Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 04-10-2016, 09:05 AM   #43
Silver86K
Drives: Silver 86
Originally Posted by 86 South Africa View Post
Ah, now I understand.
You could probably run e95, but it's a percentage, so just dilute with normal petrol until you get to 85%
Assuming 100L of fuel, you already have about 5L with e95, so roughly 10L of normal fuel will get you close to e85 (not exactly cos it's mixed into e95, but close enough).
So that's about 5L for every 50L tank.
Thank you for the help I appreciate it
Sent from my SM-G920F using Tapatalk
Silver86K is offline   Reply With Quote
Old 08-24-2018, 10:00 PM   #44
nico_rsx
Drives: BRZ 2017 Pure Red, MT
The simplest way to tell if the engine is running maxium ignition timing is to look at an ECU parameter called IAM (Ignition Advance Multiplier). You need some form of logging device (Its not available via standard obd readers like android torque app and a ELM327 adapter unfortunatly).
you need Techstream or a tuning system like Ecutek, Tactrix or Openflash tablet etc to read parameters directly from ECU.
@steve99
How do you read the IAM value with techstream? I have the cable and the software, but that value seems to be nowhere in the "data list" menu.
nico_rsx is offline   Reply With Quote
Old 08-25-2018, 01:23 AM   #45
steve99
Originally Posted by nico_rsx View Post
@steve99
I think its called advance multiplier or similar not IAM in techstream.
Old 08-25-2018, 04:24 PM   #46
nico_rsx
Is it still a "unitless" data that is between 0 and 1 in techstream?
Because I have seen ignition advance or something like that, but it's in degrees and the value is something like 30.
I'll search again.
I give up tahdizzle Scion FR-S / Toyota 86 GT86 General Forum 20 11-07-2014 06:20 PM
What happens when you give an FRS 750 hp. Cjymiller FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 50 08-21-2013 12:19 AM
I give up Ben_G CANADA 26 07-19-2013 11:05 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
Which would you give up? ant08 Scion FR-S / Toyota 86 GT86 General Forum 45 03-31-2012 05:32 AM
