farther as possible from the center of the brake disk (i.e. the wheel). That's why in expensive cars you have very big disks and many small pistons (4-pistons, 6-pistons calipers, etc.) in the outer area of the disk. You cannot place a big piston in the outer area, so you have to divide the total piston area in smaller pieces. Overall, the farther away from the center then the better braking power. You can imagine it as a lever ...
Old 06-20-2016, 10:12 AM   #50
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I just had to google this.
http://forum.liberty.asn.au/viewtopic.php?f=2&t=15690
krayzie is offline   Reply With Quote
Old 06-20-2016, 08:10 PM   #51
Northwest86
Originally Posted by krayzie View Post
Thats one of many. Let alone the amount of stuff we discuss on. CLub facebook pages. I love the one where after daniel died they wanted to charge her storage after they had blown up a stock and 2-3 built engines wigh basically zero milage and no track duty at all. Their idea of tuning is load a map and check the afrs. Theyre a joke frankly
Old 06-20-2016, 11:11 PM   #52
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Correct....the GTS calipers sit further away from the center of axle (front rotor size 276mm vs 294mm)
http://forums.nasioc.com/forums/show....php?t=1265631
Old 06-22-2016, 07:31 AM   #53
makinen
makinen's Avatar
Drives: Toyota 86
If GT spec calipers have larger pistons, would it be better to use GT caliper with GTS bracket?
I have been using that combination to skip brake fluid work without knowing piston differences.
makinen is offline   Reply With Quote
Old 06-27-2016, 10:27 PM   #54
sam69
Drives: GT 86
That is exactly what I did used GT calipers with GTS brackets and discs as was going to put the GTS calipers on and then found that the pistons on the GT were 3mm bigger .
sam69 is offline   Reply With Quote
Old 06-30-2016, 02:19 PM   #55
jng
jng's Avatar
Drives: Toyota 86
Any Aussies / Kiwis that did the GRB ('08 - '11) STI Brembo swap on the base model 86 rear brakes able to drop me a PM? This would be the version with the stock solid (non-ventilated) rear discs. Have a couple questions regarding the ability to direct bolt on the rear calipers onto the knuckle without a need for any brackets.
Thanks.
Old 07-01-2016, 02:36 AM   #56
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks.
Me....at least I used to before I took them off. The 08+ rear brembo's are direct bolt on. No brackets required. The mounting holes are identical on the GT and GTS so it's irrelevant
** PRE-ORDER ** Nur Spec GT86 Aero Kit ** From Carson Toyota Carson Toyota Exterior Parts - The Rest 91 01-20-2016 11:15 PM
UK Spec Toyota GT86 2.0M lordgrover FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 10-18-2012 09:38 AM
First UK Spec GT86 Delivered! Keszki Member's Car Journals 9 07-27-2012 03:51 PM
New Zealand to receive TRD Spec GT86 Priced from $63,486 ($50,841US). CozmoNz Scion FR-S / Toyota 86 GT86 General Forum 31 07-22-2012 10:00 AM
please explain the different lower front lights on US spec BRZ torquemada BRZ First-Gen (2012+) — General Topics 30 12-04-2011 01:18 AM
