#43 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
#44 |
Drives: 13 BRZ Limited 6MT GBS
I took apart the MT buttons.
Honestly, with a bit of ingenuity, I think you'd be able to get them to work as is. Mechanically speaking, the MT buttons are pretty much the same as the AT. The center blank is still a button, and it's still hinged in the middle, but it's got a wide flange around it that keeps it from moving. If you trimmed the flange, you could get it to move. The PCB is the same but the two rubber membranes that short out the AT buttons are gone. If you could find the right part, they could be added back in. There's no control logic on the button PCB either. There is one common pin and then each button shorts its own pin to the common pin. So there's three pins on the MT (TCS, VSC, common) and five on the AT (TCS, VSC, Snow, Sport, common) plus I think two pins that are just for lighting. I am not sure if the common pin is vehicle ground or what, I haven't measured. But the traces are all there, there may even be the additional pins in the connector (I don't remember, it's been months since I took them apart), You'd still need to find a way to connect into the HU. I wouldn't feel comfortable connecting the SWC common pin on the HU to the common pin on the buttons, I don't know if they'd play nice.
#45 |
Drives: FR-S 10 #103 AT
OP, you suck. Now I'm going to have to go through the same measuring process for the FR-S Pioneer radio.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#46 | |
Drives: Mazdarati
Yes it is cool. ....but real sports cars don't have radios either!!!! btw, more than one ! equals the same thing as more than one ?
#47 | |
Drives: Mazdarati
And see my above post........on a side note, http://www.urbandictionary.com/defin...=jive%20turkey
#48 | |
the tuna, no crust.
TROLLOLOLOLOL |
#49 | |
I know the values are probably different, but does anyone know if the pinout is the same for all the HU's? In particular for the HU in the FR-S anniversary edition (now standard for 2014 Scions)?
#50 |
Drives: BRZ Limited
Exactly. Another side benefit is that you can change stations while in the navigation screen, which is nice.
#51 |
Drives: Neptune GR86
How did you end up connecting the 3 wires to the 28 pin connector?
#52 |
I used the pins out of a front panel header from a computer case, they aren't exactly the right pins but they're close enough to fit in the connector. Not sure what fogelsre did.
#53 | |
Drives: BRZ Limited
WM1856-ND - CONN PLUG 3POS 3MM SINGLE ROW WM1846-ND - CONN RECEPT 3POS 3MM SINGLE ROW WM1841-ND - CONN TERM MALE 20-24AWG TIN WM1837-ND - CONN TERM FEMALE 20-24AWG TIN The female connector terminals (the last item) fit the 28-pin harness perfectly. Bob |
#54 |
Trust me, I'm the Doctor
All I really need is next/previous track as volume up/down is a physical knob. A switch like the OP used could go in the blank spot used for sport/snow in the automatic, & you wouldn't have to relocate the heated seat controls.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#55 | |
Drives: 2013 Subaru BRZ (Galaxy Blue)
now it's just figuring out what components I can use with the space provided. But really it's just a idea nothing more lol |
#56 |
I don't really see a need for volume control there, b/c of the readily available physical volume knob on the HU itself. Physical buttons for the touch screen are definitely helpful, but redundancy for the volume knob is adding unnecessary complexity for this DIY. With another HU, I'd say it's a good idea (like one with just volume up and down buttons like my last HU, the Pioneer App Radio 2), but for the stock Subaru HU....? Nah. If it's easily doable, then sure, but if it'd add some headaches I'd say leave it.
But that multi-function switch/knob idea is brilliant! I like! If you get the circuitry and programming devised and set up for easy DIY, I'd love to try it.
| nalc's BRZ steering wheel audio control saga | nalc | Electronics | Audio | NAV | Infotainment | 69 | 12-20-2016 11:07 PM |
| My idea for a center arm rest / console cover / center cup holder | ravenblackfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 67 | 02-13-2016 04:00 PM |
| need help on jpm center console | Jhon19lopez | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-24-2013 08:57 PM |
| Center Console help | mbh1101 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-22-2012 10:56 AM |
| Center Console | encity5 | Electronics | Audio | NAV | Infotainment | 1 | 06-10-2012 10:22 AM |
