Old 09-13-2013, 12:10 AM   #43
Darambul
Drives: Scion FR-S
My scion sqeaky noise from motor.
I took my car today to carson toyota because I keep hearing noise from the motor like sqeaky cricket noise on the driver said. They said its my hydraulic fuel pump. My car is under warranty so they are going to fix for free. I will let you know how it goes.
Darambul is offline   Reply With Quote
Old 09-13-2013, 12:19 AM   #44
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
a simple search could answer all your questions
bkblitzed is offline   Reply With Quote
Old 09-13-2013, 04:10 PM   #45
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Are you sure you all aren't hearing the infamous crickets?
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 04-27-2014, 01:30 PM   #46
14Subota86
Drives: Fr-s
I noticed mine does it also, UNLESS the ac is off PLUS the the vents have to be recirculating also!
14Subota86 is offline   Reply With Quote
Old 05-06-2014, 06:18 PM   #47
FRSKuntz
Drives: 2013 Scion FRS
I've been hearing the same sound. Chirping/Squeaking. Took it to capistrano toyota today. The guy told me it was normal. I really want to tell him that if that annoying a** EMBARRASSING sound is normal he's out of his freakin mind. Toyota definitely needs to do something about this. It's not like its that hard to drown it out with light music but anyone next to me hears that sound clear as day.
FRSKuntz is offline   Reply With Quote
Old 05-07-2014, 11:25 PM   #48
Luftmeister
Drives: 2013 Hot Lava FR-S
I took mine in and they replaced the fuel pump. Some have said it's due to running gasoline with ethanol. Can't confirm that because I know more than a couple of people who have also had their cars with the chirping, and are running E85.
Luftmeister is offline   Reply With Quote
Old 05-08-2014, 02:28 AM   #49
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Sounds like the dreaded crickets. I lost mine as soon as I switched from ethanol gas to pure gas; however, some have retained them despite switching and they have replaced their HPFP only for them to come back. Best bet is to crank up the stereo and don't idle the car.
Demandred7 is offline   Reply With Quote
Old 05-08-2014, 06:45 AM   #50
djmm
djmm's Avatar
Drives: toyota
It's not the sound when your foot is on the brake pedal? Mine has this sound like old plumbing rattle sound when brake pedal is pressed. But not all the time. As soon as I release the pedal, noise stops. Only happen when I just started the car. Not when it's warmed up.
djmm is offline   Reply With Quote
Old 05-08-2014, 11:49 AM   #51
MRBLONDE3965
Drives: ultramarine fr-s
TSB
Toyota has a TSB out for the car to replace the D.I. fuel pump. Go in and complain about it and it will be covered under warranty. if you're on the east coast just an fyi theyre on backorder from california
MRBLONDE3965 is offline   Reply With Quote
Old 05-08-2014, 12:02 PM   #52
Badasi12b
Drives: 2014 Honda Accord Coupe V6
It's interesting that considering that most people on the forums who complain about this all have M/T and constantly boast about it being so much better than A/T. Now I'm not sure about the A/T people here, but it's just something that i've noticed during my months on these forums. I rarely hear technical complaints from A/T owners. hmmm... But I'm pretty positive that isn't making a difference though, it's just an odd coincidence.
Badasi12b is offline   Reply With Quote
Old 05-08-2014, 02:06 PM   #53
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I have an A/T and the idle noise makes me curious. With or without crickets, I'm not sure what the idle should actually sound like and if mine is different or normal. I'm guessing what I'm hearing is maybe the belts and I'm just paranoid.
Nevermore is offline   Reply With Quote
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 11:11 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 04:31 PM
FT 86 Engine jayjayjayjay Engine, Exhaust, Transmission 15 01-18-2011 03:22 PM
