Old 02-08-2014, 05:32 AM   #547
Bigmaxy
Drives: Pegasus GTS86
What torque specs are people using for the manifold bolts?
Sent from my GT-I9505 using Tapatalk
Bigmaxy is offline   Reply With Quote
Old 02-08-2014, 08:31 AM   #548
M1K3
M1K3's Avatar
Drives: vrooom...
Service Manual says 22.1 ft/lb. I would torque it to that then do what spitfire said by rechecking the torque settings after a week or two. If you were really worried you could also safety lock wire the nuts.
M1K3 is offline   Reply With Quote
Old 02-08-2014, 06:55 PM   #549
Bigmaxy
Thanks mate. That's what I went with initially and then gave it a tad more to 26 ft/lb following all the problems people have been having with leaks. Just wanted to make sure I hadn't missed something.
Old 02-11-2014, 09:01 PM   #550
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
How flat would you consider the header flanges to be, to stay within spec....? what would be minimum considered for resurfacing.
gdrider77 is offline   Reply With Quote
Old 02-11-2014, 09:20 PM   #551
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
I haven't gotten the new headers yet but if there is any variance I will be having them machined before they're put on the car. I wouldn't tolerate any measurable variance.
I have grimmspeed gaskets as well and they work quite well. They even helped with how horrible the old leak was.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 02-11-2014, 09:20 PM   #552
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by gdrider77 View Post
How flat would you consider the header flanges to be, to stay within spec....? Just wondering everyones thoughts on this. I have about a .5mm difference from one side to the other.
My old manifold had about a 1mm low variance and it leaked at this spot.
The new manifold i just got has a .5mm low variance in pretty much the exact same spot.
What i have noticed, is that its on the same spot on 2 manifolds from them. Makes me think that possibly their jig is slightly off....
And to be clear, on the leaking one i had the forrester gaskets which seem to be about 1.25mm
I have now got the new Grimmspeed gaskets, and they are about 1.6mm thick, so hope that helps.
Any measurable difference shouldn't be accepted imho
Sent from my IBrick
Old 02-11-2014, 09:26 PM   #553
gdrider77
gdrider77's Avatar
Im with you, but i guess im just wondering what would be considered acceptable, if any. Hoping Paul @AVOturboworld will chime in with what they look for coming out of the factory when it comes to QC. And should i take these to be resurfaced....
I thought that usually with manifolds, once they are done welding them together, they even out the flanges as a last step.
At least the new one is only off .5mm and not 1mm.
Old 02-11-2014, 09:39 PM   #554
protpibe
protpibe's Avatar
I would probably get it resurfaced, but I don't think it really matters since the headers will probably flex or shift a little over time once they've been heated and cooled a bunch. I would strongly suggest torquing the header bolts down to torque spec (+a little more) during the install, and then re-torquing every few days or so for the next week or two. Boxer headers have to deal with a really weird design compared to single flange inline-4's. I think that's one of the main reason why you see a lot of headers with flex pipe.
Old 02-18-2014, 02:14 AM   #555
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Just stopping by and reporting my 9,500 miles with the @AVOturboworld kit in just under 4 months! With three maps ranging from 6, 9, and 10 psi with stock injectors and fuel pump; I have yet to have an issue. All I need to do is upgrade my clutch prior to going E85 in the upcoming weeks and replace the worm clamps to the T-bolt clamp! Other than that, will post my charts in the upcoming weeks when I get my E85 tune! Talk to you guys soon!
BTW, will keep everyone posted on the @racerx1715 Oil Pan. I will be testing the pan for fitment and numbers as soon as I receive it. Will be posting a review on it.
DesertFrs is offline   Reply With Quote
Old 02-18-2014, 03:24 AM   #556
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I like seeing real people coming back with longer term reports thanks!
Old 02-18-2014, 09:58 AM   #557
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Absolutely unacceptable... And AVO keeps saying there is no issue... It's the OEM gaskets....
BTW, why did you edit the post
You payed a pretty penny for this kit, they need to be held accountable....
It's about damn time the issues with these manifolds are 10000% fixed.
Old 02-18-2014, 01:32 PM   #558
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
If the actual flange itself is warped, yes. I believe he was referring to the flat "plane" from side to side, and I addressed that in another post. Subaru headers naturally tilt inwards a bit before they are bolted down, talk to any shop that's fitted a ton of them. Properly torquing them down gets rid of that. And also as mentioned, fitting flex joints on one side would be a solution, but experience from doing headers for 30+ years, flex joints just become a failure point.
AVOturboworld is offline   Reply With Quote
Old 02-18-2014, 01:39 PM   #559
Sportsguy83
Drives: Limited BRZ
Maybe someday....
Old 02-21-2014, 01:27 PM   #560
nataku
Negative Mass
nataku's Avatar
Got the car back from PTuning a couple days ago. It's been running great so far. Still get occasional exhaust pops on aggressive shifts so I guess that's just a thing that'll happen.
New intake looks and sounds fantastic. It hisses loudly under boost and flutters when I let off. I tried to get sound clips with my GoPro but just ended up getting a better exhaust sound clip lol.
The headers were installed with the thick Forrester gaskets and sealed with RTV. My oil lines had a hose that was ruined so the hose was replaced and new clamps were used. All mounting points for oil lines were sealed with silicone.
I'll be checking the header bolts regularly for the next couple weeks to make sure they're torqued down. Hopefully all these leaks are gone for good.
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
