#547 |
Drives: Firestorm 86
Have a few questions?
How much header wrap is need to wrap the header? 15' or 25' If I wrap the op would I have any clearance issues? Thanks |
#548 | |
Drives: 2012 FR-S
Off the top of my head, I would guess with 1" you need about 50'. 2" would be around 25-30'. Here's a quick Jegs search for wrap http://www.jegs.com/webapp/wcs/store...rm=header+wrap |
#549 |
What will be the heat difference between wrap and unwrap header in the engine bay and oil temp?
#550 |
Hi people, Does anyone know the torque spec for the 3 12mm bolts connecting the header to overpipe ? I find it impossible to use my torque wrench to tightened it.
Cheers |
#551 | |
Drives: 2012 FR-S
After a few days of run in time, it's always good to go back and double check as the gaskets can often compress. Last edited by AceHeader-MT; 11-19-2015 at 02:12 AM. |
#552 |
Thanks for that. Will try it later
#553 | |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
An old trick taught to me during my impressionable years was the technique of wrench arc . . . Useful for low torgue specs, particularly in tight spaces. Snug until nut resists further tightening, then add a steady 15 degrees of wrench arc. Additionally owning a set of metric articulating, ratcheting closed-end and fixed-open end wrenches will bring sweetness to your header install. Mine are from Craftsmen on sale about $85, and this is Black November. Just saying. Good luck.
- When men make plans the gods laugh.
#554 |
Finally installed my 4-2-1 with 150 op. Fitment was good but it rub the skid plate when I test drive it today. Other than that everything is all good. I can feel more pull at lower rpm and the best part is its not too loud and no drone (Tanabe concept G catback and oem front pipe). Very happy with the result but not sure what to do with skid plate clearance. Anyone expirience the same thing? Maybe I can make some holes in those areas.
#555 | |
Drives: 2012 FR-S
We're not sure why some skid plates make contact and others do not. To solve this issue you remove the skid plate and using a block of wood and a hammer, flatten the raised structures on the plate. All instances we've had were a few mm of contact with those ribs. If you still have issues just let us know. |
#556 |
Drives: frs
So for those of you who have followed my noise issues, I finally put the stock cat back on. The car is very, very quiet. I have the catted resonated JDL ultra quiet front pipe, and it doesn't sound too bad. It definitely was my Corsa cat back that was the issue. I cannot wait until the Ace quiet cat back comes out, or I may look into the Invidia q300 if that doesn't ever happen. I am so enjoying driving my car again. The noise was so great that I couldn't ever drive it hard as the volume just drew so much attention. Anyway, I am glad that quiet is possible. That factory cat back is butt ugly from the rear now. Come on Counterspace garage and Ace, get that quiet exhaust together. BTW, anybody want to buy a Corsa cat back?
#557 |
Drives: Subaru BRZ
Anyone running the header with Perrin and aftermarket cat back?
I have an aftermarket FP with high flow cat. I also have Perrin 2.5. Wondering what the noise level will be with header and Perrin catback. Also, would a JDL ultra quiet lower the volume enough if I switched it out?
#558 |
Drives: Toyota GT86. N/A for life
So do you think the Type B 250, stock exhaust but with a muffler delete will bleed my ears?
#559 |
Drives: 2014 GT86
*) catless header
*) muffler delete. It certainly WILL be loud. If it's TOO loud or not is too subjective thing, each has personal limits of what is acceptable and what will 'bleed his ears'. |
#560 |
I currently have a catless UEL header with the muffler delete and it is okay, just a little drone.
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
