Old 03-19-2013, 02:28 AM   #589
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Originally Posted by lbroskee View Post
any idea if we can get the dash light on with this way too?
no it cant. stalk has the module itself to make the dash light work.
Originally Posted by calis5nest View Post
I might be wrong but I think the only way to get that is by getting stalk
correct
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 03-19-2013, 02:28 AM   #590
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by *KID* View Post
Here's mine on BRZ fogs... so much better than the outback fogs IMO
other then plastic Vs glass, what is the difference (ex. like none of that gap crap)?
lbroskee is offline   Reply With Quote
Old 03-19-2013, 03:05 AM   #591
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
These aren't black housing, they are chrome housing and I believe they identical to the gt86 fog lamps.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 03-19-2013, 10:49 AM   #592
lbroskee
lbroskee's Avatar
what about the gap between the bezel and the fog? if it's not there then i will gladly go plastic
Old 03-19-2013, 11:16 AM   #593
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Theres no gap.. Ill take a picture on my lunch
Old 03-19-2013, 02:22 PM   #594
HRTROB
HRTROB's Avatar
Drives: Toyota 86
correct
I think you might be able to get the cluster indicator to light up without the stalk. You would need a negative trigger relay setup and use that to ground pin 24 in the BCU (white wire).
I was able to get my rear fog indicator to light up without the front/rear fog stalk by jumping pin 2 (yellow wire) in the stalk connector to pin 4 (white wire). Rear fog would turn on with the front fog switch
HRTROB is offline   Reply With Quote
Old 03-19-2013, 03:17 PM   #595
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
HRTROB,
a little off topic, but can you order the stalk with both front & rear fog light spots on it?
kmbkk is offline   Reply With Quote
Old 03-19-2013, 03:20 PM   #596
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Sorry for the delay guys. for those interested to tap their switch on ignition key.without draining the battery and u can turn on the fogs without turining on parking lights and headlights.
unplugged that white socket
remove the black cover insulator around these wires, and pull the green wire, with the splicing wire connector, connect the red wire from the switch to the green wire.
Note: U need to squeesh in very hard to get the perfect contact on the wire, coz the green wire has a thick insulator.
Then plugged it back in the white socket, then screw in here the ground wire
enjoy with ur working foglights lol. hope this help guys.
Quick question: what's attached to the red & white wire in the first pic? I may do this soon and wanted to make sure I wasn't missing something.
Old 03-19-2013, 09:52 PM   #597
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
oh thats a stock set up connection wire. im not sure where that goes. so ur good on that part and nothing to worry.
Old 03-19-2013, 09:53 PM   #598
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
hmhm.. can u explain more pare? its like i need another relay and harness for it? or with the harness that i used, just add more trigger relay to it?
Old 03-19-2013, 10:17 PM   #599
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Finally got my forrester foglights in as well as my custom amber button. Still waiting on my bezels...
Just need to finish my custom harness, modify my H9 bulbs, and install the button with the relay and I'll be all set!
post_break is offline   Reply With Quote
Old 03-20-2013, 12:53 AM   #600
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Pare can use the relay harness you have, but you have to wire it differently. Pin 86 and 30 to fused +12v, 87 to fogs, 85 to a negative trigger.
You can also use a second relay if your current one is posiive trigger. Pins 85 and 30 to ground, pin 86 to your first relay's trigger, then 87 to the white wire
Old 03-20-2013, 12:55 AM   #601
HRTROB
HRTROB's Avatar
Drives: Toyota 86
HRTROB,
I'm sure I can, I just need the part number. Nigel said he can also order them if he had the part number
Old 03-20-2013, 12:59 AM   #602
lbroskee
lbroskee's Avatar
Any update on that pic. Also a part number?
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 06:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 03:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 02:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 08:29 PM
