View Poll Results: Toyota FT-86 weight
2300-2399 pounds 5 5.88%
2400-2499 pounds 8 9.41%
2500-2599 pounds 17 20.00%
2600-2699 pounds 22 25.88%
2700-2799 pounds 23 27.06%
2800-2900 pounds 10 11.76%
Voters: 85. You may not vote on this poll
Old 01-21-2010, 06:56 PM   #43
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by CyberFormula View Post
chances are....same weight as the s2000.
2765~2855 lbs? Man, that's heavy weight. My Impreza RS weight less than that.
Old 01-21-2010, 08:08 PM   #44
Blokatos
Drives: MX5 Miata Mk2.5 1.6
The lower the weight gets, the more cash will flow into Toyota's dealerships.
Imagine how petrolheads around the world will wellcome the FT with a weight around 2600 lbs.
Now imagine the same at 2400.
I don't even want to speak about the frenzines if it comes out at 2200 lbs.
Credit crunch crisis...
Blokatos is offline   Reply With Quote
Old 01-21-2010, 10:10 PM   #45
Lexicon101
Inexperienced
Lexicon101's Avatar
Drives: Crappy old '90 civic. Frankie.
Yeah, toyota's gonna be working REAL hard to keep the weight down on this, even with safety regulations... it probably won't weigh as much as the s2k.
Wasn't one of the marketing points of the concept its low weight?
Lexicon101 is offline   Reply With Quote
Old 01-21-2010, 10:16 PM   #46
zigzagz94
BRZerhood Lurker #13
zigzagz94's Avatar
Drives: 15 DGM BRZ Premium
All the rumors were the concept was 1000kg which bodes well for the production vehicle if the target weight is anything within 200kg of that.
zigzagz94 is offline   Reply With Quote
Old 02-09-2010, 09:45 PM   #47
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
So apparently 1000kg cars are still possible: Audi just released it's new A1, which clocks in at 2304lb, or 1045kg. It's slightly shorter and narrower than the FT, but taller, it still seats 4 and meets all the safety reqs. The FT will be a little bigger, with a larger engine (2.0 instead of 1.2) and the necessary RWD bits, but I'm still hopeful for the 24-2500lb range.
no_name is offline   Reply With Quote
Old 02-10-2010, 09:41 PM   #48
Lexicon101
Inexperienced
Lexicon101's Avatar
1000kg = sex!
That'd be nice.
Old 02-10-2010, 10:08 PM   #49
Lexicon101
Inexperienced
Lexicon101's Avatar
Originally Posted by Redline View Post
mt akina lets roll!
Am I the only one who's gonna say anything about this?
x.X
Come on, there have to be loads of Initial D fans around here.
Old 03-24-2010, 03:02 PM   #50
Nemesis
H. Badger Cares About Him
Nemesis's Avatar
Drives: BMW 335i coupe w/ man.6 spd
Originally Posted by zigzagz94 View Post
Last celica was around 2500lbs and so is the miata. FT-86 is similar in size to both those so I don't see why they can't hit the 1200kg target weight.
it's funny you mentioned that. I was thinking about this the other day and remember driving the GTS and found the power lacking. The torque seemed incredibly weak for a sporty car. It had good power, only if you got the rpms up to 6800 or higher (VVTi). I did not get the car because of this. I want it to have low end torque. Revving a car this high draws unwanted attention from the po-po. They are saying this should be a torquey engine. I am really hoping this won't be another celica GTS. I was NOT impressed and waited for the celica GTS to come out, test drove it the day it arrived on the dealers lot, even had the 6spd. Almost cried after driving it, I was so underwhelmed.
Nemesis is offline   Reply With Quote
Old 03-24-2010, 03:56 PM   #51
Franisco
Franisco's Avatar
Drives: D31a
Ruh-oh Don't let the 86 purists hear you saying that. But I agree
Originally Posted by White Comet View Post
No one's buying a Yaris to wind the piss out of it and possibly slam into a mountainside pretending they're the ultimate Tofu delivery person.
Franisco is offline   Reply With Quote
Old 03-24-2010, 07:57 PM   #52
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I voted a realistic sub-2,800lbs, and Im really not afraid of the boxer engine lacking low end grunt, its certainly good for that.
chulooz is offline   Reply With Quote
FT86 weight speculation anyone? Ground N Pound Scion FR-S / Toyota 86 GT86 General Forum 54 09-07-2013 09:14 PM
